Question about HP LaserJet P3005n Printer
49.4C02 Error - HP LaserJet P3005n Printer
  • 152 Answers
Hewlett Packard 49.XXXX Errors
I hope this will be of assistance to you, any repairs under taken are at the owners free will.
Hello, the dreaded 49.2F9D Error Turn Power On/Off and other related 49 Errors.
This tip relates to the Hewlett Packard P3005 Series Printer - General reference to most HP Laser Printers
There have been many reports of this error in the HP genre of laser printer. This is a generic fatal error; the root cause is undetermined in most cases. It could be related to an application "corrupt data" or faulty printer firmware, or the formatter board or other associated hardware or accessory. The first step in troubleshooting this error is to isolate the printer from any computer source - disconnect from any I/O ports, Network/USB etc... Power cycle the printer. Does the error still report? If NO then an application may be causing the error, try to isolate the file causing the problem. Clear any pending print jobs. If YES then Firmware/Formatter most are the problem. A new firmware file can be found here. P3005FIRMWARE
Pay close attention to PDF files with embedded JPEG files.
Pay close attention when printing Emails or Web Pages.
In rare circumstances the fuser has been reported to cause the 49.2F9D error. (P3005 specifically)
*** Further Reference Material MoreOn49Errors ***
Contact a local HP Authorized Service Center for further assistance.
Posted on Feb 23, 2011
Oce tds error code 12502
Error 12501, Error 12502, Error 12503, Error 12504, Error 12505, Error 12506, Error 12507, Error 12508, Error, 12509, Error 12510, Error 12511, Error 12512, Error 12513, Error 12514, Error 12515
Error codes related to External Paper Input Module
Oce VarioPrint 110
Oce VarioPrint 120
Oce VarioPrint 135
Apr 28, 2014 | Office Equipment & Supplies
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
The printer will not print because of service error 49,4c02
Hello thanks for using FixYa
error 49.4c02 is a critical firmware error that occur which cause the processor on the formatter to abort operation.This type of error can be because of invalid print commands,corrupt data,or invalid operations. Sometimes electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables or poor connections,
To solve this try this solution step by step
  • Turn the printer off and then back on.
  • Try printing a job from a different software application. If the job prints, go back to
  • the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
  • f the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
  • Turn the printer off.
  • Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
  • Remove all EIO devices from the printer.
  • Turn the printer on.
  • If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
  • device.
  • Replace a DIMM or EIO device if you determine that it causes the error.
  • Remember to reconnect all cables that connect the printer to the network or computer.
  • If the error persists, final option is replace the firmware
Please see my this Solution (Same as your's), 2 people thought it as Helpful for them So
I hope this solution will also helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Feb 10, 2011 | Office Equipment & Supplies
My photocopy of canon ir3100f the give massage code error on screen i want solution
Wich code?
Here is examples:
E000 Insufficient temperature rise of the fixing unit at power-on
E001 Abnormality of the fixing unit
E002 Insufficient temperature rise of the fixing unit
E003 Low temperature of the fixing unit after standby
E004 Error of the protection circuit in the fixing unit
E006 Connection error of the fixing unit
E008 Life expectancy of the fixing roller
E010 Main motor error
E012 Drum motor error
E013 ITB waste toner full error
E014 Fixing motor error
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
E021 Developing rotary error
E026 Toner empty error
E032 The counter of the NE controller fails to operate.
E045 OHP sensor error
E067 High voltage-related error
E070 ITB HP detection error
E100 BD error
E110 Operation error of the laser scanner motor
E202 CIS unit HP detection error
E225 CIS light quantity error
E227 Power supply error in the reader unit
E243 Control panel unit error
E248 Backup memory error
E315 Abnormality of image data
E351 Main controller PCB error
E400 Feeder communication error
E490 Model error
E500 Finisher communication error
E503 *** Finisher internal communication error
E505 Finisher backup memory error
E514 *** Stack delivery error / **** End assist motor error
E519 **** Gear change motor error
E530 *** Rear alignment error / **** Front alignment error
E531 Staple error
E532 Staple unit shift error
E535 Swing error
E537 *** Front alignment error / **** Rear alignment error
E540 *** Stack tray up/down error / **** Upper tray up/down error
E542 **** Lower tray up/down error
E577 *** Paddle error
E580 Stack tray up/down error
E584 **** Shutter unit error
E590 ***** Puncher motor error
E591 ***** Puncher dust sensor error
E592 ***** Puncher side registration sensor error
E593 ***** Puncher shift motor error
E5F0 **** Saddle paper positioning error
E5F1 **** Saddle paper folder error
E5F2 **** Saddle guide error
E5F3 **** Saddle alignment error
E5F4 **** Saddle rear side staple error
E5F5 **** Saddle front side staple error
E5F6 **** Saddle paper push-on error
E5F8 **** Saddle connector error
E5F9 **** Saddle switch error
E601 Abnormality of image memory
E602 Hard disk error
E604 The image memory (SDRAM) is faulty/insufficient
E609 * Abnormal low temperature of the hard disk
E610 ** Failure in the hard disk cryptographic key
E674 FAX board communication error
E677 Abnormality of the external controller
E712 Communication error between the ADF and the reader
E713 Communication error between the finisher and the printer
E717 Communication error with the NE controller
E719 Communication error with the coin vender/card reader
E730 PDL error
E731 UFR PCB error
E732 Reader communication error
E733 Printer communication error
E740 Abnormality of the Ethernet board
E744 Language file/BootROM error
E745 * Token ring board error
E746 * Option board error
E747 Main controller PCB error (Image processing ASIC or memory control/communication control
ASIC)
E748 ** Main controller PCB error
E749 ** Restart in accordance with a change of the product configuration
E803 Door close error
E804 Controller fan error
E805 Fan error
Jun 26, 2010 | Canon iRC3100 Printer
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
to abort operation. This type
of error can be caused by
corrupt data, or invalid
operations. In some cases,
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
the message appears
only with a certain
software program or
software vendor for
assistance.
4 If the message persists
programs and print jobs,
disconnect all of the
or computer.
5 Turn the printer off.
6 Remove all memory
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
DIMM and EIO device
off and on again as you
install each device.
10 Replace a DIMM or EIO
Try new network card
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
HP LaserJet P3005n Printer Logo
359 people viewed this question
Seeker5211
Seeker5211
