Question about AMD Duron , 700 MHz Processor
I have a AMD processor 700 Mhz with 1Gb ram, my system problem is that when i do a multitasking work my system strucks and i have to restart my system
    Guru:
  • 767 Answers
Well firstly, your RAM is more than sufficient for multitasking so that's not the problem. You could however do with a slightly faster processor. There is a full list at Wikipedia, this link will take you straight there. I would personally recommend at least a Duron 1100 at 1.1GHz. Because this range of processor is a single core, it will struggle when it comes to multi-tasking. I will however congradulate you on using AMD, I find these to be the best value for money and are great performers.
Posted on Nov 15, 2010
I got this Presario 700 from a friend. it has a
Compaq Presario 700 Memory
Maximum Memory 384MB
Memory Slots 1 (1 bank of 1)
non-removable base memory 128MB
Machine name: Compaq Presario 700
CPU options: AMD Mobile Duron (900MHz)
Chipset: VIA ProSavage KN133
HD Bus: Ultra ATA-66
Front Side Bus options:
Memory Speed options: PC133 144pin SDRAM SODIMM
Hope this helps you out. Have a Happy and safe 4th of July weekend!
Jul 02, 2010 | Compaq Presario 700 470024-192 Notebook
Ubuntu did not insall all the way wont let dvd out of player
Bro you've better check first the hardware system requirements for that operating system before you proceed to installations. Ubuntu hardware system requirements. *CPU 700 MHz or 1GHz of processor *Hard Disk 3GB to 3.5GB of available disk space should be needed. *Memory 256MB or 1GB of RAM *Video Card at least 125MB for VGA graphics interface
May 11, 2010 | Computers & Internet
Want to upgrade CPU and Ram on ASUS A7V-ML motherboard
Download a small utility called CPUID from http://www.cpuid.com or use this direct download link "http://www.cpuid.com/download/hwmonitorpro/HWMonitorPro_106.zip". Using this utility you can analyze your system hardware statistics and also you can find the RAM capacity supported in your system along with various other RAM parameters. It will also show you the available free RAM slots to use, as well. I hope this is useful to you.
Aug 04, 2009 | AMD Athlon , 650 MHz (-K7650) Processor...
How to get AMD athlon 3700 socket 754 engineering sample cpu run at proper speed
Here's a little history
http://compreviews.about.com/cs/pchardwarebasics/a/aaBIOS.htm
More advanced stuff
http://compreviews.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=compreviews&cdn=compute&tm=128&gps=215_11_1267_540&f=00&su=p284.9.336.ip_p504.1.336.ip_&tt=2&bt=0&bts=0&zu=http%3A//www.adriansrojakpot.com/Speed_Demonz/BIOS_Guide/BIOS_Guide_Index.htm
Some systems have "bottlenecks," where small overclocking of a component can help realize the full potential of another component to a greater percentage than the limiting hardware is overclocked. For instance, many motherboards with AMD Athlon 64 processors limit the speed of four units of RAM to 333 MHz. However, the memory speed is computed by dividing the processor speed (which is a base number times a CPU multiplier, for instance 1.8 GHz is most likely 9x200 MHz) by a fixed integer such that, at stock speeds, the RAM would run at a clock rate near 333 MHz. Manipulating elements of how the processor speed is set (usually lowering the multiplier), one can often overclock the processor a small amount, around 100-200 MHz (less than 10%), and gain a RAM clock rate of 400 MHz (20% increase), releasing the full potential of the RAM.
AMD also produced x86 designs which competed with Intel on performance rather than price. In January 2002 the Pentium 4 gained a lead in sales and AMD marketing responded by giving their processors numeric suffixes approximating the clock rate that an AMD Thunderbird (and by inference a Pentium processor) would need to give matching performance, openly undermining the "megahertz myth".
May 15, 2009 | Computers & Internet
Memory synchronization Problem
Did you reset the cmos on board first?
Jan 18, 2009 | MSI K8N Neo3-F Motherboard
Can I put to much RAM in the motherboard for the Processor?
That additional RAM will be good for your computer so it will be much faster and don't worry everything should work fine there after adding new RAM to your computer....
Jan 13, 2009 | Intel (C733) Celeron A, 700 MHz Processor
CPU upgrade
Your motherboard has a good support for various Processors. If you want to go for the latest then you can go for Palamino core Athlon 4.Its compatible all the KV7 series boards but all you have to check is "Till WHAT clock speed can your board support?" .
Regards,
Sai.
Jul 10, 2008 | AMD Duron , 700 MHz Processor
Amd sempron 2800+
i want AMD Sempron(tm) processor 2800+ free downloads driver
May 27, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
Apr 03, 2008 | AMD Duron , 750 MHz Processor
AMD Duron , 700 MHz Processor Logo
79 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
