Question about HP LaserJet CM1312 All-In-One Printer
I have CM1312 mfp HP printer, During printer updating i had an error. After restart printer shows :Corrupted firmware Ready 2 download" I uninstalled printer, installed new one (with same usb port - corrupted firmware printer popped as unknow device) Im running fw updater, after it send all to printer, im turning printer on, its shows Downloading(done) after that Erasing...(and its stackin on it) it always stackin at Erasing and wont let me go further.
3 Suggested Answers
  • 123 Answers
SOURCE: HP laser jet 1522nf mfp ( firm ware corrupt ready 2 download)
Perform the following troubleshooting in the order listed:
  1. Turn off the printer, with the communication cable still attached.
  2. Clear the print spooler by doing the following:
    1. Go to Start then choose Run .
    2. Type net stop spooler , and press Enter .
    3. The Windows XP spool directory is located at: C:\WINDOWS\SYSTEM32\SPOOL\PRINTER ; Delete every file within this folder.
    4. Go to Start , then Run , and type net start spooler , and press Enter .
  3. Manually delete and reinstall the driver:
  4. To uninstall printer driver, refer to the following steps:
    1. Open Printers folder and right click the driver that you wish to delete.
    2. Within the menu, select Remove .
    3. For the confirmation message displayed, click Yes .
    4. Right click the Printer Folder and select Server Property .
    5. Click Drivers tab, and select the driver for deletion. Click Remove .
    6. For the confirmation message for the deletion, click Yes .
  5. Install the printer driver manually as follows:
    1. Select the Printers and Faxes option from the Start menu.
    2. Click "Add a printer" then, on the resulting "Add Printer Wizard" dialog, click Next.
    3. Ensure the option "Local printer attached to this computer" is selected. Untick the checkbox "Automatically detect and install my Plug and Play printer". Click Next.
    4. Ensure that the option "Use the following port:" is selected then select the appropriate port from the drop-down choice box. When choosing port, use one of Virtual Printer Ports for USB to which is your printer connected to. Click Next.
    5. Click the "Have Disk..." button. On the "Install From Disk" dialog, click Browse... then navigate to the appropriate directory to which the software/driver extracted.
    6. Select an inf file then click the "Open" button. Click OK on the "Install From Disk" dialog.
    The Add Printer Wizard will start to copy driver files to the PC.
  6. Run the firmware upgrade with the printer turned off so that the printer accepts the firmware only after the entire file is spooled.
  7. In the firmware update program's window, choose your printer (manually installed) and press Send Firmware button, and wait for the firmware to be spooled completely.
  8. Power-on the printer.
  9. During the printer firmware update, the liquid crystal display (LCD) on the printer control panel will display Printing Document and will change to Erasing . After a short while, the LCD display will change to Programming . After a short while, the LCD will display complete The Ready LED on the printer will start flashing. The printer will automatically power off and then back on to reboot, and will make noises similar to that of a power-on operation.
Posted on Jul 14, 2010
tballone
  • 126 Answers
SOURCE: hp clj cm1312 mfp firmware
You will need to apply the firmware to the machine. I've attached the link to hp site for you to download the firmware file as well. Below the link is the directions on how to accomplish this, as well you can see the same directions on via the link provided
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3558902&prodNameId=3558903&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=t2-85206-1
Firmware Update Notes:
  1. The Firmware Update Utility uses the USB connection to the printer.
  2. The HP Color LaserJet CM1312 MFP print driver software must be installed prior to using this utility.
  3. The HP Color LaserJet CM1312 MFP printer must be on and in a READY state as shown by the LCD display on the control panel and remain powered on during the entire firmware update process.
  4. Depending on the processor speed of your PC, the firmware update process may complete on the printer before the update status progress bar in the flash firmware update utility on the PC screen completes, this is normal.
  5. Once the update process has started, do not use your PC for any other activity until the process is complete.
  6. Do not power cycle the product or the PC until the firmware update process is complete.
Process:
  1. Download the flash firmware updater file from HP.com to the PC desktop.
  2. Turn the printer off and then back on to clear main printer memory.
  3. Double click on the file CM1312_MFP_Series_FW_Update-20100616.exe flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate CM1312 MFP driver in the dialog window. If you assigned a different name to the HP CM1312 MFP, choose the name that represents the correct printer.
  5. Click on "Send Firmware" when ready to proceed.
  6. The progress bar will begin to move to the right indicating information being transferred.
  7. DO NOT power cycle the product or the PC during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Printing Document - Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  9. At the conclusion of the firmware update, the dialog window will show a smiley face. Click on exit.
