Question about Sony KP-51HW40 51" Rear Projection Television
Sony projection TV Model KP - EF61MN2 Picture is not clear.
  • 135 Answers
SOURCE: sony widescreen projection TV -- Model KP-51WS510
The tv is in shutdown protection due to overdriving video signal. If you are handy you can pull the front cover off and there are 6 controls on a HV block. 1 set says focus, do not touch those. One set says screen. One at a time turn them down, counter clock wise putting each one back where you found itTurn the first one down and then turn the set on. Do this for each untill you get a picture. You will most likely find a bad blue gun. You can also remove the board from each gun 1 at a time with the set unplugged and find the shorted gun. good luck.
Posted on May 25, 2009
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
greenspan
  • 1734 Answers
SOURCE: Sony projection Tv KP-65XBR10W has no picture or sound
Looks to me as an serious (but not uncommon) PSP board problem with Panasonic plasmas. Contact a Panasonic service center.
What problems have people had with quality control on these displays? Are they covered under warranty?
  1. Certain displays emitted an extremely loud buzz. This was covered by warranty repair.
  2. Certain displays had a problem with the Y/C delay on their S-video input. This was also correctable.
  3. One person reported red vertical lines on his display.Was this covered by warranty? Was it an input problem or a pixelproblem?
  4. Afew bad pixels here and there are not covered underwarranty. Largeclusters are generally covered. It's up to Panasonic'sdiscretion. Onthe plus side, however, bad pixels are becomingincreasingly rare. Mostpeople are reporting no bad pixels at all!
CALIBRATINGWhat needs to be calibrated on a plasma?
You needto calibrate most of the same things that need to be calibratedonother displays. About the only things that don't need to be doneareconvergence and geometry. You can usually tinker with picture sizeandposition, but there's no need to deal with keystone orpincushionadjustments, etc.What is white level? What is black level?How are they adjusted?
Theadjustment for white level is usuallylabeled "Picture" (as onPanasonics) or "Contrast". "Brightness", on theother hand, refers tothe black level. Yes, this is apallinglycounterintuitive. This FAQuses the terms "white level" and "blacklevel", since they betterdescribe what you're actually adjusting, andthey're the terms used byAvia and Video Essentials.
How do I adjust hue and saturation?
In anothermysterious choice of terms, hue is controlled by the "Tint"setting,and saturation is controlled by the "Color" setting. This FAQuses theterms "hue" and "saturation", since they're the terms used byAvia andVideo Essentials.
How do I set the white level on a plasma?
Youset the white level by adjusting the "Picture" setting. You willneedto use a different test pattern than you would for a CRT. Forbothplasma displays and LCD displays, you should use the 10 IREgrayscalestep pattern. There are two criteria you want to match on yourplasma.
First,you need to make sure the white level is low enoughthat your displayisn't thresholding (or clamping) bright levels. Youshould set thewhite level low enough that you can see each of the 10IRE stepsdistinctly. The Panasonics seem not to exhibit clamping (in mylimitedexperience), even at factory defaults, so this criterion may notbeterribly useful.
Second, for the health of your display (e.g.to avoid burn-in), you should turn down the white level. Just becauseyour display can display blindingly bright pictures doesn't mean that it should.Plasma displays should be set between 21 fl and 25 fl light output; thePanasonics comeout of the factory at about 30 fl. On one ISF-calibratedPanasonic, 23fl was roughly equivalent to a Picture setting of -20 (inthe usermenu, not the service menu). To set this precisely you'll needto bringin a calibration specialist, but you can do a lot of good byjustdialing down the white level a lot. After seeing the display at 30fl,23 fl will see very dim. But after a while, you'll find that 23 flisplenty bright.
How do I set the black level on a plasma?
Youset the black level by adjusting the "Brightness" setting. You canusethe same test pattern you would use for any other display.
How do I calibrate grayscale (calibrate the color temperature)?
Unfortunately,this is one you can't do yourself. You need specialequipment tomeasure the color. In fact, most ISF technicians lack theequipmentspecific to plasma calibration (a $15K gadget known asaspectroradiometer). But even the standard color measurementequipment(which calibrationists do have) will do a great job.
