Question about One For All URC-3021 Remote Control
Program remote I think that i have the right code for goldstart tv bu thow do you program the one 4 all remote
    Champion:
  • 217 Answers
Code for programming to a LG 4K tv?
  1. LG UHD 4K Television - LG.com‎
    Adwww.lg.com/UltraHD4KTVRatings:Reliability 9.5/10 - Picture quality 9.5/10 - Features 9.5/10
Search Results
    Find Your Comcast Remote Control Programming Code
    customer.xfinity.com/...tv/finding-your-remote-control-programming-co...
    Learn Comcast remote codes and more information on how to program your remote control. ... To Watch On Demand Programming with XFINITY TV:.
    DIRECTV - Remote Control Code Lookup
Jan 01, 2016 | LG Televison & Video
How to program an rca tv remote to rca tv
Hello
Your RCA remote universal remote control model number is RCA RCU300T; I thinks and poste this solution to you.
Codes for RCA tv with this remote control are:
000, 003, 004, 005, 027, 045, 077, 089, 090, 094
In order for the 3 component universal remote to control
your TV, you must program it with the TV code that matches
your TV. These instructions explain the preferred method of
programming the remote-the Direct Entry method.
1* Manually turn on the TV.
2* Locate the enclosed TV Code List.
Find your brand of TV.
3* Press and release the TV key. The
indicator light blinks and then remains lit
4* Use the number keys to enter
the first code listed for your brand.
After you enter a valid three-digit
code, the indicator light turns off.
Note: If you enter an invalid code,
the LED will flash rapidly for 2
seconds. Start over at step 3.
5* Aim the remote at your TV and press
the ON•OFF key. If your TV turns
off, you have found the correct code
6* Enter the code in the box provided
on this page for future reference
7* If your TV doesn't turn off, repeat
steps 3-6 above, entering the next
code for your brand.
OK
Jul 05, 2011 | RCA 3-Device Universal Remote with...
I NEED A NEW REMOTE CONTROL
Hello
I thinks that you need a new universal remote control for your RCA tv, and answers. You just buy one stated below,and codes and other proceedings are also given.
Model No: [RCA - D770 Wide Range Remote Control]
Codes for RCA TV with this remote control are:-
1000, 1003, 1004, 1005, 1006, 1007
.........................1019, 1096, 1098, 1099, 1100, 1101
.........................1102, 1103, 1129, 1179, 1181, 1187
............................................1188, 1190, 1198, 1199
Proceedings
1. Turn on the device to be programmed.
2. Look up the brand and code number(s) for the device on
the code list at the end of this section.
3. On your remote control, press and hold the device button
you want to program.
4. Enter a code from the code list.
5. Release the device button, and then press ON•OFF to
see if the device responds to the remote control
commands. If it doesn't, try pressing the device button
and then ON•OFF again.
6. If you get no response, repeat these steps using the next
code listed for your brand, until the device responds to
the remote control commands.
NB: Switch Off and On your TV with its front panel power switch each time [NOT BY THE REMOTE CONTROL HANSET], before you try an other code, UNTIL YOU GET THE RIGHT ONE.
Dec 20, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
I need the code list for a slyvania tv i have a rcu404b remote..
Your remote is programmed with only ONE code for Sylvania TV . . . 4
http://rcaaccessories.com/remotefinder/?sku=RCU404&productType=TV
I think your remote is fairly old. If your TV is newer than your remote, this code probably wont work.
Please rate this solution if you find it helpful. Thank you.
Nov 03, 2010 | RCA Universal Remote Control
Remote Control Code for Element LCD TV -- & Direct TV
We cant find our original element remote control. I just tried 10178 on the direct tv remote control and it worked YEAH!!!! We just can't do the screen size edit thing with it :(. Might still have to order a replacement element remote. This works for now. Thanks.
Oct 03, 2008 | Olevia LT32HVM 32 in. LCD Television
Program remote to tv
JVC tv codes0463...0053...1 turn on device 2 aim contrllr at device and press TVkey for TV 3/press and hold little 'p' key upper right on contrllr, till LED blinks twice, the release 'p' key 4. enter in first set of code numbers 4-digit code, if this is right set LED will blink 2x. If not repeat steps, till LED blinks twice after entering 4-digit code....then press the power button...the device should turn off and your good to go. Just make sure when you go to operate your remote that you have the right device button turned on.
Sep 25, 2008 | Radio Shack (15-2147) Remote Control
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Need code
try code 238, if it does not work you will need to try the code search.
1) turn on tv
2) press and hold "code search" until indicator light comes on
3) release code search
4) press and release "tv", indicator light should blink once
5) aim remote at tv and press the power button until the tv turns off (you may have to press it 200 or so times)
6) once the tv turn off, press enter on the remote
Nov 17, 2007 | RCA RC-U703SP Remote Control
RM24912 problems
i think this is cause u didn't programmed it well ... try to program it agian with the right code for your TV and if u didn't find the right code .. i will get it for u please rate me if this help u ...
Jul 30, 2007 | GE RM24912 Universal Remote Control
Remote control codes
The only remote that works is the one 4 all. Call ONE 4 ALL for the right model number. They then can program the remote on the phone to operate the SVA tv. It worked for me until the set died this week. Guess why I am looking on this site.
Apr 07, 2007 | SVA-USA HD4208TIII-VR 42 in. Plasma...
One For All URC-3021 Remote Control Logo
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
