Question about ViewCast CORP 95-00457 Osprey-450e Card Only
I just get a problemof osprey 440 on Linux. Description of the problem from customer: There are horizontal green lines when the 440 works in Linux for some larger output size and better quality. customer has done more tests: The 440 card worked good at YV12(8 bit/pixel)and 528x384 output size, it's good at RGB24(24bit/pixel) and 440x360 too. So maybe it's the problem of PCI main Line. Customer do the test and enlarger the ouput size ,there is no problem in windows os. Change the config of linux driver:gbuffers and gbuffersize ,the same problem as before. When he tried the ouput size of 768x576,there are green lines as the attached picture.There are more lines when trying the output size of 720x576.He tried the YV12,YVU420,UYVY and the lines are remains there but they are different between each other.He can't find the config of device--buffer,he only find the config:Processor Assignment PCI Compatibility Type. Here is the evironment: computer:HP DL380 G6 server card:osprey 440 os:linux (ubuntu 9.10) the output is worse,too many lines, had tried all the card port,and the system is instable. As a contrast,he also do the test: 1.same computer and card ,windows server2003 os,works well. 2.same computer and linux os,osprey 230 card,works well too. 3.same linux os and 440 card,change the computer with Inter mainboard ,words well. There are some problems at another computer with the mainboards of Intel 5000V:It works stable but have many lines. But in another computer with same type of mainboards it works well. attached three pictures:two capture of screen and another for machine and card.
2 Suggested Answers
  • 7 Answers
SOURCE: osprey-230 video capture card distorted
you must connect all cameras to solve this problem.if your capture card supports e.g. 4 cameras and you are only 1,2 or 3 connected the image can be poore.your video card has nothing to do with this.
Posted on Aug 29, 2009
Where can i get a dirver for Osprey 50 for Vista or Windows 7
I am afraid if its' Osprey 500 or 50, I am sorry if i am not right. Anyway try this site, http://www.viewcast.com/support/downloads and download the drivers. Good luck
May 22, 2010 | ViewCast Osprey 50 Video Capture
Image distortion
In the customer menu select convergence and then with the Mitsubishi remote select advanced, you should see a grid of lines.
If red or blue or green are out of position you have a problem in the convergence circuit.
If so, I have step by step instructions for this kind of repair and it can be a do it yourself job.
SD TECH
May 04, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Osprey 210 audio problem
The breakout cable has the RCA connectors needed. Yellow is Video, Red and White are the 2 audio inputs. Alternate inputs are the 1/8" stereo jack for sound and the S-Video plug. (not to be used all together).
viewcast.com is their website.
Also check the setup for recording, that the audio source is selected properly.
Mar 24, 2010 | ViewCast Osprey 210 Video Capture
Tv beginning to flash green with horizontal white lines
From your description it sounds like a bad picture tube. The lines are called retrace lines. There is a small chance that a component on the small board that connects to the neck of the tube may be bad. Without model number information it is very difficult so say further. Some picture tubes can be re-jeuvenated with the appropriate machine ( at a TV repar shop)
If you feel adventurous and are careful you might try GENTLY tapping the neck of the tube and see if picture improves/goes out. If the tapping does change the picture it is definitely the tube
Mar 12, 2009 | Loewe ARC332 32" TV
Osprey-230 video capture card distorted
Aug 28, 2008 | ViewCast Osprey-230 (OSPREY230) Video...
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Convergence / Short? 60PP9401
First thing to know = your set is Hitachi made with Philips
name on it....not a bad thing, just good to know.....
Parts to change out = STK392-110 IC's sub to upgrade
STK394-160E part # CZ 01341 , change both for reliability...
Then activate Intellisense and see if all is well........T.
Dec 14, 2007 | Philips 60PP9401 60" Rear Projection...
The microsoft doesn't identify the osprey 230
since the audio works but not the video, it sounds as though the problem might be in the codec, not the driver. check card provider to see if there is an updated codec pac or new service pac. try: http://www.viewcast.com/driverdownload.asp
Mar 25, 2007 | ViewCast Osprey-230 (OSPREY230) Video...
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
ViewCast CORP 95-00457 Osprey-450e Card Only Logo
164 people viewed this question
Top ViewCast Televison & Video Experts
Electro Med Services...
Are you a ViewCast Televison and Video Expert? Answer questions, earn points and help others
