Question about Xerox WorkCentre 470CX InkJet Printer
Hello, my xerox WC470cx is having a difficult time pulling the paper.
How i fix the problem of xerox phaser 3117 laser printer that takes a paper in and makes noise and stop printing?
Hi Narendra,
This is really difficult to answer without being on site!
All I can think of is perhaps you have some piece of paper stuck inside.
If you had some paper stuck before, and you had to pull it out causing a piece to rip off try putting the bits back together again on the desk, if you can't find them all then that's the bit still stuck inside you need to look out for inside.
If in doubt you will need to get your local engineer to have a look inside.
Good Luck.
Jun 13, 2015 | Xerox Office Equipment & Supplies
Xerox phaser 3117 paper jam problem, how to solve it
If paper jams every time, just open printer cover, pull out toner cartridge and you see paper feed roller it is rubber, just clean roller with alcohol and cloth.
I hope this help!
Mar 31, 2011 | Xerox Phaser 3124 Printer
Xerox 3117 paper jam
I hope this help!
Oct 08, 2010 | Xerox Phaser 3117
Xerox XD120F copy machine not pulling paper through to make a copy. Might grab paper and then jamb.
If the paper is not pulling out of the tray, you should replace the feed rollers. They are easy to replace.
If it is pulling the paper about 2/3 of the way through the machine, you would most likely have a broken fuser heat roll gear, again cheap and easy to replace.
Feb 15, 2010 | Xerox WorkCentre XD120f Copier
Xerox Phaser 6120 cannot feed paper without help
As this is an old posting I should imagin you might have it sorted by now.
if you have these type of problems clean the feed in rollers with a alcohol wipe or similar. There is usually a solonoid / clutch release mechanism that controls the paper selected from tray. I would go for the simplest solution. Over time the rollers get coated in paper lint, clean water is usually best if that fails perhaps an alcohol wipe might improve matters.
Good luck.
Jan 03, 2010 | Xerox Phaser 6120N Printer
Printing problems
Hi!
Could be a couple of things, but it sounds like the tires on the paper roller have worn out.
Like tires on a car, the slightly abbrasive surface of the rubber tires on the paper roller will go smooth over time...causing the rollers to slip on the paper instead of pulling it throuh the printer.
It's a relatively cheap/easy to install part.
You can contact Xerox for the part: www.xerox.com or other websites such as: www.sparepartswarehouse.com.
There may also be a local Xerox service centre where you live (most major cities have at least one) & the tires will be a very common part for them.
...If it's not the tires, it could also be the mechanism that lower the roller onto the paper. If this is damaged (or not calibrated correctly) the printer will have problems feeding the paper through as well.
The only easy suggestion here (if you're not comfortable replacing parts yourself) would be to take it to a registered Xerox service centre for maintenance.
Hope this helps!!
Dec 04, 2009 | Xerox Phaser 6115MFP/N Laser Printer
Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Whit
Item, Inc.
Nov 10, 2009 | Xerox Phaser 7700DN Laser Printer
Xerox Phaser 8400
There is a flag sensor on the registration assembly that is possibly broken.
Sep 07, 2007 | Xerox Phaser 8500/DN Printer
Xerox WorkCentre 470CX InkJet Printer Logo
74 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
