Question about Gaggia Titanium Espresso Machine
Gaggia titanium dispenses different amounts of brew
I have programmed my cup size and it varies in amount each time I use it
  • Anonymous Mar 29, 2014
    The image you sent showing the dis-assembled gaggia machine parts...the image is too small to view. Please send a link or something that I can click to get a normal sized image
    Sergeant:
  • Gaggia Expert
  • 223 Answers
First thing to you should try is descaling your machine if you haven't already. If descaling does not work then it might be some kind of leak issue.
You see, when leaks are present internally in the espresso machine it varies the amount of the cup, because a portion of the water which should have gone into your cup, has leaked into the machine.
It looks like your machine needs some service.
Visit www.CeriniCoffee.com if you need service in the New York City Area.
Posted on Jun 19, 2008
Expresso is too large
Nancy, this setting is controlled by the settings menu. You reach that by right arrowing through the different beverages/menu selections until you select "Settings".
  • In settings, scroll to "program the amount"
  • place a cup under the spout
  • select the beverage you want to program, espresso in this case
  • select start
  • select okay when the amount of water has been used
  • the machine will remember this setting for future espressos
  • the same menu structure allows you to control the amount of coffee ground, as well as the amounts for other beverages
Mar 15, 2016 | Miele CVA 4066 Stainless Steel
Gaggia titanium coffee slow coming out of machine
Not sure it will work for you but Our Bunn has a flex wire to run thru the tube weekly , and if we do not clean that tube it might take 20 minutes to make a pot where when cleaned it does 12 cups in 3 minute
Nov 26, 2015 | Gaggia Titanium Espresso Machine
When I press the espresso button instead of esspreso makes a long coffe .I must ad I descaled it yesterday .
You may have accidentally changed the amount setting for your espresso shot when resetting the descale counter.
If you lost the manual you can find one here.
http://www.gaggia-usa.com/support_docs/Gaggia_Brera_Quickstart_Guide.pdf
On page 11 (with the printed number 31) you find how to change these settings:
• Place a cup under the dispensing spout.
• Hold the "espresso size" button pressed for 5 seconds to enter the programming mode; the "coffee" icon will blink quickly and the coffee will start to be brewed; the icon will flash during the whole coffee brewing cycle.
• Press the same "espresso size" button again when the amount of coffee in the cup reaches the desired level.
At this point the button "espresso size" is programmed; each time it is pressed and released, the machine will brew the same amount of coffee that was just programmed.
The same operation can be repeated for the "Lungo size" button.
Jun 15, 2015 | Gaggia Brera Coffee Maker
My Keurig B40 has three different size cup sizes available, but it dispenses the same amount of water for the medium size cup and the large cup of coffee. It's barely been used so It doesn&am
I realize you think it does not need descaling to to it 'not being used much.'
However you may have hard water and I would think descaling is definitely worth a try. There might be scale built up on the water level probes in you machine.
Descaling Details are listed below:
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
(DO NOT USE A K-CUP)
Just press the BREW Button. Pour the contents of the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until "ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink.
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew cycles if you notice any residual taste.
Nov 20, 2014 | Keurig B40 Coffee Maker
Espresso (small coffee) doesn't work anymore
you have to change the amount of the water on the small coffe button. Press and hold it while is making coffee .When you want to stop -just take off your finger from button.
Aug 22, 2014 | Gaggia Titanium Espresso Machine
Too much water is dispensed resutling in a weak espresso. This happened after rinsing the brew unit. Greatful for any assistance with this. I have a 1 year old Titanium.
Hi
Try reprogramming the button that is dispensing to much.
Push and hold the button for the coffee you want, but hold it all the way through the process. Don’t release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
If that doesn’t fix it, then you might need a new flow meter.
Jul 20, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium. . coffee not hot even though
Remove the filter holder and brew some water into a small plastic cup and check temp, it could be the thermostat for the coffee temp is damaged.
Apr 29, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Will grind the coffee beans but no water passing
Either the grind is too fine or the brew unit is blocked at the screen.
Feb 05, 2010 | Gaggia Titanium Espresso Machine
No water coming through on rinse cycle
try to make a cup of water (tea), if you not get any water that way i think you have to replace the flow meter in the machine.
Best regards
/Mirran
Oct 24, 2008 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
148 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
