Question about Fisher and Paykel IWL12 Top Load Washer
Error code 37 for iw811 - Fisher and Paykel IWL12 Top Load Washer
  • 37 Answers
Code 37 is 1:pump blockage
2:your diverter valve is blocked as well
3:check to make sure your drainage hose is not kinked
Posted on Nov 20, 2010
I have a Fisher and Paykel IW811 Intuitive Eco washing machine on which I have recently replaced the pump motor and motor control board. I have reset the size for 650mm.
Switch power off at wall & unplug machine for a couple of minutes. Plug it back in and power on. See if it resets it, If not then you may have a faulty main board or it has been damaged somehow during fitting.
Jan 09, 2017 | Fisher and Paykel Washing Machines
Washing Machine Intuitive Eco model number IW811 won't power on?
Possible Cause Solution The power switch is not turned on at the wall. Unplug the machine from the wall. Wait 60 seconds, plug back in and turn the power back on again. The household power supply is at fault. Try plugging another electrical appliance into the power slot.
Aug 06, 2012 | Fisher and Paykel Washing Machines
Fisher and paykell Iw811 overfills on wash cycle
The pressure sensor is going bad and soon you will get fault code 66.
May 27, 2012 | Fisher and Paykel Washing Machines
I am contemplating buying a fisher & paykel Intuitive Eco model IW811 washing machine that is giving an error 37 message. what does this message mean & what would the ball park cost be to...
Hi Mike just read your posting.Error code 37 means you have the fault called PUMP BLOCK ERROR.There are 3 reasons this fault appears,they are ,the pump is jammed or blocked,the control module is faulty or the pressure switch tube is blocked.If you can before you buy it look under the machine and to the front right you should see a black fan.This is your pump.Try turning the fan to see if you can loosen it,The fan should turn freely.Then try a spin cycle and see if the machine drains and spins.Please reply if the machine still does not drain or if you have the new type of pump or for further help.Also if the machine does start to drain please reply on how you got on.Looking forward to your reply.
Sep 26, 2010 | Washing Machines
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 37
Hi there
The Code 37 error may occur when the concerned device is not connected to the system correctly and when its driver is faulty. A code 10 error is common when you add or remove USB devices or video & sound cards to and from your PC. When these errors occur, you may receive the error message given below.
Windows cannot initialize the device driver for this hardware. (Code 37)
To resolve code 37 errors, first ensure that your device is properly connected to your system. For instance, check all the cables of your printer or check that your sound or video adaptor is properly seated in its slot.
Try to remove and reinstall the device, and run the Add New Hardware Wizard from the Control Panel to see if Windows detects and installs it. If this does not resolve the issue, then update the device driver by performing the following steps:
  1. Open Control Panel and select System.
  2. In the System Properties dialog box, select Hardware tab, and then click on the Device Manager tab.
  3. Scroll down the Device Manager window and identify the faulty hardware from the list.
  4. Right-click on the hardware and select Update Driver.
  5. Follow the screen instructions to resolve the error.
If these steps do not resolve your error, then the problem might be with your device. Get it checked by an authorized technician.
Good luck
Jan 14, 2009 | Computers & Internet
Fisher & Paykel intuitive code 37
My machine is actually an IW811. But what happened was I checked motor see if it was spinning & confirm it was. But realised instead of pumping water out, it was going back into bowl, went straight to diverter valve, found control solenoid was burnt, was very hot to touch, even though hasn't been operating, only with main power point on. Suspect motor control board faulty as well. Replaced both parts & was fine after that. New contrl board has been upgraded & came with listings of all codes, explaining every code in detail. Specs to test switch, motor & solenoid resistances. But thanks to you guys for pointing me in the right direction, with what code 37 means in the begining.
Nov 23, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Nov 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Fisher and Paykel IWL12 Top Load Washer Logo
359 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
