Question about Nokia 5130 XpressMusic Red Unlocked Import Cell Phone
How do you open nokia 5130 to replace battery and remove sim card??
  • 4 Answers
SOURCE: how do I remove the battery and put the sim card
These are steps from the Nokia 2760 manual found at :
http://nds1.nokia.com/phones/files/guides/Nokia_2760_UG_en.pdf
(pages. 12-13)
1. Press and slide the back cover toward the top of the
phone to remove the cover .
2. To remove the battery, lift it as shown
3. Carefully lift the SIM card holder from the finger grip
of the phone, and open the flip cover
4. Insert the SIM card, so that the bevelled corner is on
the upper left side and the gold-colored contact area
facing downward.Close the SIM card holder, and
press it to lock it into place
5. Insert the battery into the battery slot
6. Align the back cover with the back of the phone. Slide
and push it toward the bottom of the phone to lock it
Posted on Apr 14, 2009
P0W3R GL1CH
  • 185 Answers
SOURCE: can not slide open back of nokia 2760 cellphone in
insert a thin object betwen the phone and the back to b able to use leverage to pop it open
Posted on Nov 05, 2009
SOURCE: nokia 5130 sim card registration
Try another SIM Card to your phone & please verify that your card has been installed properly.
Thanks.
Posted on Nov 16, 2010
caroldon
  • 17130 Answers
SOURCE: i am using nokia 5130
Perhaps there is some loose connection of the SIM card to the SIM card holder and contacts. So remove the battery and the SIM card., Use a paper to polish the SIM card contacts and the contacts on the holder. Make sure that the SIM when placed fits well into the holder firmly and in place , If not you can lift up the contacts very carefully so that the SIM never loses contact.
If this wont solve there are errors in the main board which might need more attention with help from Nokia care.
Posted on Mar 28, 2011
mohankumar63
  • 223 Answers
As if your using nokia 5130 cellular phone your mobile is 100% fine as a new one you just have problem with your sim card the problem is your sim card as got damaged.The reason for sim damage is you have keep your sim card in your valet,or you used to change your sim frequently.The other reason is you have taken a new sim but the service provider company may not recived your address prof from your number or your not using that sim from three months. so you better forget that number and take a new number. var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
Posted on Jun 12, 2011
My Nokia 5130c-2 when i open the phone,then it come out ''NOKIA'' this writen,after that the screen all white,dun have anything file come out.
Flashing is the only solution, but anyway Remove Memory Card,Sim Card and reboot by inserting only the battery.Try it for 2-3 times.If the problem still persist better to contact mobile repairing shop or follow this trick.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5130 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment. thanks for visiting fixya. Good luck.
Aug 17, 2011 | Nokia 5130 Cellular Phone
How to unlock my 5130xpressmusic from telcel mexico
Try to get it from online providers..
Aug 13, 2011 | Cell Phones
I am using nokia 5130 .but it was some problem,some times my mobile showing sim card regestration failed
Mar 28, 2011 | Nokia 5130 Cellular Phone
How to format nokia 5130 c2 xpress music without security code bcos i forget my code
You can try to do these things to solve your issue. I saw this at this link:
http://wiki.answers.com/Q/How_do_you_format_nokia_5130-c
I hope it helps.
1) Turn off your Nokia 5130-c2 phone
2) Remove your SIM CARD and your MEMORY CARD
3) Hide your SIM CARD and your MEMORY CARD in a safe place!
4) Turn on your phone while pressing: Ke(3) + Green call button + *
5) Your Nokia 5130-c2 is now formatting, please wait for a while...
6) When done, reinsert back your SIM CARD and yor MEMORY CARD in to your phone
7) There you go! your code is now set to (12345)
Mar 12, 2011 | Nokia 5130 Cellular Phone
Nokia 5130 xpressmusic contactserviece
Hi.
It means that the phone crashed, and must be taken to a Nokia service centre. Try first flipping out the battery for one minute. Restart phone with no SIM and no SD card, then restart again with SIM. If problem is still there, take the phone to your local Nokia shop.
Regards.
Ginko.
Feb 27, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
Nokia 5130 rejected my sim?
hi,
there are many reason for that,
1) loose sim card. try removing your sim card and place it again securely to the slot.
2) defective sim card. try replacing another sim and see if it works.
3) bad terminal contact. if you can manage to see your sim card terminal in the phone, try checking it if their is no abnormalities in it.
4) the worst is that it has a defective sim card IC. (rare case)
Hope i helped you.
Don't forget to rate me OK!
regards,
John
Jan 04, 2011 | Nokia Cell Phones
My nokia5130 phone is not giving proper backup
do a full reboot roshanadhika
to do a full reboot, please follow this steps
1. remove the sim and the battery whilst the phone is turned on
2. insert the battery without the sim card then turn the phone on.
3. remove the battery again while the phone is on.
4. insert the sim and the battery then turn the phone on.
hopefully this works roshanadhika!
Nov 28, 2010 | Nokia 5130 Cellular Phone
Nokia 5130 insert sim
Initially try by cleaning the sim card slot.
The insert sim card happen due to the problem in Sim card holder slot and the IC related to it.Contact the service center they will check the sim card slot and provide you a solution either by cleaning the slot and PCB board or replacing IC
Jul 08, 2010 | Nokia 5130 Cellular Phone
I have Nokia 5130 XpressMusic. i want to formate at my own . how can i fromat it ?which software is used to formate it?
Here are the tips to do follow my steps carefully:
Jul 06, 2010 | Nokia 5130 Cellular Phone
Nokia 5130 XpressMusic Red Unlocked Import Cell Phone Logo
251 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