  10. If it is desired to verify the update, use the control panel reports menu under setup to print a configuration report. The configuration report will show the current firmware revision in the Product information block, Firmware Datecode: 20100616
Posted on Oct 20, 2010
Hp color laserjet cm1017 mfp 49 service error showing in disply screen and restart the printer
Aug 15, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
Printer displays "ready 2 download"
No download, dont do it.
Printer
wants to update the firmware,
unless you want to use original cartridges forever.
Jul 04, 2011 | HP Laserjet CM 1312NFI Color Printer
Hp cm1312nfi printer problem error ready to download
The error is due to corrupt firmware and you need to reinstall it.
HP CM1312NFI Firmware Download & Instructions
Please visit the above link and Download the firmware.
"The HP Easy Firmware Upgrade utility provides the HP MFP firmware .rfu bundle and a user friendly method to transfer the .rfu file to the MFP all contained in a self-extracting executable for the Windows operating systems"
Please visit the above link and read all the instructions/ details and upgrade the firmware.
Process:
  3. Double click on the flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate MFP in the dialog window. If you assigned a different name to the HP MFP, choose the name that represents the correct printer.
  7. DO NOT power cycle the product or the pc during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  10. The flash firmware update process is complete.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 09, 2011 | HP LaserJet CM1312 All-In-One Printer
HP M2727nf laserjet.Firmware courrpt on display .printer locked up
HP M2727NFFirmware & Instructions
Extract of the instructions for Firmware Update from Hp Official Site is as under: -
Process:
  3. Double click on the M1522_MFP_Series_FW_Update-20100902.exe. An HP firmware update window will open.
  11. If it is desired to verify the update, use the control panel reports menu under setup to print a configuration report. The configuration report will show the current firmware revision in the Product information block, Firmware Datecode: 20100902.
CreativeTECH
Jun 03, 2011 | HP Office Equipment & Supplies
We have a M2727 Laserjet Printer/Fax . We can print, and we can receive fax, but our problem is sending a FAX.. Keeps giving us an error code of 49. Please advise Thank-You, Marla
I found this on the HP website:
HP LaserJet M2727 Multifunction Printer Series - 49 Error Message Is Displayed While Faxing ISSUE: The printer control panel will be displaying 49 service error while sending faxes. The receiving fax will be lost, and the printer will display the same error even after reboot. SOLUTION: Performing a factory reset and a firmware upgrade is the only solution for this issue. Step 1: Performing a factory reset Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number. CAUTION: This procedure clears fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product. Perform the following steps to restore the factory-set defaults: 1. On the product control panel, press Setup . 2. Use the arrow buttons to select Service , and then press OK . 3. Use the arrow buttons to select Restore defaults , and then press OK . The product automatically restarts. Step 2: Firmware upgrade After coming to ready, upgrade the printer firmware from the HP website. The issue can be fixed with any of the firmware upgrade available now. Firmware version 20080505 and higher versions have the fix. You can download firmware version 20080612 from the HP LaserJet M2727 Firmware Update 20080612 webpage. Click here to go to the HP LaserJet M2727 Firmware Update 20080612 webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3377075&swItem=ma-55531-3&prodNameId=3377076&swEnvOID=228&swLang=8&taskId=135&mode=4&idx=3) . The preceding steps will resolve the issue.
Mar 07, 2011 | HP Office Equipment & Supplies
My printer is stuck in "Ready 2 download" mode.
You get that error when you are trying to upload the firmware and the printer power was interrupted.
1. Close the firmware update tool on the computer if it is still active on the screen, and then turn off the product. 2. If the product is on a network, connect a USB cable (2 meters or less) from the product to an open port on the computer. HP recommends that this be a direct connection instead of through a hub. 3. Turn on the product, and then wait for the message ready 2 Download to appear. 4. On the computer, cancel any alerts about a new device being connected. 5. On the computer, open the Printers and Faxes control panel. 6. Right-click the printer driver for the product model that is being updated, and then click Properties. 7. In the Properties dialog box, click the Ports tab. 8. Note the name of the port that the product is currently connected to for use later when reconnecting at the end of this process. 9. Click the check box next to USB001. If USB001 is already connected to another USB device, click USBXXX where "XXX" is the highest-numbered USB device that has a description of "Virtual printer port for USB". Using the scroll bars on the right side of the window might be necessary, depending on the number of devices installed. 10. Click OK to accept the change and apply the settings. 11. Restart the firmware update tool on the computer, and then select the same product that was just created. 12. Start the firmware download. 13. Verify that the control panel display shows Erasing and then Programming, indicating that the update process has begun. Do not interrupt the firmware update process. 14. The product should momentarily show the message Complete. Turn the product off and then back on. The product will not automatically reboot. 15. When the product reboots, on the computer, cancel any alerts about a new device being connected. 16. Print a configuration page to verify that the update occurred. 17. Return to the Printers and Faxes dialog box, right-click the printer driver for the product model that
is being updated, and then click Properties 18. In the Properties dialog box, click the Ports tab. 19. Click the check box next to the previous port to which the product was connected before the update began.
