Question about Gaggia Platinum Swing 2-Cup Coffee Maker
My gaggia platinum is showing an out of service error code [1] and i don't know what to do! Sandra
3 Suggested Answers
SOURCE: My gaggia platinum is showing an out of service
On my machine remove water tank, remove crip / coffee bin, remove mach and wash. Tip machine on its side (turned off) using a small screw driver go around the coffee grinder and clear it completly, you will need a touch. Re assemble. First run with no beans and wait for the fill bean message, fill with beans off you go. Its only happend twice both with cheap beans
Posted on Nov 21, 2010
  • 3 Answers
when you see that error if you push coffee button does it turn from 1 to 41? if so you could need either a new HAL sensor for the grinder motor or a new grinder motor.
Posted on Jan 11, 2011
Gaggia cappuccino xtwo. What is error code 1?
Im not sure if this will help but I've got some Gaggia Accademia Error Codes, maybe they are the same as the Gaggia cappuccino xtwo.
Hope it helps. https://wll-documents.s3.amazonaws.com/Gaggia/Accademia/Accademia%20Error%20Codes.pdf
Apr 05, 2016 | Gaggia Coffee Makers & Espresso Machines
Gaggia Platinum Vision no power
You are correct it could be any of the possibilities you have mention.
It is worth checking the two thermal cutouts on top of the boiler.
These can be accessed by removing the top cover only.
If you press the center of the resets and you hear a click you have found the fault
Jan 22, 2013 | Gaggia 74845 Platinum vision coffee maker...
My new gaggia accademia won't work. IT shows error code 05. Con Youtube help me?
reset the error code and read your instr. manual. God bless you
proceed according.
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord , the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 10003380 Accademia Automatic...
What does wrench on screen of gaggia platinum vision indicate
I found a failing power supply board can cause the 'wrench' error code even in standby. The board is available for about $65 online and works in many Saeco models as well.
Jul 18, 2012 | Gaggia 74845 Platinum vision coffee maker...
Gaggia Platinum vision says dispensing failed
I suggest the spanner is telling you there is a fault, so you will need to get it serviced or repaired. It is doubtful that you can do anything.
May 06, 2012 | Gaggia 74845 Platinum vision coffee maker...
My gaggia platinum is showing an out of service error code [1] and i don't know what to do. Called the service centre all i get is "leave a message".
Nov 11, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
Looking for an english manual for Gaggia Platinum Swing Up coffee machine.
Hi
I have the original manual (a bit marked) but a better solution is to download the manual for the Swing Model from http://nettopdf.info/download.html?dl=aHR0cDovL3d3dy5jaGV6YmV0dGF5LmNvbS9pbWFnZXMvZ2FnZ2lhL2dhZ2dpYSUyMHBsYXRpbnVtJTIwc3dpbmcucGRm&t=pdf&name=Gaggia%20Platinum%20Swing%20Operation
The only difference is the manual, instead of electrical mechanism that moves the cup(s) up and down.
Cheers
Liz
Oct 07, 2010 | Gaggia 90901 Platinum Swing Up Automatic...
NEW GAGGIA PLATINUM VISION GRINDER NOT WORKING ANY WAY TO FIX THIS?
If it's new send it to a service centre.
These grinders are failing and can also damage the power supply board.
Dec 29, 2009 | Gaggia Platinum Vogue 90800 Espresso...
Gaggia platinum vision grinder not working
The grinder is faulty,take the unit to a service agent for repair
Dec 29, 2009 | Gaggia Platinum Swing 2-Cup Coffee Maker
Gaggia platinum leaking from milk island
The problem is the steam valve leaking.
It does not close fully and leaks.
You will find that when you turn the knob is seems very loose.
A service is required.
Jun 23, 2009 | Gaggia Platinum Vogue 90800 Espresso...
Gaggia Platinum Swing 2-Cup Coffee Maker Logo
125 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
