Question about Hitachi ( 0A30229-20pk) 400 GB Hard Drive
I have a hitachi 500gb portable simpledrive and i have already connected both the usb cables to 2 different usb ports and the other end to the drive. it is still not detected. im using an old computer, athlon xp with only usb 1.0 so what i did was buy a usb 2.0 - 1394 ieee pci combo card for this computer to have a usb 2.0
    Brigadier General:
  • 10,406 Answers
Can you try connecting it to a different computer?
If it still does not work, then you have a "hardware" problem.
Remove the disk-drive from the enclosure, and temporarily attach it as a "slave" disk-drive in a desktop computer, to see if bypassing the USB-to-disk-drive interface will bypass the problem.
Posted on Nov 15, 2010
My Hitachi Simpledrive 500gb won't be seen by my pc & the led is flashing, could you please let me know what I can do?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jul 06, 2012 | SimpleTech by Hitachi SimpleDrive 500GB,...
My hitachi external hard drive wont connect to my mac laptop
You might try a different cable if you haven't already. Make sure the cable is short, less than 18", or it will not power up properly. Another thing to check is to make sure the computer's Energy Preferences settings are optimized for performance, not battery life, so that the computer can supply enough power for the drive. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Jan 30, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
I bought a hitachi external hard drive for mac, 250 g. when i first used it it took a long time for it to be recognized. On pc it works fine, but on my mac it won't get recognized anymore. (the hard drive...
Your problem could be any one of these issues:
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Jan 01, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
Hitachi 250GB external drive not being recognized by desk top or laptop? Any suggestions?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 23, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
I have several computers at home, and none og them can recognize this portable device. Hitachi 250 GB Mod: SDM/250RW
1) Power:
It may be the problem that occurs with a lot of USB powered devices jrherrer. Not enough power provided.
The USB cable plugged into the computer, provides signal wires for transferring information back, and forth, and also provides 5 Volts DC for power. (Two D cell flashlight batteries produce 3 Volts DC)
http://en.wikipedia.org/wiki/USB
[ Below shows the Signal pins, and the Voltage pins of the USB B Mini style connector, (Male), used to connect to the SimpleDrive Mini external harddrive,
Pin 1 is for the 5 Volts DC Positive (Wire color - Red)
Pin 2 is for the D- Signal (Wire color - White)
Pin 3 is for the D+ Signal (Wire color - Green)
Pin 4 is not connected. (Or sometimes joined to Pin 5 with a Resistor)
Pin 5 is for the Ground (Wire color - Black)
Just added info in case you wanted to know ]
From what I see the SDM/250RW has a USB port on the side, and a DC Power Jack, used for an AC adapter, also.
(Round port with a pin in the center)
http://www.hitachigst.com/tech/techlib.nsf/techdocs/0C876B7AB91B23988825773F006BEA02/$file/SD_Mini_DS_final.pdf
From what I see stated from Hitachi, and sellers on the 'net, the AC adapter may not be provided.
Many of those who provide a review state that both the USB cable, and the AC adapter is needed to provide enough power. Seems to be a power hungry external harddrive
It's a 2.5 Hitachi SATA laptop harddrive inside that external case. (The Harddrive is 2 and a half inches across in Width. Common size used for laptops)
When using an external device powered by a USB cable there are general guidelines to follow,
A) The USB cable should not be more than 2 feet in length
B) Connect the device directly to your computer, instead of through a hub, or other device, unless the USB hub has it's own power.
2) USB cable:
Could be a faulty USB cable, although I imagine you have tried different ones by now.
3) Interface Circuit Board:
The Hitachi SATA 2.5 harddrive inside the SImpleDrive Mini SDM/250RW, plugs into a small circuit board located inside that external case.
Components on the circuit board may be fried, or the Harddrive may have come loose from the interface.
Loose from the interface
To explain;
The back of the harddrive has connector pins sticking out.
The interface has socket holes which the pins insert into.
Faulty circuit board
The external case of the SimpleDrive Mini SDM/250RW can be carefully opened up, and the Hitachi SATA 2.5 harddrive extracted out.
Another inexpensive external case for a 2.5 SATA harddrive can be procured, and the Hitachi harddrive put in it.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2781
Nov 22, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Have new drive Hitachi SimpleDrive Mini 250GB USB 2.0 Portable External Hard Drive SDM/250RW (Red Wine) and works fine on Dell precision M4300 laptop Vista OS with either one or two usb plugs (so no extra...
Most USB hard drives require an external (or secondary) power cable to power the devices when connected to laptop or netbook computers. In some cases, even older desktop computer models will require a similar cable.
This is due to the specifications for the USB standard as it dictates the amount of voltage that a USB port can deliver. Some USB ports are considered "powered" and are sometimes identified by the USB logo and a small "+" sign to indicate the added voltage.
Note: Not all manufacturers use this logo, so if your computer doesn't have this variation of the logo, it doesn't necessarily mean the USB port is not powered.
This added voltage supplies additional current to power smaller devices, such as portable (or 2.5") USB hard drives. However, in the even that the USB port is not powered, then only the minimum amount of current is supplied. This should be enough to slightly power the drive, but not sustain it, thus causing the clicking noise and there isn't enough current running through to move the arm that reads the data on the hard drive.
Chances are that the USB ports on your Asus Eee are not powered and won't allow your hard drive to run until either a secondary cable is purchased or if you use a powered USB hub instead.
The secondary cable looks a lot like a Y-USB cable with one end that connects to your hard drive and the other end consisting of 2 USB plugs that both connect to existing USB ports on your netbook. Between the 2 USB ports, they can draw enough current to power the hard drive - the downside being that if you only have 1 USB port you cannot utilize the cable or if you have 2, they will both be occupying the ports while the hard drive is in use. These cables can cost about $1-7 depending on brand and can be found online in retailers such as eBay & CompUSA.
The USB powered Hub is a more expensive solution, ranging at about $10-25, but is the higher recommended of the 2 solutions since it will provide its own power supply to the tiny device, will use on 1 of your USB ports and since it's a hub, they usually have anywhere from 3-5 additional USB ports (all powered) for you to use, if needed. Some even include built-in memory card readers and they do not require any additional drivers or software to install and can work on any desktop/laptop/netbook.
Aug 14, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
External Drive won't power on
Actually the simpletech dosent need power adapters so u dont need to check for adapters and if you are connecting to usb2 port the power should be embaded so just connect the single usb cable not the both if using usb 1 then connect the both usb cable to usb port if u have already done this please try to change the usb cables wich is connecting the hdd and the pc something wrog in the cable for sure
thanks
Jun 01, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Hitachi ( 0A30229-20pk) 400 GB Hard Drive Logo
75 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
