Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Manuel neede for a intex krystal clear pump model 638 with skimmer basket
  • 640 Answers
Below is a copy of the users manual for the krystal clear 635. It should have everything in that you need to set up your pool filter.
http://www.pooltoysource.com/images/pdf/RVR006.pdf
Posted on Apr 05, 2011
Low pump flow-that what my pump says, what does it mean
it means there is not enough water moving through the system. check for blockages in the plumbing. empty the skimmer, make sure the valves are open. etc
Jun 25, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Which hose do i connect to the filter and which to the pump
The hose that comes from the skimmer connects to the pump while the one that connects to the lower port of the pool connects to the filter. I hope this helps.
Aug 16, 2011 | Intex Krystal Clear Model 635 Pool Filter...
WWas working just fine then hooked up vaccum and cleaned pool now the skimmer does not have any suction-- water blows out other side just fine and I have gotten all air out of lines--- any ideas
Depending on how much you vacuumed, your filter may just need to be cleaned. The filter on these units are not very big, so they can get dirty fast. Make sure it is cleaned out. Make sure skimmer basket is not clogged up, and make sure none of the flexible hoses are crimped. Also make sure there isn't anything stuck in the impeller. A stick, twig, or piece of toy, etc, can get stuck and cause low flow. Check for leaks between the suction side of the pump and the pool skimmer. One more think you might want to check is for leaks on the suction side while equipment is off. a leak here will let air into system and effect flow.
Sep 24, 2010 | Intex Krystal Clear Model 635 Pool Filter...
I just purchased an intex above ground pool and i need help on where to put the chlorine at
The problem with the floaters is they can drop out small pieces of tablets or granuales and cause bleach spots on the bottom of your pool. Use the skimmer.
Jun 15, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Apr 11, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
Pool vaccuum
are you filling the vacuum line with water before hooking it to the skimmer?
Jul 21, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
371 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
