Question about SanDisk Sansa Clip MP3 Player
Usb port not recognized - SanDisk Sansa Clip MP3 Player
    Problem Solver:
  • 8 Answers
1. Click Start --> Right Click on My computer
2. System Properties will appear Click Device Manager (for Vista or windows 7) or Click Hardware Tab and Click the device manager button
3. Click on the plus sign under Universal Serial Bus Controllers
4. See if there is a Unknown device. If there is one just right click on it and click uninstall
5. Shutdown the computer
6. Disconnect all usb device leaving only the MP3 hooked up
7. Turn the computer back on
8. Let the computer detect your MP3.
9. If it does detect it its all good but if it still unknown under device manager contact your MP3 manufacturer
Posted on Nov 15, 2010
    Habit-Forming:
  • 68 Answers
1. try using usb1 port ( instead of usb2)
2. check the Device-manager for USB controllers normality. (or try to upgrade versions)
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
1 usb port on toshiba satellite c660 doesn't recognize mouse
If is just a USB port, then it could be a driver problem, or that USB hub is turn off, or is a fried/bad USB port. Try another USB device on that port too.
Mar 19, 2012 | Gigabyte GA-8I845GVM-RZ Motherboard
My computer doesn't recognize my dane-elec 8gb usb stick , although other usb devices do work.
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Aug 19, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
IBM ThinkPad T41 won't recognize USB 2.0 Ports (sees them as USB 1.1)
all available ports are not recognized? have you tried other known good usb devices on those ports?if other devices are recognized then it is an issue with the usb device you were first trying to hook. if not, then it may be the port issue or driver. so update chipset driver for your pc. use ibm's website to check for drivers of your pc.
Mar 31, 2010 | IBM ThinkPad T41 Notebook
My adaptor is not recognized in my USB ports I installed the router and it completes all of its connection checks. I am trying to install the adaptor on a remote computer (in the basement) and that...
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
Dec 15, 2009 | Computers & Internet
I am having a problem with my computer (e-machines T5082). I does not recognize any devices plugged into the USB ports. Printer, cameras, Zune, ect. They have power because my speakers draw power from a...
Greetings....
Please try to check if your USB port both rear and front USB port are not defective. Most common problem of defective usb ports are when plug your usb devices it won't recognize the device you inserted. So to make sure that your USB Ports are not the main cause why your computer won't recognize devices you inserted.
Nov 03, 2009 | E-Machines T5082 PC Desktop
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
Thinkpad T20 won't recognize usb port
You can get a PCMCIA adapter with 4 USB v.2.0 slots on eBay. It requires power from the USB port on the laptop, but the pigtail connector is included. Works like a charm! Comes from China just like everything else in this country.
Nov 16, 2008 | IBM ThinkPad T20 2647 Notebook
Pleomax 6gb USB Drive No Longer Recognized by My Computers
It's either the USB port, the drive electronics itself, or the USB cable.
First I'd try a different USB cable.
Apr 06, 2008 | Computers & Internet
USB Connection Not Recognized
check the ports thr' control panel-if driver for usb port is missing pl. reload usb driver.check with pen drive whether the usb port recognizes the pendrive as it flashes the light on the pendrive.
Dec 21, 2007 | JVC 20GB Everio GSeries HDD Digital...
SanDisk Sansa Clip MP3 Player Logo
196 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