Nov 07, 2010 | HP LaserJet CM1312 All-In-One Printer
Hp clj cm1312 mfp firmware corrupt ready 2 download, What to me to do? Help, please
Process:
Oct 20, 2010 | HP LaserJet CM1312 All-In-One Printer
49 2f81- error
From the service manual:
A critical firmware error has occurred. This type of error can be caused by invalid print commands, corrupt data, or invalid
operations. In some instances, electrical noise in the cable can corrupt data during transmission to the MFP. Other causes include poor quality parallel cables, poor connections, or specific software programs.
To fix:
1 Turn the MFP off, and then turn the
MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs, disconnect all of the cables that
connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
To upgrade firmware:
The MFP has remote firmware update (RFU) capability. Use the information in this section to upgrade the MFP firmware. The overall process involves the following steps:
1 Determine the current level of firmware that is installed on the MFP.
2 Go to the HP Web site and find out whether a firmware update is available. If an update is available, download the latest firmware to your computer.
3 Transfer the new firmware from your computer to the MFP.
Determining the current level of firmware
To determine the current level of firmware, view the configuration information on the MFP control panel. To view the configuration information, follow these instructions.
1 Press MENU.
2 Touch INFORMATION.
3 Touch PRINT CONFIGURATION. The configuration page prints.
4 The firmware datecode is listed in the section called Device Information. The firmware datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
Downloading the new firmware from the HP Web site
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software. This page provides instructions for downloading the new firmware version.
Transferring the new firmware to the MFP
This procedure requires that you install HP Web Jetadmin Version 7.0 or later on the computer. See Using HP Web Jetadmin software. Complete the following steps to update a single device through HP Web Jetadmin after downloading the .RFU file from the HP Web site.
1 Start HP Web Jetadmin.
2 Open the Device Management folder in the drop-down list in the Navigation panel. Navigate to the Device Lists folder.
3 Expand the Device Lists folder and select All Devices. Locate the MFP in the list of devices, and then click to select it.
If you need to upgrade the firmware for multiple HP LaserJet 4345mfps, select all of them by pressing the Ctrl key as you click the name of each MFP.
4 Locate the drop-down box for Device Tools in the upper-right corner of the window. Select Update Printer Firmware from the action list.
5 If the name of the .RFU file is not listed in the All Available images box, click Browse in the Upload New Firmware Image dialog box and navigate to the location of the .RFU file that you
downloaded from the Web at the start of this procedure. If the filename is listed, select it.
6 Click Upload to move the .RFU file from your hard drive to the HP Web Jetadmin server. After the upload is complete, the browser window refreshes.
7 Select the .RFU file from the Printer Firmware Update drop-down menu.
8 Click Update Firmware. HP Web Jetadmin sends the selected .RFU file to the MFP. The control panel shows messages that indicate the progress of the upgrade. At the end of the upgrade
process, the control panel shows the Ready message.
HP Web Jetadmin is a Web-based software solution for remotely installing, monitoring, and troubleshooting network-connected peripherals. The intuitive browser interface simplifies crossplatform
management of a wide range of devices, including HP and non-HP printers. Management is proactive, allowing network administrators the ability to resolve printer issues before users are affected. Download this free, enhanced-management software at www.hp.com/go/webjetadmin_software.
To obtain plug-ins to HP Web Jetadmin, click plug-ins, and then click the download link that is next to the name of the plug-in that you want. The HP Web Jetadmin software can automatically notify
you when new plug-ins are available. On the Product Update page, follow the directions to automatically connect to the HP Web site.
If installed on a host server, HP Web Jetadmin is available to any client through a supported Web browser, such as Microsoft Internet Explorer 6.0 for Windows or Netscape Navigator 7.1 for Linux. Browse to the HP Web Jetadmin host.
Replacing the formatter
1 Slide the formatter cover toward the left side of the MFP and remove it.
2 Remove two thumb screws (callout 1).
3 Slide the formatter toward the left side of the MFP, and then remove it.
NOTE Dislodging the formatter might require considerable force.
I hope all this information helps! Thanks and please take a moment to give this solution a rating of fixya.
Feb 17, 2009 | HP LaserJet 4345mfp Printer
Error messsage on HP M1522nf MFP "firmware corrupt ready 2 download".... how do i fix this?
1. install M1522nf printer driver PCL5 to any usb port. 2. download latest firmware from www.hp.com 3. run firmware utility and select installed printer from drop down menu.
Sep 07, 2008 | HP Office Equipment & Supplies
HP LaserJet CM1312 All-In-One Printer Logo
189 people viewed this question
Seeker5211
Seeker5211
