Question about GPS
My garmin nuvi 250 iv had for 2 years has now decided to die on me.. when i turn it on a pop comes up and says that there is no maps downloaded to route and it ccant be used without them.. it worked fine yesterday and now i cant get past that.. any ideas?
    President:
  • 1,514 Answers
We have a garmin nuvi 255w. We need to know what is the latest map update. Our gps has "CN North America, NT 2010.30" version on it. Is ther something newer than this.
Maps for most GPS devices are updated several times a year. Your map is from 2010 and should be updated. You can go to the garmin site and pay to download and install upgraded maps or do a google search for map upgrades and you'll find some services offering lifetime upgrades for a few dollars more than the Garmin one time upgrade. I did this and have had no problems updating the maps on my Garmin Nuvi 250.
Mar 13, 2011 | Garmin nuvi 255W GPS Receiver
I have a garmin nuvi 250 and the touch screen is not responsive. I tried to recalibrate it by turning it on and holding the power switch for 30 seconds and touching the screen and the calibration dot came...
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. If there is a software update available, that should solve your problem.
Mar 31, 2017 | Garmin nuvi 250 GPS Receiver
How instal maps on sd memori card for garmin nuvi 250
Hello
Insert the memory card into the memory card slot on Garmin Nuvi 250 GPS device. The memory card slot is located on the left side of the device. Push the card in until it clicks. (If you inserted a memory card that already has pre-installed maps and files, there is no further action required. The device will access the new maps based on the address you enter.)
Connect the Garmin GPS to the computer using the USB cable. The mini-USB connector will need to be inserted into the rear of the Nuvi 250; the larger end is inserted into the computer's USB port.
Locate the computer file that you want to download to the Garmin memory card. The Nuvi 250 is capable of reading JPEG formatted images and GPX formatted Waypoints and other mapping-related files. Right-click on it. Select "Copy."
Select the "Computer" folder from the computer's desktop Start menu. Double-click on the "Removable Disk" drive that represents the Garmin Nuvi.
Right-click in an empty space within the drive and select "Paste." The files have now downloaded to the memory card and will be accessible through the Nuvi 250 menu options.
Good Luck, and do rate the solution if got help
Dec 06, 2010 | Garmin nuvi 250 GPS Receiver
How do i update my garmin nuvi 250? it tells me it needs to be updated.
Garmin is telling you to update your Map, its wants you to buy a New Map which cost around 50 or 60 dollars.....your unit will work find for now unless you need the new map 2011 it just has the newer streets and highways. Anything over 2 years old should have a newer Map..
With the gps Off
plug in your gps to your computer using a USB cable (most cameras connect to your computer with the same usb cable)
your computer with detect new hardware ( usb ) a pop up box will come up, minimise it
next
go to www.MyGarmin.com the Garmin site will detect your pluged-in unit and let your update your Map
It will say to download WebUpDater utility to transfer your map to your gps
Make sure you register your unit with Garmin at that time
Nov 11, 2010 | Garmin nuvi 250 GPS Receiver
1300 nuvi screen comes up loading maps and stops
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
I purchased the Garmin nuvi 250 GPS system last year but I'm unable to successfully download the USB and other data to update the equipment can you help me please?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater
First you have to set up an account at Garmin using the serial number on your GPS. Once you do that you can download firmware update for free.
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} By the way, the correct Garmin approved power OR download cables are a must!!
Does this help? Let us know. Thanks.
Aug 27, 2009 | Garmin nuvi 250W GPS Receiver
I want to update my navi 250 for free, any ideas?
The only way to get a map update cheaper would be to buy the lifetime update, which lets you update your unit up to 4 times/year (by downloads from their homepage) for a fix sum only slighly more expansiver than the regular update.
By doing more than one update however, the price per update is almost half of just buying an onetime update.
Jun 03, 2009 | Garmin nuvi 200W GPS Receiver
I have a garmin nuvi 250 device and want to update the maps for the UK and Europe. I have been told this can be done for free, can someone please help?
oh man i don't like when people ask me for free but u know what i bet u are a great guy and i can help u.THE ONLY THINGS YOU'L NEED IS AN USB,GPS WITH FREE SPACE,AND GOOD FAST INET.
Open www.thepiratebay.com
and type in the search engine garmin nuvi 250 (map and version)
for example
garmin nuvi 250 europe 2.16
i don't think there is a map that is 2.16 but...
than download the one you want and type in keygen generator garmin 250 nuvi
and than download it when you downloaded all the data copy the map in your garmin drive
and copy the .meta file to the keygen file folder load/run the keygen and write your device code than copy the map code. than disconnect your device and then when your device asks you for the map code write the code that you just have copied
Apr 26, 2009 | Garmin nuvi 250W GPS Receiver
GPS Logo
20 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
