Question about ASUS (SL1000) Router
I am getting ip conflict when i try to connect my laptop is new dell ispiron
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 144 Answers
This should be easy to fix. On all your computers, go into Control Panel > Network Connections. Right click your wireless connection, and goto properties. Open TCP/IP properties, and make sure everything is set to automatic, NOT static.
Reboot them all (and probably the router too) and you should be fine :)
If not,
Go into the router settings page. Make sure DHCP server is enabled, and make sure that none of your machines are being assigned a static IP.
If you need more info, please let me know.
Posted on Nov 15, 2010
IP Conflicts
I would try a different port with a new cable. IP conflict should be noted by the PC / node. You could ping the IP in question with the -a switch to resolve DNS name. You could also run a traceroute from the command prompt to help identify what drop if failing / timing out.
Jan 18, 2013 | Dell Computers & Internet
Where did i get a free dell ispiron laptop lan driver
please try and search the following link for Dell support.
support.dell.com/support/downloads
You can also log onto :
support.dell.com
request in the query with your model number
Sep 14, 2010 | Dell Inspiron 6400 Notebook
My dell ispiron 10 1.6GHZ is running at 783MHZ
The system is designed to conserve power unless an application demands more (Intel Speedstep)
Try disabling Speedstep in the BIOS
Jun 08, 2010 | Dell Inspiron Mini 10 Notebook
Hi everyone.. I have Dell Latitude model PP01L, Windows 2000 and is windows XP my problem is that when I try to connect to internet via ethernet my modem is connecting my router and my router is connecting...
Have you tried connecting your computer directly to your modem to see if it is your router creating the problems?
If you get a good stable connection might need to pick up a new router.
Feb 25, 2010 | Dell LATITUDE C640, P4...
DI-524 not working with Vista32 Dell M1330
make sure your wireless card is set to "obtain automatically an IP address"
Jan 25, 2009 | D-Link AirPlus DI-524 Wireless Router
Dell latitude E4300 wont connect to internet
Recently I purchased an Vostro 1310 for my mother as her Inspiron 1100 was dying; I installed all the drivers everything was peachy but frustratingly enoguh I could not connect to our home modem -
I alleviated this issue by taking it off obtain ip address automatically.
Then I put the following data in
IP 10.0.0.3
Subnet 255.255.255.0
Gateway 10.0.0.138
DNS preffered 10.0.0.138
Alternate Blank
I had to assign the laptop an IP as you can see and point it in the right direction which was to my modem. So all you need to do is find his modems default path and it should be sweet.
After I applied these changes it had no issues connecting - It might be a conflict of ip assigning on the network.
Before you rate get back to me if it didn't work - I want to help you solve this issue and get a Fix Ya! rating ;)
Blazamane
Jan 09, 2009 | Dell LATITUDE C640, P4...
I bought a used dell 505. When I try to connect to wireless internet I get the following: "Another wireless utilitty is communicating with Inte's Pro/Wireless adapter. To avoid conflicts, Intel's...
Hi Brucemph,
I just physically fixed a dell with the same problem. Dell installs a wireless configuration software that will auto configure the wireless adapter in the event there is a "Conflict". It basically disables the default card. Look at the programs you have installed and find the Dell Wireless program. Open it and select the default wireless card that is installed on the laptop. Once that is selected, go to your network connection, right click on the network adapter choose properties, select internet protocol, right mouse click, properties and make sure the box is checked that say's obtain ip address automatically.
Let me know how you do.
Nov 11, 2008 | Computers & Internet
HD laptop Dell ispiron 2200
You have to look for a ATA-6 5400 RPM hard drive.
e.g. you could use the Western Digital Scorpio 160 Gb
If you need more help, just post some info back.
Apr 21, 2008 | Dell Inspiron 2200 Notebook
Ip address conflicts
make sure that you are not connected both wirelessly and wired to one of the pc's, dissable the wired ethernet cards on all of the pc's as this may be the problem, and check in the DHCP client list in your router, refresh the list if you are able and see if there are two references to one pc with the same ip address.
assuming you have DHCP enabled on the router this should not happen as long as your wireless adapters are set to obtain an ip address automatically.
Oct 16, 2007 | Dell TrueMobile 2300 Wireless Broadband...
ASUS (SL1000) Router Logo
85 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
