I changed the LAN speed on my TZ210 from Auto detect to 1GB now nothing on the network. how do i fix that?
  • jason278 Nov 15, 2010
    i cannot get into the Sonicwall interface, if so thats the first thing i would have done.
    i need to get access to the interface.
  • 32,281 Answers
I suggest you change it back to Auto detect and let the computer decide the best speed. You network is cannot run at 1Gb, that is why it does not work.
Posted on Nov 15, 2010
  • 1 more comment
  • Chris Hingee
    Chris Hingee Nov 15, 2010
    To change the Sonsonic LAN settings -
    Go to Control panel - Network Connections and right click on your LAN connection and select Properties, then click configure on the Sonsonic LAN card then click on the Advance tab and select Link Speed
  • Chris Hingee
    To change the Sonsonic LAN settings - Go to Control panel - Network Connections and right click on your LAN connection and select Properties, then click configure on the Sonsonic LAN card then click on the Advance tab and select Link Speed
  • Chris Hingee
I can't get my LAN settings to automatically detect settings, box will not check.
Reset your proxy settings
Proxy servers, or proxies, act as intermediary servers between a Web browser and the Internet. According to Microsoft's website, proxies are mainly used by networks in companies to enhance the security and speed of their network connection.
Proxy servers can also be used to log Internet usage, mask the network address of a server or to apply global restrictions to a network.
Internet Explorer is set to automatically detect proxy servers by default.
You can reset the Internet Explorer proxy settings to their default settings from the "Internet Options" configuration.
I have found the easiest way to do this is to add the menu to the top of a webpage.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on tools option then from the drop down list Internet Options
Select the "Connections" tab, and click the "LAN Settings" button.
Delete the proxy server address and port from the "Proxy Server" settings and clear the "Use a proxy server for your LAN" check box.
Clear the check box beside the "Automatically detect settings" and "Use automatic configuration script" options in the "Automatic Configuration" section of the "LAN Settings" dialog window. Click "OK."
Click "Apply" and then "OK" to save these changes and close the "Internet Options" dialog window.
Close all Internet Explorer browser windows for these changes to take effect.
http://windows.microsoft.com/en-US/windows-vista/Change-proxy-settings-in-Internet-Explorer
Sep 12, 2013 | Computers & Internet
I have a Netgear DGN1000 Modem Router, and I currently have two PC connected via Ethernet cables. For one, the light is solid green, whereas the light for my laptop is flashing orange/red. I can still surf...
amber light means your only getting 10Mb speed. Your ethernet port could be going bad on the laptop. Go to control panel > Network Settings > right click Your Network (LAN) adapter, properties, click configure, advanced tab and make sure your link speed is set to "auto negotiate" or "auto detect"
Apr 02, 2012 | Computers & Internet
I have a D-link DGS-1005G. I have two computers connected and a printer. The D-Link is also connected via LAN. I can obtain internet connection to each computer with wireless and the printer will not...
Hi, you have to set up your printer as a device that can be communicated in your LAN by the two PCs.
To set up your printer properly in the LAN, you need to assign a fixed IP to this printer such that whenever it is switch on again, both PC still communicate to this printer without changing the new IP assigned to this printer.
You need to set up this fixed IP properly in your DLink router. For guidance please check this in your user manual of the Dlink. Please let me know any problem you may have again in future.
Aug 10, 2011 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Hi how a 1GB ethernet passthrough can connect to 10/100 base t network or switch port. pls answer. regards NR nayan.dhn@gmail.com
No, The 1Gb Ethernet Pass-Thru module does not auto negotiate and will not accept commands to operate at any uplink speed other than 1Gb.
Jan 18, 2011 | HP Bladesystem c-Class 1GB Ethernet...
My internet speed is too slow, it only recieve 10Mbps as i view it on Lan. how can i make it to 100Mpbs? By the way my internet is connected on built-in lan (through Motherboard) do i have to buy Lan card...
So from Network Connections, you right-click the LAN connection, select status, and it displays Speed: 10 Mbps ?
If you select the Properties button from that dialog, and then with network card showing, select the Configure button; and from the properties shown on the Advanced tab, select Link Speed & Duplex. The value should be Auto Detect. If the LAN is configured correctly for 100 Mbps, you should get it.
Mar 01, 2010 | EliteGroup ECS G31T-M Motherboard - Quad...
No network
if you are on a wifi zone it must be detected by your laptop if not maybe your network connection setting for detecting wifi is off. try changing the settings of your network connection. and change it to auto detect the network connections
Aug 10, 2009 | Sony VAIO GRZ610 Notebook
When I put my memory card into my computer-nothing happens. It has photos on it, but my computer is not automatically promping me
check whether u have installed USB controllers & drivers.
If nothing happens then do this. go to Start--> Run and type "devmgmt.msc" without quotes and enter. Then device manager will open , now connect ur memory card and look for scan for hardware changes menu . click that and scan . now u will find if any new hardware components are fixed to your computer or not. Then your memory card will be detected.
Aug 09, 2009 | Lexar Professional High-Speed 1GB Secure...
Cannot display web page
Click START.....ALL PROGRAMS.....ACCESSORIES.....COMMAND PROMPT
Click OK
Type ipconfig/flushdns then press Enter
Type ipconfig/release then press Enter
Type ipconfig/renew then press Enter
Close Command Prompt Window
Open Internet Explorer and click Tools.....Internet Options.....Connections.....Lan Settings
Then click...Auto Detect
If you're using Mozilla Firefox
Click Tools.....Options.....Advanced.....Network.....Settings
Click......Auto-Detect Proxy Settings
I this fails, then call Tech Support for your ISP.
Nate P.
Jan 06, 2009 | Dell Dimension 4600 PC Desktop
Switch port
switch setting
int f0/1
speed 100
dup full
and lan card shuld be shud be more then 100mbps or 1gb
then it will conect to full duplex means
u have to to any device shud have same duplex
Aug 11, 2007 | Cisco Catalyst 2950 24x10/100 Mbps...
Help with my wet11
Can you connect to the built-in Web server or configuration screen?
Aug 07, 2006 | Linksys Instant Wireless Wireless Ethernet...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
