Question about Cycling
I loss my Serial number: - Cycling
    Guru:
  • 347 Answers
Most serial numbers are located on the bottom of the bike known as the bottom bracket. Too view the serial number flip the bike over and look between the crank arms on the bottom bracket. If the serial number is not visible it may be under a the guide for the cables and that will need to be loosened. Other places for a serial number, but much less common are the underneath of the rear stays or the rear dropouts.
Posted on Nov 18, 2010
Code U1016 2000 Grand Am GT
DTC U1001-U1254 Loss of Communications
Powertrain Control Module (PCM) U1016
Vehicle not starting an running ?
Do you know anything about GM class 2 serial data network .
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for State of Health monitoring (Node Alive messages). A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. Once an identification number is learned by a module, it will monitor for that module's Node Alive message. Each module on the class 2 serial data circuit which is powered and performing functions that require detection of a communications malfunction is required to send a Node Alive message every 2 seconds. When no message is detected from a learned identification number for 10 seconds, a DTC U1016
The control module ID number list below provides a method for determining which module is not communicating. A module with a class 2 serial data circuit malfunction or which loses power during the current ignition cycle will have a Loss of Communication DTC set by other modules that depend on information from that failed module. The modules that can communicate will set a DTC indicating the module that can not communicate.
Control Module
ID Number
016
Electronic Brake Control Module (EBCM)
040
Body Control Module (BCM)
064
Sensing and Diagnostic Module (SDM)
088
Instrument Panel Cluster (IPC)
096
Do you know how to do a loaded circuit test for the power an ground circuits for that module ?
The Trainer 61 DTC Diagnostics Pt1 How The ECM Thinks
ECM Inputs and Outputs Diagnosis
Feb 28, 2017 | Pontiac Grand Am Cars & Trucks
My gun was stolen last week i dont have serial numbers how do i obtain numbers so my insurance will cover the loss
Hi Melinda:
If you obtained the gun legally, the serial numbers should have been recorded on the bill of sale. Depending on how long you have had it, the store that you bought it from may have aa copy of the invoice if you cannot locate yours.
I suggest that you contact them to see if the information is available.
Sep 23, 2015 | Cell Phones
2002 Chevy Avalanche "U 1041" Loss of EBCM/EBTCM communication. Both front and rear rotors,brake pads and hardware has been replaced. But I found out they did not do the emergency brake. Also this shop did...
How did you come up with this code ? U 1041" Loss of EBCM/EBTCM ????? Do you what U code's are for ????? Brake pads an rotors have nothing to do with this code ! This is a problem with the serial data communication network or the ABS module it's self .
DTC U1001-U1254
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for state of health (SOH) monitoring/node alive messages. A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. Once an identification number is learned by a module, it will monitor for that modules node alive message. Each module on the class 2 serial data circuit is required to send a node alive message every 2 seconds. When no message is detected from a learned identification number for 5 seconds, a DTC U100 000 is equal to the 3-digit identification number of the module.
your best bet ,chevy dealer !
Oct 15, 2017 | Cars & Trucks
I hv loss my imei of samsung sgh L-700
The IMEI number is uniquethe each mobile phone. The number is printed onthe label under the battery. You can also get theIMEI number by entering this on your phone *#06# It will then display your IMEI numberand you may also get a unique global serial number. Your IMEI number should be15 digits.
Sep 03, 2011 | Samsung SGH-L700 Cell Phone
If i loss my serial number
Contact your sales representative, where you bought Adobe software, or contact Adobe directly. They will present you with options you have. If you have your original invoice there should be no problem with your serial number, they might issue you a new one...
Mar 06, 2011 | Adobe PHOTOSHOP CS3 10 WIN UPG FR DV 1U...
It dosent hold the pressure all the time
If you haven't already, I suggest contacting Flushmate technical support at the toll-free number on the serial number label. They'll need the serial number off teh Flushmate and will be able to guide you in identifying the source of any air-loss and recommending a solution.
If it's under warranty and replacement parts are needed, they'll send them at no charge.
Hope this helps
Sep 02, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
Have a few codes that I dont know what they are for, b1004, u1064, u1040, u1255 and c1095
b1004 = FUEL LEVEL SENDER LOW
u1064 = LOSS OF TSM/TSSM/HFSM SERIAL DATA OR SERIAL DATA ERROR
u1040 = ?
u1255 = SPEEDOMETER SERIAL DATA ERROR/MISSING (carburetor model)
TSM/TSSM/HFSM SERIAL DATA ERROR/MISSING
ECM SERIAL DATA ERROR/MISSING
LOSS OF SPEEDOMETER SERIAL DATA ERROR
c1095 = ABS FRONT BRAKE SWITCH OPEN
Jul 04, 2010 | 2008 Harley Davidson FLHR Road king
Carrier, model 50RMC024EPC3030; serial number---how many tons??
This is a 2 ton unit (24,000 BTU/HR) 50RMC024EPC3030 The proper way to size a cooling system is actually by the Heat Loss Method, but as a rough estamite generly 500-1000 sqaure feet per ton. Hope this helps
Mar 19, 2010 | Heating & Cooling
Cycling Logo
384 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
