How to connect Logitech 2.1 external speakers which has 3.5mm green color male pin to BenQ E2420HD monitor?
    Guru:
  • 406 Answers
You can connect the 3.5mm male pin at the left side of the monitor(if you're facing the front panel) it's located under the two USB ports( see "G" from the bottom Image). You may also use the line out port available( see "A" from the bottom image)
If you need the list of ports available you can take a look at the picture provided below:How to connect Logitech 2.1 external speakers - bourngenius_0.jpg
Hope this helps. Please check the manual for more info.
Posted on Nov 15, 2010
Testimonial: "Thanks a lot............ "
How to use USB ports in BenQ E2420HD monitor? Can I connect pen drive..........
The USB ports on the Benq monitor is a USB hub. Connect a USB cable from the USB port on the computer to the input USB port on the Benq.
Then you can connect any USB devices to the USB port on the Benq and the computer will see this device.
Nov 15, 2010 | Computers & Internet
Need a link for the directions on how to connect cables to the computer. serial #105255894
Connections
> Blue 15 pin or white 16 pin colour port is for monitor.
> 3 pin female port is for power cable for Computer Tower
>3 pin male power cable is for monitor
> Purple and green colour port is for Keyboard and mouse if they are ps2 (round connector) if usb then connect in any usb port.
>Small 3 colour ports Pink,Green,Blue is for sound.Connect only the Green colour cable coming from speaker to green port
>Connect the speaker Adapter cable to the wall socket for supplying power to speakers.
> RJ45 (Ehternet port-port which looks like phone connector but little bigger will connect Internet cable if you have internet.
Connect and Enjoy
Sep 08, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
Wanting to use tv as monitor with benq a52 v03 joybook
Yes, you need to press the key combination for your laptop to direct the video output through the external VGA port. It varies by laptop, but it usually involves the use of the Function (Fn) key and another key like F4...look for a picture of a screen in the same color as your function key.
Jun 15, 2009 | Computers & Internet
How to connect 5.1 speakers to a notebook
yes it will :) if it has 6 female ports (the normal 3 + 3 extra) it will work just fine :)
Jan 07, 2009 | Creative Labs Sound Blaster Live! 24-bit...
Identify cable & where to connect to get audio on HP w17e monitor
male mini-stereo to male mini-stereo
Plug into LIME GREEN port on computer.
Dec 28, 2008 | HP w17e Monitor
Monitor color problem
1. first cheak the display cable continuty.
a) 15 pin male connector 2nd pin bending . adj the pin
2. Dry points in neck board , solder the drypoints.
3. R G B amp transistor problem , or R G B Cromo IC problem,
4. neck base problem.
Nov 04, 2008 | LG Computers & Internet
Nonworking speakers
For your monitor with built in speakers, there should be a cable usually the plug is green in color, coming from the monitor which needs to be plugged to the back of the computer for the speakers to work. If you don't see a cable, then there is a plug on the monitor where a cable would go.
Yes you can connect external speakers. They plug into the back of the computer. There are usually round ports on the back colored blue, pink, and green. Figure: http://www.ultimatepcrepair.com/files/bsound.jpg (sometimes there is more, depending on your computer) The speaker cable plugs into the Green color one.
If you need more help just comment.
Aug 14, 2008 | Proview PS 776 Monitor
Colors reversed on samsung 2220vm
You got a loose connection on your VGA 15pin Socket. everytime the color signal got loose there is a invert video.or missing color signal.Possible cause in which terminals in a bad contacts with wires. preparably the RGB color signal, replace only the 15 pin male socket... which is pin 1 for Red pin 2 for Green pin 3 for Blue..
others pins just trace the signal.. don't worry its color coded.
Mar 03, 2008 | Computers & Internet
Computers & Internet Logo
248 people viewed this question
David Payne
David Payne
