Question about Uniden Tru-Digital Expansion Waterproof Handset with Caller ID Phone
Adding speed dial nos to uniden waterproof handset
Hello, I am helping a friend to put speed dial nos into his phone.. He has a Uniden system with an additional water proof hand set
. I was able to set up the handset with the answering machine but he has misplaced the book for the waterproof hand set.
Is it possible to add the numbers to the waterproof handset .. as this is the one he primarily uses?
Am I able to down load the instructions?
Thankyou
Mark
I found the model no, on the Uniden website DSS 7805WP and down loaded the manual.. there were no instructions .. but i showed where the phone book icon was .. and once inside the phone book the process was the same as the handset that came with the answering machine.
Posted on Jun 19, 2008
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Uniden DECT 1580-4WXT waterproof unit appears to be dead - will not charge or register with base unit. Just bought system at Sam's Club 2 days ago. The other 3 units work fine.
This phone uses inductive charging because of the waterproof feature. I suggest that you remove the
battery cover from the back of the handset, unplug
the battery, and then plug it back into the handset.
This solution worked for me.
Jun 21, 2010 | Uniden DECT 6.0 Cordless Telephone...
I have a Uniden DECT 6.0 phone set. I damaged one
On the base, open the menu and select Register Handset. The display should say Handset Registering.
On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
1.
2.
DSL filterTelephone cordTelephone wall jack
45
In about 30 seconds, the handset display should say Registration Complete. Press Talk/fl ash and make sure you get a dial tone.
If...
Try...
you don't hear a dial tone
the display says Registration Failed --
Making sure the handset is fully charged, then start over at step 1.
Sep 07, 2009 | Uniden DECT 6.0 Cordless Telephone...
Uniden 1725 no dial tone
I had the same problem as long as they are plugged in correctly and you put the #2 handset into the #1 cradle to register it to your base then try hanging the phone up several times. These are expandable phones so that I believe you can keep adding other handsets. So sometimes they think you have a few more handsets than you really have so when you hang up it may not know what handset you are hanging up #1 #2 or #3 #4 etc. So I had to keep hanging them up until it finally hung up. Then I had to re install them so it knew I only had 2 hand sets. So then you start from the beginning, like when you took it from the packaging. I hate these phones. I ended up replacing them with different ones. Plus I always keep a rotery phone laying around put away because during a power outage you still can plug in an old dial phone and it will work! Nothing like old technology.
Feb 15, 2009 | Uniden 5.8GHz Dual Cordless Phone
How do you register a waterproof phone (TWX977) to a TRS9585
Not sure if you still have this problem, but...
Basically go on you base unit, and hit "MENU/SELECT". Scroll down to "REGISTER HANDSET" and click "MENU/SELECT". On your waterproof handset, hold the "#" key until it displays "REGISTERING HANDSET". And voila! After that finishes, your waterproof handset will be good to go!
Feb 03, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
I want to change speed dial nos. don't have manual for instructio
You should be able to download the appropriate manual from
http://uniden.com/index/manuals_results.cfm
Jan 07, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
Uniden power max 5.8 speed dial
Press and hold a number key (0-9) associated with the speed dial until the phone number appears, and then press talk/flash or speaker on the handset or speaker on the base. The number stored in the speed dial is dialed.
Sep 22, 2008 | Uniden 5.8GHz Dual Cordless Phone
Speed dial on uniden
When the phone is not in use, press and hold the number key (0-9) that is assigned to the phonebook entry. Press flash on the handset to dial the number.
Apr 23, 2008 | Uniden DCT756-3 Phone
Uniden Tru-Digital Expansion Waterproof Handset with Caller ID Phone Logo
175 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
