Question about HP Compaq dc7100 PC Desktop
My dc7100 will not power on! No reaction at all.
  • 1,179 Answers
I have published a guide regarding this matter, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Thanks for the opportunity to help you
damnor01
Posted on Nov 15, 2010
How to replace cd drive in hp compaq dc7100?
pls open the case and find the port power and data, you can buy or replace another DVD Rw easily
May 12, 2014 | HP Compaq dc7100 PC Desktop
When i on my pc hp dc7100 it is red light blinking please solve my problem.
first remove the cover of your computer after switching off the system and removing the power plug the power the system and see whether the processor fan is working if not power off the system and remove the 24 pin connector from the smps to the motherboard and short the green and black pin of the conector from the smps and see the smps fan is working if not replace the smps if working then remove the memory from the slot and clean them or change the memory to which match the dimm slot an connect the connector and switch on the computer
Feb 27, 2011 | HP Compaq dc7100 Ultra-slim PC Desktop
LOOKING FOR HP COMPAQ DC7100 SPF Ethernet Controller
Go to this website:
HP Compaq dc7100 Minitower Drivers
Select your operating system.
You will then get a list of driver options. You will need to know what network interface you have to select the correct one.
Thanks for using Fixya.
Nov 12, 2010 | Compaq dc7100 Minitower PC Desktop
Picked up a HP dc7100 but will not boot from sata
You should have an option on the dc7100 in bios to enable sata in the devices section. Mine always worked fine with sata. If nothing else works remove the security chip, reset the cmos and reboot with the Hard Drive connected and it should connect. If that doesn't work Try flashing the bios just in case it got corrupted.
Mar 12, 2010 | HP (REFURB) HP DC7100 XPP P4 3.2GHZ 80GB...
After 5 yrs of duty my dc7100 CMT shuts down
Well theres alot of things that may be wrong with your PC.
Im presuming your running Windows XP yes ?
1. Adding some coolerpaste may do the trick.
2. Try replacing the RAM i had this trouble and it was a dodgey/dead stick of RAM
3. Make sure theres no short circuiting anywhere.
4. Replace the Power supply.
5. Try reinstalling Windows again.
Hope this helped. Any more questions just ask me :)
James.
Feb 23, 2010 | HP Compaq dc7100 PC Desktop
Hi. I need to purchase a DVD burner for my Compaq dc7100 and need to know what brands will fit my computer. Thanks, **** P
I've checked on the specs of dc7100, and it shows that it has multibay optional for 12.7mm removable drives .
I've difficulties finding the exact DVD compatible for dc7100 since it seems that it's already been discontinued.
However, these are the closest match that I've found. Kindly click to double check the specification if it matches your computer:
HP Multibay DVD+RW Drive
HP Slim 8x SATA supermulti LightScribe Drive
Oct 29, 2009 | HP Compaq dc7100 Ultra-slim PC Desktop
Just bought hp dc7100 2.8ghz 1g-ram reco unit. VERY noisy fans, especially rear case fan. do i lose 1/2day returning unit or is it fixable? if fixable, is it economic? Micko
sounds like the fan bearings may have gone. Its very easy to replace, open the case and disconnect it (will only be via one power connector).
Now unscrew it from the rear of the case. You can either go without the fan as on a system of your power it isnt vital, or you can buy an 80mm fan from ebuyer or novatech for around £2 gbp to replace it.
Jun 14, 2009 | HP Compaq dc7100 Ultra-slim PC Desktop
HP Compaq dc7100 CMT: Impossible to enter BIOS
Try this,Remove the TPM and start computer,
TPM Card for dc7100
cae4c98.gifOn the desktop and workstation models, the connector is located under the drive bay on the right hand side of the computer. In order to recover the system you should remove the TPM module and re-install the OS.
Please rate this a fixya
Feb 11, 2009 | HP Compaq dc7100 PC Desktop
Dc7100 sff power supply
Part number :
349987-001 Switching power supply (340W) - 100-240VAC input, 45-66Hz
Aug 24, 2008 | Compaq dc7100 Small Form Factor (PJ361UA)...
HP Compaq dc7100 PC Desktop Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