Thatsaid, one person who had his Panasonic display calibrated by anISFspecialist said that the Cinema / Warm setting was reasonably closeto6500K out of the box. Using that setting is probably the best you'lldoon your own.
If you're really determined to screw up yourdisplay,the RGB drive and cutoff settings in the service menu are usedto adjustthe color temperature.
How do I adjust the color decoder?
Thereareseveral issues here. Generally speaking, the Panasonic decoder seemstopush blue a bit. The R-Y Axis Angle and B-Y Axis Gain in theservicemenu are used to correct this behavior.
There used to beaproblem on some Panasonics with the Y/C delay on the S-video input.Seethe Quality Control section for more information.
How do I adjust the gamma?
On the industrialmodel, there is a set of Advanced picture settings. Goto the Picturemenu, turn Advanced on, and then hit the down-arrow. Inthe subsequentmenu you can adjust quite a few parameters, includingselect from a fewgamma settings.
This advanced menu appears to be missing from the consumer model.
How do I calibrate my consumer model given these missing menus?
Thereis apparently a way to activate these menus. Perhaps you can findacalibrationist or Panasonic technician would can turn them onlongenough to do the calibration.
What's the overall calibration procedure?
In general, the order Avia sets out is the correct one. A more complete list is:
  1. White level (picture)
  2. Black level (brightness)
  3. Repeat (1) and (2) until you have a good balance.
  4. Grayscale (requires special hardware and mucking about in the service menu)
  5. Sharpness
  6. Hue and Saturation (tint and color)
  7. Color decoder (requires use of the service menu)
  8. Repeat (6) and (7) for red and green until you have a good balance.
SERVICE MENUHow do I access the service menu?
In a word, don't. See the service menu warningabove.If you're bound and determined to make use of the service menu,buy theservice manual. It contains more than enough information foryou to ruinyour display and/or kill yourself.
Posted on Aug 18, 2009
johnnydiode
  • 647 Answers
SOURCE: Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Posted on Oct 24, 2009
Testimonial: "Many thanks to johnnydiode and all the others on this site sharing their knowledge and providing a valuable service."
raklein62
  • 360 Answers
SOURCE: tv wont come on and a red light is blinking
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Posted on Oct 25, 2009
Sir Myself Raj, My Sony Tv Projection Model is kp
Sir Myself Raj, My Sony Tv Projection Model is kp -es53me1. We are using this tv since 8 years. Now recently we are facing a problem with it. The problem is, The Picture quality is not good. Total screen & pictures are appearing as blur. Would you please give the solution for this?
Oct 10, 2013 | Televison & Video
Sony wega model#kp-46wt520 rear projection hdtv lamp
It uses 3 picture tubes which due to the age of the set are no longer available.
May 05, 2012 | Sony KP-46WT520 46" Rear Projection...
I have a Sony KP-53VP0 Rear Projection TV Kinda Cloudy Picture.
take off the back of the tv and clean the lenses and the foggy picture will go away
Jan 14, 2010 | Sony KP-53V90 53" Rear Projection...
Sony model KP-53V80 wont show picture or sound
YOU LOST VERTICAL DEFLECTION THIS WILL REQUIRE PARTS REPLACEMENT
Dec 25, 2009 | Sony KP-53V80 53" Rear Projection...
No image on sony rear projection tv (model KP-53V35) for 20 minut
sony has a circuit than balances the 3 crt's. it needs a screen adjustment which is located in the front of tv behind speaker grill. easy repair
Oct 22, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony projection tv picture real bright and not clear
This sounds like your flyback on the D-Board of your tv is going out (The part is around $70.00) and available at www.Sears.com the parts dept have make and model ready ( This is a very common problem with this model of sony tvs) Have a pro do it HIGH VOLTAGE! Please rate in order to keep this site free
Thank you!
Dec 14, 2008 | Sony KP-53HS20 TV
I need a blue picture tube re-necked / rebuilt
Go to the following link and leave your model number in a email and list which tube you need, they have access to just about any new replacement tube that you need for Sonys. they dont list them all, but leave a email I am sure they will have what you need.Heres the link.
http://servicemanuals.vstore.ca/
Aug 09, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony kp-65xbr10w led light blinks 5 times
i have a sony tv model kv36fs17. led flashes 5 times. tv works but no red color. would could be the problem? thanks
Jan 23, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
