Question about Samsung SyncMaster 912N 19" Flat Panel LCD Monitor
Screen blanks out after aqbout 50 minutes to a little over an hour
Screen blanks out. but the computer is still operating correctly. Or if I do a restart it will not come up to desk top. bvut gives me a black screen. I have to turn off for about half an hour or a little more for it to come back up.
If i turn off the computer. the dos screen comes up the windowsXP comes up then i get a gray screen for a moment and then it goes black.So I have to turn it off and wait for half an hour and it comes up like normal.
On a restart if I leave the computer come all the way up I can hear the computer to on line in the speaker. I have taken hooked the computer up to another monitor and it restarts fine every time. Left it on for over an hour on the other monitor and it worked fine. So it has to be the monitor or the driver. when I disconnect the monitor with power on i get the ICON indicating that the monitor is alright.
Please advice.
Thank you,
Paul Reece
  • 558 Answers
Sounds like bad capacitors on the inside board.
Posted on Jun 19, 2008
What causes my TV screen to go blank after 10 minutes?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Dec 10, 2015 | Toshiba 46l5200u 46es 1080p/120hz Led Tv
HOW TO SET SCREEN TIMES? cOMPUTER GOES BLACK WHEN i AN WORKING
Do you mean the computer shuts off? Confused bout "screen time." a what you mean.
Aug 10, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Hi the clock is set for 60 Hertz, What about countrys with 50 Hertz in voltaje?
50 Hz means the electric generator rotates 50 times per second.
And then electricity oscillates or reverses polarity 50 times per second.
Products rated for 60 Hz will not operate correctly with 50 Hz power.
Feb 16, 2014 | Coralife Power Center DayNight Timer or...
I need a night light timer that I can set to be on for 50 minutes and off for 10 minutes and repeat this every hour for 24 hours.
1) If you have programmable timer, then it would require 24 ON and 24 OFF settings, with down-to-the minute programming.
1 ON for each hour.
1 OFF for each hour.
Following link shows Grasslin 50-60 Hz 230Volt din rail timer with 50 memory slots. 16 amp at 230 volts
http://waterheatertimer.org/pdf/talento_371_372_371_mini_plus_data.pdf
2) If you have 24 hour mechanical timer with dial, it would need 24 ON trippers and 24 off trippers with down-to-the minute schedule.
No timer has that capability.
3) There is C8800 series cycle timer. 120-240Volt 60Hz for US market. 20 amp at 120volts, or 20 amp at 240Volt. Chose 1 hour cycle, then insert 100 trippers and leave 20 blank spaces.
http://waterheatertimer.org/pdf/027-C8800-sprinkler-cycle-timer.pdf
4) There are percentage cycle timers.
For example CT2000. Rated 120Volts 60 Hz for US market.
http://waterheatertimer.org/pdf/CT2000_sell-sheet-with-wiring.pdf
Select 1 hour cycle, and 16% or 84% percentage to choose ON or OFF
Nov 28, 2012 | Woods Indoor 24 Hour Night Light Timer...
Please tell me how to program my timer. How do I set the time and when it should come on and go off everyday
Smarthome has the T-1032 pdf manual
http://www.smarthome.com/manuals/4256.pdf
1) Test installation to see if your wiring technique is correct.
Open cover > set on-off switch to 'ON'
Press the tiny round reset button with paper clip
Screen displays 0:00, MO, MAN, OFF
Close cover
Push cover inward like a push-button (the cover is the manual override)
Lights should turn on
If lights don't turn on, then you need to rewire ... so re-post a re-wire question ... and then come back to this answer to program
2) Set Time and Day/ Correct time and day are needed for programs to work.
To start, notice on the screen - in the corners are little letters: MAN, MO, OFF. And to left of time is PM.
Set the Hour: Press hour button until correct hour shows, including PM or AM
Set minutes: Press MIN button until correct minutes show
Set the day. Press day key ... MO in corner changes ... for example TU is Tuesday, WE Wednesday, TU Thursday
Press one of the control buttons to finish operation
Programming overview
Timer allows 7 programs
Program 1, Program 2 etc
Each program has ON and OFF time
So you have to select Program 1
And then set DAY for Program 1, set ON time for Program 1, and then set OFF time for Program 1
Next you do the same for Program 2 , and then Program 3, 4 etc to 7
If you only want Program 1, then you do not need to set Programs 2 thru 7
Let's program
Press PGM button ... the timer screen show a P to right of time
The number 1 appears below P and indicates Program 1
Set days you want Program 1 to work: Press day button and you can see MO TU WE TH etc appear on screen.
If you want all week long, press day button until all 7 days appear in tiny print on bottom of screen
Now you have the Day set for Program 1
Notice the screen shows ON ... this means you are going to set the ON time for Program 1
First, Set hour you want Program 1 to turn ON: press Hour button until correct AM PM time shows on screen
Last, set minutes to go along with hour: press MIN button until correct ON time minutes show
You have the day, hour and minute set for ON time
Set OFF time for Program 1: we are going to set a Day, hour and minute you want Program 1 to turn OFF
Press PGM button, and notice that OFF appears in top right corner of screen
Set the day you want timer to turn OFF for Program 1 by pressing DAY button >>> Tip set same days you set for ON times. So if you selected all seven days for ON time, then select all seven days for OFF time
Set the hour and minute you want Program 1 to turn OFF by using Hour and MIN buttons as before.
OK, the ON and OFF day, hour and minute are set for Program 1.
To continue to Program 2, press PGM button until a 2 appears on screen below the P
If you do not want to set more Programs, then you're finished
To finish, press any control button
Close the lid, cross your fingers, you did good
Sep 30, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
Looking to buy a Samsung HP-S5073 Plasma, and the owner says that the screen goes blank sometimes. (But the sound still works while the screen is blank). This could happen for 5 minutes or an hour. Then it...
There is a possibility that this comes from poor signal quality. Re-booting the television may stop this behavior for a period of time, but if the problem is not corrected, it will return.
There could also be an internal problem with the television.
(Personally, I would look to buy something else.)
Hope this helps!
Jun 17, 2010 | Samsung HP-S5073 50 in. Plasma HDTV
My screen only displays after 4 /5 hrs
Try a different screensaver.
Also look in the display properties by simply right clicking the desktop and clicking properties.
Then locate power management.
the initial seems to be a bad screensaver judging by the 20 minutes, but the 4-5 hours seems to be a sleep mode that bypasses the screensaver issue.
Jul 23, 2009 | Computers & Internet
Wondering why(like many others here) I can't play videos on my computer anymore? I get a blank screen with a square/triangle/and circle in a little box in the upper left corner of a blank screen..
90% of the time this is due to your not having the correct codecs installed or windows media player (or whatever client you use0 being unable to download them.
A free codec pack is available here
http://www.free-codecs.com/K_lite_codec_pack_download.htm
I suggest you choose the full version 5 and install with the default settings.
Jul 16, 2009 | Microsoft Windows XP Home Edition
IBM T30 screen ramdomly goes blank and computer freezes.
Reset your bios settings to "Bios defaults", then disable power management.
In Windows, go to device manager and try to detect new hardware. Follows screen instructions.
Mar 27, 2009 | IBM ThinkPad T30 2366 Notebook
Samsung SyncMaster 912N 19" Flat Panel LCD Monitor Logo
208 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
