Question about Sony XR-CA400 Cassette Player
Please for Sony FM/MW/LW cassette Car Stereo XR-CA410 no work in FM. Power connection number 8 for earth negativ ground and number 4 for positive +12volt supplies? Thank you.
  • 4 Answers
SOURCE: continuous power supply
get a volt meter or a test light and check which wires from the car are constant 12v and which are switched with the ignition. I think that usually the red is constant 12v and yellow is switched. You might want to try switching the two and see if that helps.
Posted on Jan 10, 2008
SOURCE: to install sony car cd/mp3 player removing the FM cassette player
how to connetct stereo system
Posted on Apr 13, 2009
etirbynnor
  • 655 Answers
SOURCE: connection diagram for XR-CA300 SONY car stereo
Hello eliasrvc2,
Sony's support site shows the color codes for wiring both a 9-pin and a 16-pin harness. Click the appropriate harness to bring up the color code table.
Hope this helps.
Posted on May 05, 2009
  • 4875 Answers
SOURCE: how to decode my radio cassette sony model
Sorry...this code will only be available from your Main Dealer or a Radio Decoding Service
Posted on Jun 19, 2010
muleunit
  • 36 Answers
SOURCE: i need code for sony
If you have the original remote control, you can use this website to decode the passcode for you. They charge a small fee however.
http://www.dndservices.co.uk/Sony-XR-M510-code.html
Posted on May 04, 2011
Does anyone have an install manual or color code chart for a Sony xr-17 am/fm cassette stereo from the 80's?
This is the best I can do for you. I don't see any free manuals on line. In fact, I am hard pressed to find this anywhere else. (Vintage Manuals in Indiana appears closed, although you see web references to it.)
Sony Service Manual for the XR 17 Cassette Player Radio Car Stereo Repair...
Aug 26, 2017 | Sony Car Audio & Video
Sony car stereo
be careful withn that stereo u could trigger the anti theft system in ur car then ull really have to do some homework cause then its costly to fixs
May 22, 2013 | Sony CDXGT40U - Cdx-gt40u Fm Mw Lw Cd Dsp...
Unable to tune in to programmes on LW, MW and SW bands. FM working fine
If you are experiencing bad or NONE AM (MW) reception ,if your receiver has an external antenna connection point here is the solution... It should also have a ground connection as it is rare such a point does not accompany an external antenna connection.
The problem with MW reception is the vast frequency range of the MW band as" 540-1760kHz "
means nighttime fade out, and even heavy static and distortion..( less than SW )
in order to receive a station on LW and MW bands you need to have a "Loop Antenna " that normally supplied by manufacturer..if you cant locate it ,you can buy it in any electronic store..it is a very cheap accessory..additionally both LW and MW works good in daytime with powerful radio stations in your vicinity ..espacially LW..not much stations on these days..except in Europa..MW works better and more stations come after sunset ..
SW band is a little bit different.if you really want to listen SW in depth ,and if your receiver has multiple SW bands as well ,you then need special SW antenna to be attached to your receiver..otherwise it is not worth to listen it due to heavy static and distortion on the band..,unless you want it..just for testing and to see what is available in your area pls attack a plain wire (about 1 meter ) to ext antenna plug and try to search it..if you desire to learn shortwave -Listen To The World please visit the URL below.
http://www.hamuniverse.com/shortwave.html
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us
to continue f
or Helping out the Community :)
Jul 07, 2011 | Audio Players & Recorders
Cannot get any sound from fm. i have stations and aerial is ok just have sound on mw/lw any suggestions? gail
seems the fm tuner is blown, did you check antenna and connections? if ok then contact service for fm tuner problem.
regards
Feb 19, 2011 | JC Whitney SONY XPLOD 10-DISC CD/MP3...
Dear sirs, I have just received a service manual for a unit your company produced quite a number of years ago. Unfortunately however,I have been advised by several repair shops here in the US that...
Sorry I tried and searched the web for anything i could about this product. All I could find is current or a little older models. nothing that even resembles what your looking for. My only suggestion would be if you live in a large city put an add for one in the want adds.
Ive tried to even find a website where you could post like a want add to buy from someone thier old Panasonic fm/lw/mw/sw radio stereo cassette recorder,model no.RX-5150LS so you could part it out but no luck on that either.
Sorry I was unable to help you.
An other suggestion is just to take out the parts they say are bad, take it to a electronic part store and see if they have anything that's similar,
or just see what they come up with or show u.
Oct 10, 2009 | Car Audio & Video
Problems with wiring schematic when replacing a factory stereo
Do you have the harness adaptors? it is best to use these rather than cutting harness. you can swap factory radio back in at later date and they will tell you the wiring ,if not i will try and locate the diagram for you
Dec 12, 2008 | Sony XR-C7350X Cassette Player
I have a CXSGT08HP sony car stereo. It was installed by a friend at home. The memory does not work. Can you tell me which wire is the memory wire and were i need to hook it up to?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hi Justtamera,
I’m attaching a wiring diagram which hopefully isreadable. I’ll also list the “where to”instructions for all of the other wires. It’simportant that several wiring steps be done in a particular order.
About the Memory Wire:
The memory wire is Yellow and should be connected to the +12 V power terminal (which isenergized at all times). First besure to connect the black ground (earth) lead to a metal surface of the car.
Important…
>>Before making connections, turn the stereo unit and carignition off to avoid short circuits.
>>Connect the yellow and red power input leads onlyafter all other leads have been connected.
>>The power antenna (aerial) control lead (blue)supplies +12 V DC when you turn on the tuner.
Hope this helps. Lemme know if you have more questions or would like me to email you acopy of the owner’s manual.
Thanks, and take care.
Gail :-)
Connecting the Sony CXS-GT08HP Car Stereo Unit
1. To a metal surface of the car
>First connect the black ground (earth) lead, thenconnect the yellow and red power supply leads.
2. To the power antenna (aerial) control lead orpower supply lead of antenna (aerial) booster amplifier
>Notes
>>It is not necessary to connect this lead if there isno power antenna (aerial) or antenna (aerial) booster, or with a manually-operatedtelescopic antenna (aerial).
>>When your car has a built-in FM/AM antenna (aerial)in the rear/side glass, see “Notes on the control and power supply leads.”
3. To AMP REMOTE IN of an optional power amplifier
>This connection is only for amplifiers. Connecting anyother system may damage the unit.
4. To the +12 V power terminal which isenergized in the accessory position of the ignition switch
>Notes
>>If there is no accessory position, connect to the+12 V power (battery) terminal which is energized at all times.
>>Be sure to connect the black ground (earth) lead toa metal surface of the car first.
5. To the +12 V power terminal which isenergized at all times
>Be sure to connect the black ground (earth) lead to ametal surface of the car first.
Important…
>>Before making connections, turn the car ignition offto avoid short circuits.
>>When your car has built-in FM/AM antenna (aerial) inthe rear/side glass, connect the power antenna (aerial) control lead (blue) or theaccessory power supply lead (red) to the power terminal of the existing antenna(aerial) booster. For details, consult your dealer.
>>A power antenna (aerial) without a relay box cannotbe used with this unit.
Nov 29, 2008 | Car Audio & Video
Radio not working
Have you made sure your power source has power?
Next check your inline fuse if it has one.
Make sure you do have a good ground.
If none of these solutions work you most likely have a bad system.
Feb 02, 2008 | Sony XR-CA370 Cassette Player
Sony XR-CA400 Cassette Player Logo
29 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
