Question about Samsung LA46M81BDX 46 in. LCD TV
I have a LA46M81BDX/XSA which is 3 years old when i power it up it struggles to turn on continually making the switching noise while the red light is flashing then when it stops that it strugles to get a picture up . It is also getting ghosting when watching dvds on AV1
  • 308 Answers
SOURCE: red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
Posted on Jan 18, 2007
  • 29 Answers
SOURCE: Samsung LNR408DX/XAA Wont power up
power supply is bad
Posted on Mar 16, 2008
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Posted on Oct 29, 2008
lightnbaby
  • 36 Answers
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Posted on Nov 12, 2009
  • 610 Answers
SOURCE: Hi, My SAMSUNG LE40R88BDX/XEU LCD 40
It sounds like the power supply board has some bad capacitors that need to be replaced. Samsung is covering the cost to repair this problem on some models. You can call 1-800-samsung to find out if your unit is covered.
Posted on Apr 02, 2010
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
My Samsung LCD has no picture (screen is black) and the power repeatedly turns on and off. The red light on the power button continues to turn on and off. Can you help? The TV is only 3 years old.
open back cover check 5v filter capacitor on powersupply board that is either 1000uf or 2000uf
do you see any bulging capacitor? replace with top quality capacitor.
Aug 07, 2009 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Tv turns it self off after only 2-3 seconds and makes crack noise
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Dan
Jan 16, 2009 | LG 50PB4D 50 in. Plasma HDTV
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Tv will not power up - makes a weird noise and red light blinks constantly.
It sounds like a bad lamp, a bad lamp driver or a combination of the two. Be aware that sometimes a bad lamp driver will blow a perfectly good lamp, so if you're not sure which is causing the problem, replacing BOTH would probably be the best course of action
Sep 30, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
Samsung LA46M81BDX 46 in. LCD TV Logo
148 people viewed this question
Jerry Greenberg
Jerry Greenberg
