Question about Toshiba Computers & Internet
I was given a toshiba retractable mini mouse to use on my emachine 350 but can't get it to work, does it need a driver?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 157 Answers
Like other computer mice this one doesn't have any specific driver download:
1) Plug the mouse in the USB slot and check the laser beam under the mouse - if there is no light, the mouse is dead, and you should return it to the seller for replacement. (Such a thin cable of the mouse is very vulnerable and might break easily. More over I find many negative reviews about this rectractable mouse - so if your seller offers to replace it - ask for a different model or test it with your laptop right in the shop before bringing it home.)
2) Here is a solution that already worked for another user, but was very complicated: http://forums.toshiba.com/t5/Keyboards-Touchpads/USB-mouse-not-recognized-drivers-can-t-be-installed/m-p/23526
3) Or alternatively download and install a free driver updater software, e.g. http://www.innovative-sol.com/drivermax/index.htm - let it scan and update all your missing drivers - it may fix USB general problems if this causes also the mouse problems.
Posted on Mar 05, 2011
  • Reinis Berzins
    Reinis Berzins Mar 07, 2011
    P.S. If this helped you to solve the problem (or at least brought some clarification) - rate this solution with 4 thumbs up! But before you would give a negative rating - post a comment, so I could improve my solution to satisfy your needs. Thank you!
My retractable mini mouse is not working. I don't know how to open to change the batteries if that is the problems, help!!!
You are not giving much information as to the make and model of the mouse but since it is retractable I assume that refers to a cable. Wired mice do not have batteries, they draw their power over the wire from the USB port. If it is not working, try another port. Try the mouse on another computer or try another mouse on this computer to determine if the problem is the mouse or the computer.
Feb 07, 2017 | The Computers & Internet
Mouse driver for m00117 laptop running win 7 does recognize mini mouse need driver
click start control panel under harware and sound view devices and printers you should see your mouse right click select open download mouse software
once your usb mouse is connected windows 7 should automatically search for and update the drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question/exclamation mark? ! or a red Xthis means a driver will need to be updated right click select update driver
Oct 18, 2011 | Sakar Optical Retractable USB Mouse...
My mouse isn't working. it is ge 98768 retractable mini mouse
hi
this is because of lose coonection in the wire. r the USB port got damaged. jus trying using another mouse if it works in your computer then the problem with the usb port.
Jul 05, 2010 | Jasco GE Notebook Mini Retractable Mouse -...
M trying to fix my retractable mouse. do you have any diagram showing how the insides of the retractable mechanism looks like. much thanks!
Optical mouse from inside: http://www.gadgetrivia.com/photos/o/56422-best_optical_mouse.jpg (this isn't a retractable mouse, but the inside looks exactly the same, only the cord this different which doesn't matter in this situation).
Here are instructions for optical mouse repair: http://www.thenetguruz.com/hardware/diy-optical-mouse-repair/
But if your mouse doesn't work first plug the mouse in the USB slot and check the laser beam under the mouse - if there is no light, the mouse is dead, and you should return it to the seller for replacement. (Such a thin cable of the mouse is very vulnerable and might break easily. More over I find many negative reviews about this rectractable mouse - so if your seller offers to replace it - ask for a different model or test it with your laptop right in the shop before bringing it home.)
Apr 10, 2010 | Generic Memory Mini Retractable USB...
I get a report message saying basically this : An Error occured during installation.The driver installation files for this device is missing a necessary entry. This may be because the INF was written for...
Yes,
 you need a Vista driver for this device, windows 95 shows how old it is !
If you are upgrading from WIndows XP to Vista delete all the mouse drivers in the device manager (under control panel).
Then let Vista install new ones.
Mar 07, 2010 | Toshiba Black/Red USB Laser Mini...
My toshiba laser laptop mouse is broken right now. It is a mini retractable laser mouse. The laser is normally red but it is not turned on now.
that sounds like a bad cable connection from the electronics in the mouse to the main-board. That would most likely have to be repaired at Toshiba.
Oct 01, 2009 | Toshiba Computers & Internet
Stopped working
Hey,
Goto device manager by right-clicking My Computer-> properties-> hardware-> device manager.
There in mice and other pointing devices category, select your mouse, uninstall it and refresh the page.
It should automatically detect your mouse.
Thanks
Apr 15, 2009 | Toshiba Black/Red USB Laser Mini...
Computers & Internet Logo
241 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
