Question about Jl Audio 12W3 Car Subwoofer
12 w 3 v3 2 cut off
During loud play they simply shut off
after hitting real hard for half of a song
I turn off the receiver and back on and then I have bass.
Im running an alpine MRP M650 with gain and everything down
no gain on head unit
brand nre in the box is this normal?
I had the V2 and never this problem.. I know my amps not shutting down its not even hot
there 12'' 2 ohms
wired pos. to neg.from one speaker to amp
and same for other speaker
what ohm is my amp seeing
how can I accomplish a 2 ohm load wiring if this is wrong?
  • 109 Answers
Again as I have stated in my other answer to you. You can not wire two SVC 2 ohm subs to acheive a 2 ohm load. more than likely you are running your amp at 1 ohm mono and this is why it is clipping and shutting off.
Posted on Jun 24, 2008
Why is my AKAI DPS 12i recorder is making loud loading noises as i rec or play back the songs? there is about 12 songs on there could this have anything to do with it?
It has nothing to do about the amount of songs present at this device. It has to do about it\'s hardware. I\'m not sure if there\'s a fan inside to cool a processor or other parts (check at the back of this device where all connectors are located). If there\'s dust in the fan-section, the fan has to suck more air, being able to cool the interior devices.
Oct 14, 2013 | Akai Professional Dps 12 Track Recorder...
Whenever I start playing on my xbox or playstation, the receiver will shut off (the red light is blinking around the power button). Once I hit the button, it stops and then I can turn the receiver back...
does it only shut off on high volume or a loud noise?
It's the amp tripping to protect itself.
look out for a shorting speaker wire or faulty speaker etc. disconnect each in turn to find out which
Sep 03, 2010 | Denon AVR-987 Receiver
My sc-ch900 cuts out after a minutes playing. Is
did u play it real loud? if not, probably not. in most over load problems the system shuts down pretty fast. it will not take minutes if it has an over load protection. it is pretty hard to tell exactly what is wrong with that kind of sophisticated systems unless we take a look inside. it is probably bad power supply within the system. like i always suggest, if warranty covers-replace it. otherwise u have to get it fixed.
Mar 12, 2010 | Technics Audio Players & Recorders
Losing power
mine does this too, I have the deck on my boat and on land the deck cuts out when a bass line hits or loud music comes in, cuts out at about 20 on the volume level, however, when on the water and the motor is running, my voltage is up to 14 vdc or so.. At this point, I can crank the deck up to 30-37, and it will scream , doesnt cut out or lose power just rocks. I have heard that kenwood decks are competition stereos and require 14-16vdc, but I have never found any proof of this. One thing you can do is order a battery from summitracing.com that runs higher than 12vdc. But then again im just speculating
Mar 05, 2009 | Kenwood KDC-MP538U Car CD/ MP3 Player
PS3 freezing during multiple games
Check the vents on you ps3. If those are blocked or even too close to a wall or something like that, the game will freeze.
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Dec 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
Ive got no power to the amp trough the rem wire unless i connect.
You need a bigger amp and make sure its a two channel. Four and five channel amps are for mids and highs. If you want real bass get a two channel. If you dont want to buy a bigger amp, Go get a capacitor. It acts like a battery charge storage for when your sub needs to hit those real low notes. It takes a lot of power. Also if you get a capacitor your altinater that charges your battery will not have to work so hard keeping your battery charged, Thus not wearing out your altinater and not having to replace it so soon because it will happen.
Another quick fix is turning your gain down. I turn my gain up half way, maybe a little past half way. You might not get the bass hitting as hard but at least it wont shut off on you.
Nov 20, 2008 | Kicker 01C8VR4 Car Subwoofer
Sansa shutting off during song
this is normal for this player - it goes to sleep fairly quickly - se p.35 of manual to see how to change frequency of shut off
Apr 18, 2008 | SanDisk Sansa e260 MP3 Player
My Onkyo Receiver TX 601 is turning itself off
Several things can cause this: Loud signal passages can momentarily draw high currents at the mains, especially if you have unit plugged into power stripe with other equipment. Or if unit is plugged into isolation transformer, current draw may exceed output of transformer. Too many speakers hooked to output or if one is bad (partially shorted due to overheating)
Apr 04, 2008 | Onkyo HTR500 Receiver
Phillips Mp3 player-Songs get cut-off half-way through playing
Play this file in media player 9,10.if it play fine then the problem of mp3
Feb 29, 2008 | Philips GoGear SA178 MP3 Player
Jl Audio 12W3 Car Subwoofer Logo
99 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
