Question about Canon IMAGERUNNER 2230 Copier
Canon imagerunner 7095 finisher can't be used. I already turned the finisher (limited settings) off and I get the same message
hamzaskilltd
  • 316 Answers
SOURCE: I have an error code Eooo578-8001. On my 7095 canon imagerunner.
paddel error
Posted on Jun 06, 2010
  • 168 Answers
SOURCE: Canon ImageRunner Scan feature won't connect to network
its waiting for the command from the computer. in order to use scan you have to down load the canon scan tool from imagerunner.com / support/ downloads/ office products/ then canon network utilities. look for network scan gear tool ... down load save open run setup then open the program and you can either let it search for a scanner or you can put in the IP adress for the copier. then under your scanning software ( ADOBE PRO) eg. you selesct the scan gear tool as the scanner. to scan a doc you put paper in feeder select scan online then from your computer tell your software to scan good luck
Posted on Jan 03, 2009
  • 58 Answers
SOURCE: canon IR 7095
if you can not use the finisher and the machine says Functions limited
press additional function
press common settings and then scroll to find limited functions mode if its on press the off button press ok and turn off the machine and then back on
Posted on Aug 07, 2009
  • 61 Answers
SOURCE: canon imagerunner 7095 displays error
The fixing inlet sensor moves up and down to detect paper it is not go to home position. Make sure nothing is blocking it's path. Replace fixing inlet sensor ascent/descent motor or sensor itself.
Posted on Oct 15, 2009
  • 168 Answers
SOURCE: Canon Imagerunner 7200 At the bottom of the
touch the add func key then common settings scroll till you see limited functions mode touch it then turn limited function to off then turn copier off then on
Posted on Nov 20, 2009
Ir4570 message: finisher cannot be used help me pls.
Dear colleagues,
I have Canon IR 3045, is giving the following message "finisher cannot be used" is there any solution to reset the message.
Many thanks for any assistance.
Boualem
uae
Sep 16, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Need help with using the staple feature on my cannon imagerunner 2870. The staple button is not highlighted to be used, but the copier is full of Staples
Do you have on display message like: " limited mode" or similar?
If yes there is some problem with staple finisher. In most case with up and down movement sensor, or copies dont come out sorted, instead goes everywheare on delivery deck...If Im not mistakaen error is E 542 or 724.
You can try under user mode - copy sett.- there must be an option to turn off limited mode. Then restart machine, if something is wrong you will get error code message.
Jun 24, 2010 | Canon Office Equipment & Supplies
Canon Imagerunner 7200 At the bottom of the screen it says "Finisher Can Not Be Used" Also says "Ready to Copy (Function Limited)"
Nov 18, 2009 | Canon imageRUNNER 7200 Copier
Finisher setting will not work
touch the additional functions key then touch custom settings scrolll till you find limited function mode touch it then turn limited function off turn copier off then on this should turn the finisher back on unless the finisher has an error
Sep 25, 2009 | Canon imageRUNNER 5000 Copier
Canon IR 7095
Jul 28, 2009 | Canon imageRUNNER 3570 Copier
Canon imageRUNNER 7095 copier has the error code E00057a-8003 ..... can you tell me what this means? can we fix it on our end? Let me know as soon as possible because our copier has been down for 3 days....
This Problem occured with a finisher V1/V1L attached to our Canon iR7095.
The staple unit didn'tmove back to it's initial position. After restarting the printer there was a really strange clattering sound coming from the staple unit.
Problem was solved by removing all trapped pages from finisher and copier. Probably you have to restart several times. The system should reset and move the staple unit back to initial position.
Aug 12, 2008 | Office Equipment & Supplies
ImageRunner 6570 Stuck on limited functions
Press the "Additional Functions" button on the control panel. Press the "copier settings" button. Then scroll through the screens to the fourth or fifth screen (I forget which but you'll find it) and you will see "limited functions" "on" and "off". Press "off", then turn the copier off and then turn it back on again. Your finisher should work now.
Jul 29, 2008 | Canon IMAGERUNNER 6570 Copier
1,243 people viewed this question
old marine
old marine
