Pc want boot up until I hear the fan come on, It take 4 or 5 time or more before it boot up. But when it do it stay on. But if it Idel . I will turn of.......
  • 1,179 Answers
Go through my guide, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!! click on it and it will take you straight there.
Posted on Nov 15, 2010
Gas does not ignite on furnace. Fan stays on even when shut off at thermostat. When trying to start, I hear a click and get a gas odor that stops quickly. Furnace had major overhaul 10 years ago.
You have a ignitor problem .Replace the ignitor .Is it a direct spark or a glow type .My guess it's a glow type .About the fan issue sometimes fan would stay running for maybe a minute even after you turn the fan mode ofg
May 27, 2017 | Heating & Cooling
Laptop repair
You need to provide more information. It turns on, boots to Windows? How long does it stay on for? Can you hear the fan spinning?
Feb 26, 2014 | HP DV9626US Pavilion Notebook
Computer wont turn on
you have to considered these things if can establish right
1. does any light indicator at the panel of your pc?
2. how about the fan in the PSU does it work?
3. also the processor fan it is working or get stuck up.
4. does the operating system boot up?.
5. do you hear any beep when rebooting and how many times.
if one of this doesn't work good then you can not turn on your pc.
Oct 12, 2012 | Compaq Evo D500 PC Desktop
I WAS HAVING PROBLEMS WITH OVER HEATING, NOW MY LAPTOP HAS CUT OUT AND WONT RE-START. WHEN YOU PRESS THE POWER BUTTON IT LIGHTS UP AND YOU CAN HEAR THE FAN OR SOMETHING BUT THE SCREEN STAYS BLANK. ALSO...
When a laptop overheats the CPU will shutdown, this is known as thermal overload. The laptop will not boot up until the CPU has cooled down. If this problem in not fixed then the CPU will eventually fail.
This problem is usually caused by a faulty fan or the fan and heat sink is clogged with dust.
Replace the fan if it does not spin freely and or remove the dust clogging the fan and heat sink.
Oct 27, 2010 | Compaq Presario CQ60-220US PC Laptop
Media Center m7060n PC Desktop: My m7060n Tower turns on, but the key board blinks...
It sounds like you have a board that is not booting at all. Remove everything from the board except the system RAM and CPU and switch it on. If it boots now, shut it down and then replace each individual item one at a time, booting the machine after each item is refitted/connected until you fit something that prevents the machine from booting. Pay special attention to system RAM sticks by removing them/it and refitting it as bad connections in the RAM socket can also cause a boot failure but removing and refitting the sticks usually cures this issue.
May 18, 2010 | HP Media Center m7060n PC Desktop
WILL NOT RE-BOOT AND THE FRONT RIGHT HAND LIGHT IS FLASHING RED MAKING BEEPING NOISE ALONG WITH THE FAN GOING, ANY IDEAS ?
please remove and replug your system RAM. its happened due to some fault in system RAM. after remove and replug the RAM it will be sure working fine.
thansk & regards
Harry..
Feb 08, 2010 | HP dc7800 Business Desktop USDT Alternate...
Dell vostro 200 4 repeated beeps on start up
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Oct 05, 2009 | Dell Vostro 200 PC Desktop
Wont boot up,no picture or sound on the tv.
when u switch on your console try holding your finger on the standby button untill u hear it beep , i think it beeps 3 times this will put it back to the origional settings incase you have accidentaly switched it over to hdmi
Aug 11, 2009 | Sony Playstation 3 (PS3) Console
Screen is black. Hear computer trying to boot up.
cpu fan failure try to put a big fan where the comp vents and air flows! and see if its not shutting down!
Jul 01, 2009 | HP Pavilion dv5-1000us Notebook PC
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
