My Goodman gmp 135 heating unit wont flash up
3 Suggested Answers
  • 189 Answers
SOURCE: my goodman furnace (model gmp
All of the burners should light. Could be a dirty flame runner. I recommend that you get a good clean and check.. Burners, flame runner, flame sensor should all be cleaned. If this does not solve your problem than the gas pressure needs to be checked.
Good luck....
Posted on Apr 03, 2009
shastalaker7
  • 1515 Answers
SOURCE: Units heating elements wont shut off regardless of
Hi, you will need to replace this thermostat as the circuitry is faulty and keeping the strips energized. The only way to check would be to pull cover from stat and expose stat wires. Power off first. Disconnect the 24 volt hot wire, red and they should shut right off. If so get a new stat. If you need further help, please contact me. Merry Christmas.
Shastalaker7
Posted on Dec 24, 2009
How to clean goodman gmp 050-30 flame sensor
most flame sensors can be cleaned with sand paper
Nov 20, 2016 | Goodman Heating & Cooling
We need to change the heat exchanger for my Goodman Heat Furnace model no.-GMP 075-3
Not an easy task! Take many pictures as well as draw out and mark which wire went where. You will have to remove everything from inside the cabinet to get to the heat exchanger. It may be easier to replace the furnace. If you are paying a professional to do the exchange, figure three hours if they have done it before, if not figure 5 to 6.
Apr 02, 2011 | Goodman Heating & Cooling
How to change fan speed on a goodman gmp 100-3 furnace
Usually you can find the control board on the lower part of the furnace. Turn the power off and remove the
doors. This board is usually located directly in front of the blower motor.
On the control board locate the terminals marked heat/cool/park and Park Lets say the Heat Terminal
has a red wire attached to it and you want a higher
speed.
Red is uasually low speed, remover the red wire from
heat terminal and exchange it with a wire attached to
a terminal lab eled park. Black is usually high spped
Jan 01, 2010 | Goodman GMS90703BXA Heater
I have a goodman GMP 125-5 furnace. I have
sounds like the primary limit typically behind the gas valve its larger then the others, rectangle in shape with 2 wires going to it. be careful if your bypassing limit this can create a very hazardous condition
Nov 06, 2009 | Goodman GDS80904BNA Open Flame Heater
My gmp series heater comes on for 30 seconds to purge exhaust and goes off for 2 seconds and starts over red light flashes constantly gas valve never opens igniter doesnt heat up
Sounds to me like your pressure switch is bad or the hose has a hole in it. If the pressure switch does not close, the unit will start. It will try again until it goes into lock out. normaly three times.
Oct 13, 2009 | Goodman Heating & Cooling
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
