Question about Sony CDP-C545 CD Player
How do I reset it? i looked for a reset button but it doesn't have one??
I dropped my tablet and now everything is backwards words,screen,everything help
Hello! you might need to calibrate your tablet`s sensor, if that doesn`t work please turn off the auto rotation on your tablet, and then reboot your tablet. if that doesn`t work, please do a factory reset on your tablet by pressing power button + volume down, your tablet will go into recovery mode and look for factory reset.
Jul 29, 2015 | Tablets & eReaders
My password doesn't work
Routers have a reset button on them just for such an issue. Remember when you use this button the router will be reset back to factory settings. Look on the back of the router, you should see a little hole with the word reset above it. With the router pluged in, press this reset button (you may need a paper clip to get in the hole). When you release this button, the router should look like it has been powered cycled. At this point the router is reset to factory. You will need to set everything up on it, just like you did the first time you took it out of the box.
Hope this helps
Jan 31, 2012 | Computers & Internet
My EasyCap DC60 shows the greean light when I put it in the computer but it doesn't show the video and because it doesn't show the video I think the audio doesn't work. Please help.
You need to reset the BIOS of the Motherboard.
For easy repair, just remove the battery ( looks like a button ) on the motherboard,wait for 1- 2 minutes, then place it back again, that way should fix the problems
Aug 22, 2011 | Computers & Internet
Errer code 5
1/ Turn off the canon printer
2/ Hold down the Stop/Reset button
3/ Not releasing the Stop/Reset button, hold down the Power button, now release the Stop/Reset button
4/ Not releasing the Power button, double click Stop/Reset button and release both the Power & Stop/Reset button - doesn't matter in which order
5/ Click Stop/Reset button four times
6/ Click the Power button to confirm the selected action (reset counter absorber)
Aug 02, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I cannot find information on my router to change my password. My password doesn't work anymore
You'll want to reset your router using the following instructions:
To reset the router using the reset button, use these steps:
  1. Look for the red reset button at the back of the router.
  2. Press and hold the reset button for approximately 5 seconds.
This will reset your router to factory defaults meaning you'll have to set up your router to the way you like it (i.e. adding a password to your wireless network etc.)
Jul 24, 2011 | Linksys WRT160N Wireless Router
My garmin shows a computer picture and doesn't switch on anymore!
Connect it with the USB cable to a PC / Mac - does it communicate with Mygarmin.com? If so look for a software update and load it. Make absolutely sure it's connected to external power - so the battery won't die when updating. Then wait for it to restart.
If no connection then hold the power button for more than 20 seconds - this triggers the auto reset.
If that doesn't help - let it sit like this till the battery has been drained. Then try to restart while charging it.
If still the same - let it drain again and while pressing the On button, hold the lower right corner of the screen for at least 20 seconds. This will trigger a master reset - reverting back to factory mode. It will erase all user data.
Jul 04, 2011 | Garmin GPS
My printer is not switching on What can be the problem even though the fuse is alright in place?
UNPLUG PRINTER POWER CORD,AND TRY DIFFERENT OUTLET. IF THAT DOESN'T WORK, LOOK FOR RESET BUTTON, LOOK IN YOUR MANUAL UNDER TROUBLESHOOTING. OR CALL BEST BUY GEEK. HOPE THAT HELPED.
Jun 29, 2011 | HP PSC 1315 All-In-One InkJet Printer
The television stays in closed caption mode regardless of the settings. Is there a way to reset it to factory default
try turning off the caption through the remote of the menu. to reset it to factory settings, go to menu, then settings, then there should be an option to reset the tv. If this doesn't work look through your manual. Sometimes you have to hold the power button for some length of time or the menu button on the tv. if these methods don't work, tell me the model and make of the tv.
May 28, 2011 | Televison & Video
My htc touch 2 doesn t start anymore... it does ask me to press send button to reset it but it doesn t go
  1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
  2. Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default, or press other keys to cancel.
  3. Release the TALK and END buttons, and then press ENTER on your device.
Mar 11, 2010 | HTC Touch P3450 Smartphone
Sony CDP-C545 CD Player Logo
44 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
