Question about GPS
When i press power button display cannot see anything and no sound
Hold the ON button down for about 30 seconds. This should reboot the unit
Posted on Nov 15, 2010
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
Tip
Dell Laptops (Has power no display issues) 1. Immediately run PSA. (Make sure...
1. Immediately run PSA. (Make sure laptop is connected to AC Adapter. Leave laptop off. Press and hold on the Fn key then press power button once).
2. Just wait for about 3 to 5 minutes then you might will hear beeping sounds (no display with beeping sounds) this means that laptop is working fine but no display. This might cause by either the video card or LCD.
3. After hearing beeps turn off laptop. (Press and hold on the power button for about 3 seconds)
4. Leave laptop off. Press and hold on the D key then press power button once. If full screen colors appears this means LCD is working fine and the problem is the video card. If no display from the LCD no colors were displayed try the test again just to make sure. If still the same no full screen colors then the problem is the LCD.
on Dec 03, 2009 | Computers & Internet
Why my laptop(dell inspiron 1464) stuck while working? with continuous sound & displays one color for whole display. can't do anything except pressing power off button. Pls help me regarding this.
First check that your memory ( RAM) are firmly seated.Press on the memory sticks to make sure they have good contact.
Also The issue could be related with the operating system, as for instance in some cases the OS causes computer turns on, and turns off again. what I can suggest is that you re install the operating system again, or reboot computer to the factory defaults from the rescue CDs that you made. If the problem still exists , then there must be some hardware issue. In which I recommend you contact Dell support.
May 18, 2014 | Dell Inspiron 1464 Notebook
My daughter made a password on her archos and she can not remember what it is, is their anything she can do to get in without ?
- Press and hold the power button until the ARCHOS banner is displayed and then release it.
- Press the power button twice (like a mouse double-click) while the banner is still displaying.
- A white Recovery screen should appear within a couple of seconds.
- To move from one option to another, press the power button. To select the highlighted item, hold down on the power button.
You'll want to select the Format System option.
Jun 02, 2011 | Computers & Internet
I can hear my Ps3's Sound, when the HDMI cables are connected, and it's on the correct HDMI channel, though i can't see anything, the screen is just black. I have tried holding the power down, until i...
Ok, you are actually holding the power button down for too long. Please do the following to sort out the display on your PS3.
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep once when you first press it, then beep again about 5 seconds later. Release the power button when you hear the second beep. The display will now reset and it should detect your HDMI display with no problem.
Hope this helps
Dec 23, 2010 | Video Game Consoles & Games
Laptop won't boot (display problems)
If the diagnostics displays on the LCD screen but you get no display when Windows starts to load, it sounds like you have a video software driver problem. Try tapping the F8 key when you power on your laptop and boot in Safe mode. If it works in safe mode then you need to check you driver. You can also try connecting the laptop to an eternal monitor and see what happens.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 08, 2008 | Dell Latitude D800 Notebook
Zone 2 issues
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there
Aug 03, 2008 | Yamaha RX-V659 Receiver
Protection displayed and shuts off
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
Mar 01, 2008 | Samsung HT-X40 System
GPS Logo
15 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
