Question about Samsung SyncMaster 740N 17" LCD Monitor
HI..I HAVE A SAMSUNG SYNCMASTER 225MW TV MONITOR BUT HAVING A WHITE LINES AT THE MIDDLE OF THE SCREEN AND POWER "ON PROBLEM". ANOTHER THING IS WHEN I PLUG IN THE POWER CORD THE POWER LIGHT JUST BLIND THEN SIMULTANEOUSLY OFF I "ON THE POWER" BUT NO RESPONSE AT ALL SOMETHING LIKE NO POWER. I JUST UNPLUG AND PLUG AGAIN THE POWER CORD AND THE POWER IS "ON" THE POWER BUTTONS AND ALL THE FUNCTIONS BUTTON ARE NOT FUNCTIONING. I JUST PLUG AND UNPLUG THE POWER CORD WHEN I OFF THE POWER.
4 Suggested Answers
  • 1684 Answers
SOURCE: power button lights, doesnt blink, but no other
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Aug 08, 2009
budmrtn
  • 11361 Answers
SOURCE: Describe your samsung syncmaster 204bw Problem: I
Check the power supply DC filter cpas first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 08, 2010
  • 1684 Answers
SOURCE: Hi, i have Samsung SyncMaster 225BW monitor and
A blinking power light on the Samsung 225BW usually indicates a failure in the power supply board. There are parts called capacitors that start to fail and this causes the power supply to keep restarting trying to stabilize the output voltages. If you can do a little soldering then you should be able to repair the unit yourself. Here is a link to a repair guide for the 225BW with pictures and a video showing how to dis-assemble the unit and repair the power supply board.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
There is also a parts list of the capacitors you need to get for the repair.
BuddyMc
Posted on Dec 27, 2011
How to fix white horizontal lines on middle of screen of a PC monitor?
Need to check removing LCD ribbon cable in the monitor. but it is may be a damage of LCD screen ,need to replace the lcd.but in very first check and service the lcd.
Feb 22, 2016 | Samsung Syncmaster S20b300b - Led Monitor...
SAMSUNG SYNCMASTER 226BW WHEN TURNING ON MONITOR, IT SHOWS BLACK AND WHITE LINES THEN IT SHOWES A BOX THAT SAYS "NOT OPTIMUM MODE, RECOMMENDED MODE 1680 x1050 60HZ " AND IT IS STUCK ON THIS...
hi dear
start your computer on safe mode and go to the display property change to as per mentioned rresolution on your screen.
best of luck
regards
raj
Sep 06, 2011 | Samsung Computers & Internet
I have a samsung syncmaster 940bw the other day while using it while surfing the web the screen went white and i cant seem to be get access to the menu on it
The screen went white can be due to failed T-CON board or failed power supply, I would inspect the power supply and the ribbon cable between the logic board and the LCD panel.
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
Aug 28, 2010 | Samsung Syncmaster 940BW LCD Monitor
Hi I Got a Samsung SyncMaster 920NW the display
If you are saying that it powers off in a few seconds you most probably have a bad (internal) power supply.
Jul 12, 2010 | Samsung SyncMaster 920NW Monitor
A problem on my screen
It happens due to two cause first one is you have any power saver, speaker or any magmatic device near your monitor(screen) and other cause is your monitor going to damage. Please do not keep any things near monitor and check it. I hope it will work fine.
Good luck.
Thank you
Sachidanand
Aug 19, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
User manual needed or factory reset for my Samsung SyncMaster 225MW LS22CRASB
You can download the manual from :-
http://www.nodevice.com/user_manual/samsung/monitors1/syncmaster.html
Thanks.
Jun 18, 2009 | Televison & Video
SYNCMASTER 753S
I would say your monitor is toast. However, you could test this theory by hooking up another monitor to it and see if it does the same thing.
Mar 25, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung syncmaster 204b
Yes. There is no vertical deflection. The circuit that controls vertical deflection is bad. This is an easy fix for a TV tech. Take it to the TV repair shop.
Dec 14, 2006 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
196 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
