Question about Kenmore Grilling
Kenmore Sure-Spark We have a Kenmore Sure-Spark with Integrated Sideburner with a rotisserie motor but no rotisserie that was given to us. It is a "Precision Flame Cooking System". 1. Do you have any idea where the model number is or how we can get a manual for this unit? 2. How do we catch the grease so that it doesn't drip underneath on the concrete? 3. How do we mount the propane tank? Do we just place it on the lower wire rack? 4. There are no lava rocks in place. Does it need to have lava rocks to retain heat?
  • 4 Answers
Try Appliance Factory Parts ( at (800) 955-7075. Call or look on their website for specs, drawings, parts, etc. The grease clip underneath takes a Campbell soup can to catch the drippings. And yes, you need to buy lava rocks which act like hot charcoal when heated by the gas. Yes, the tank fits underneath on the stand and is clipped into the wire rack.
Posted on Jun 19, 2008
Heater runs but then dies out and smokes replaced fuel hoses is it the spark plug maybe
The spark ignition electrode is done doing its job as soon as flame is established. I'm thinking your infra-red eye is possibly the culprit. It 'sees' the infra-red given off by the flame to hold the fuel valve open. It is a glass eye that may not be perfectly aligned to 'see' the flame or it could have a dirty lens. Clean it first and try again. Try to make sure it is properly aligned to see the flame when it is established.
Jan 03, 2015 | Heating & Cooling
I just bought the Brinkman, and I am trying to figure out how to use the Rosterria. Can you help me?
Since a Rotisserie is an optional item for your model grill. I assume you have purchased one that is approved to be used on your model Brinkmann Grill Smoker. If not, I recommend that you Do Not use it. If it was approved, read and follow the directions that came with it regarding installation, setup and preparing to use the rotisserie.
The Rotisserie can only be used when you are not grilling anything else on the grill. Remove the grill grates directly in front of the rear infrared Rotisserie Burner. If you Don't, they will be in the way. In their place, you are going to use an aluminum pan (like a pie pan), as a drip pan for whatever you're cooking on the Rotisserie.Place that on top of the burner's flame tamers. Make sure the rotisserie motor is in place and you have electric power to it. Test the rotisserie spit, by inserting it into the motor's spit holder. If you have a Counter Balance, attach that near handle on the spit shaft just below the handle. If your rotisserie is missing the counter balance, you can not use the rotisserie.
Remove the rotisserie spit and place whatever you're planning to cook on it, following the directions that came with rotisserie kit. Make sure the spit forks are tightly embedded in the meat, whole chicken, etc. If a whole chicken, tie the legs together like a Thanksgiving Turkey around the spit..
Light the Rotisserie Burner and close the hood of the grill. Allow the temperature to reach a minimum of 250 degrees F, before opening the hood and installing the food loaded rotisserie spit.
Be careful, as the interior of the grill will be hot. Install the spit as you did earlier. Make sure it fits into both sides of the grill's hood correctly.
Turn the Rotisserie Motor ON and watch as the food turns. If it turns and then sort of bumps, when the spit turns around, adjust the counter balance to stop this. It should turn smoothly. Once all tha is completed, close the hood and allow the food to cook for whatever time, you would cook it in a kitchen oven. Rotisserie cooking is like smoking food. It's a low (temp) and slow (time) process. But, the flavor rewards are GREAT. Only check the food occasionally. The more you open the hood to peek, the longer it will take to cook. Each time you peek, add 10 minutes to the cooking time.
All of this, was sort of a thumbnail sketch of rotissering food. Search the web for recipes and techniques. You'll be amazed at what's out there.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 22, 2011 | Brinkmann 5 Burner with Smoker 8101750S
Where can i get parts forit.I have lost my Rotisserie grilling skrewere that holds the chicken in the middle and helps to turn it round
You can find a universal Rotisserie Rod (spit) at just about any home center or hardware store that sells gas grills and accessories. Take your rotisserie motor with you, to make sure you get one that will snugly fit the coupling on the motor.
Good luck & Happy Grilling!!
Apr 24, 2011 | George Foreman GBQ100 Grill
Flame does not stay on Rotisserie Burner grill but jumps back into the throat where the air mixes with the propane gas. What's wrong and how do I fix it?
If it's windy outside when this happens, the wind is blowing the infrared burner out. Especially if the hood of the grill is open. The Rotisserie should only be used with the hood closed.
Feb 09, 2011 | Grilling
CalFlame 4-burner convection BBQ rear rotisserie burner does not work. Converted to natural gas. There is a spark but gas will not ignite. Held match to burner and it would light but would go out when...
Check the air shutter adjustment on the rotisserie burner. It may be starving for air. Also make sure the burner is properly positioned over the orifice. When it was converted, it may not have been put back into place correctly. Also, it's possible the orifice may have been re-drilled out at the wrong size for natural gas. If you know the rotisserie burner BTU rating, I can look up the correct orifice hole size to check if it's right. Douglas
Sep 12, 2010 | Cal Flame 5-Burner
I was given a ducane 20002301 2 burner with rotisserie and when I ignite and have on high there is not much flame. I know very little about gas grills
Could be two things, the first is a bad regulator, easy to replace and not very expensive. The other is a blockage in the burner orifices. For this you have to take the burners out and check inside the burner venturis and then see if you can unscrew the orifices on the valves and clean out any blockage.
Nov 16, 2009 | Ducane 455 inch 2 - 3 Burner with...
I have a pyromaster electric fireplace model HEF flame does not flicker ,it lights upand heats but no flame
I have the same model and problem there must be some part to get to replace it it seems to be a motor problem. would appreciate any ideas
Nov 09, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Ducane 3400042 lighting problems
Good answer... but remember (if you have the regular burners on... The Rotisserie will not light.) 1. Cut all knobs off... Then push and hold in Rotisserie button as you turn to high.
2. Press ignition button, until you hear rotisserie ignite. 3. Keep holding in the rotisserie button until the thermostat realizes the gas is on and burning. (IT must get hot enough to keep gas flowing.) Hope that helps, Dave
Apr 08, 2008 | Ducane 30400040 Stainless Steel Grill
Sideburner for Thermos Stainless Steel Gas Grill (Mod # 461262006)
It sounds like the orifice is bad. An orifice is a small metal part that has a small hole in it. This regulates the gas coming out to the burner. It is at the tip of the pipe that brings gas to the burners, before the flame. I don't know what the hell the garggley noise is. Unless the bottle is upside down, and you are getting liquid, I don't know.
Mar 02, 2008 | Thermos Stainless Steel Gas Grill
Grilling Logo
594 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
