COMPUTER DOES NOT SWITCH ON - Computers & Internet
  • 1,179 Answers
My guide will explain every-thing, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Thanks
damnor01
Posted on Nov 15, 2010
My print jobs say printing but no result. stays in the que. printer window shows mn1 and sleep, other than the date and time
If you know how, open the 'printers folder' in your computer and delete all the printing jobs.
Switch off the printer and unplug it from the computer.
Switch off the computer.
Switch on the computer.
Connect the printer and switch it on.
Hopefully it will have cleared itself
Mar 12, 2016 | Brother MFC Office Equipment & Supplies
Gateway DX4822-01 power switch problems
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Main wires such as Power On LED, Power On switch, HarDDrive activity LED, and Reset switch; IF used.
Suggest KEEP track of where those wires go!
Make a drawing, and notes. I even use a magic marker, (Sharpee?), and make a notation of the Front Panel header pinout, on the floor of the computer case.
In this particular case it isn't known if the Power On switch is the problem, or the Power Supply.
Power On switch;
Power UNPLUGGED to computer, Anti-Static Precautions FOLLOWED; (Don't know? Post back in a Comment),
Remove the twisted pair of W/B and W/G wires, to the Power On switch pins, in the Front Panel header.
Plug power back into computer.
Use a small flat tipped screwdriver, and touch the two Power On switch pins. (Jewelers screwdriver works well for this application)
Power Supply comes on? Bad Power On switch.
Allow Windows to fully load, run for a few minutes; then turn the computer off normally.
Jump the two Power On switch pins again.
Power Supply comes on? You DEFINITELY have a bad Power On switch.
Power Supply does NOT come on?
We will go to a further diagnostic test then.
Awaiting results for first test, then we will go on.
Post back in a Comment.
Regards,
joecoolvette
[Also; is the computer dirty inside? ]
Feb 19, 2013 | Acer Computers & Internet
SRW224G4P slow lan
Disconnect all the LAN cables from the switch.
Power-off the switch.
Power-on the switch.
Connect one computer.
See if that one computer works "quickly".
If so, connect one more computer, and redo your testing.
Repeat.
May 23, 2012 | Linksys SRW224G4P 24-Port Ethernet Switch
We used our Dynex successfully for several months (serving 2 computers) and then, after a big thunderstorm the other night, now Computer 1 internet will only work when plugged directly to the modem....
Thanks for your question.
Given that one computer works and the other does not would tell me to change out cable to see if it fixes the issue, if not then the switch would be the issue on that particular side. Nine times out of ten its the cable itself.
Whichever the case may be you still would be recommended to try another Ethernet cable. Now the lan card inside the computer 2 should also light up when connected, so I would pay close attention to the lan card as well.
Thanks for your questions, We work for your Feedback and ratings, so dont forget to leave some feedback before you leave.
Best of luck
rulds2008
Jul 27, 2011 | Dynex 5 Port 10/100 Ethernet Switch...
I just buy a new computer and go to hook up my KVM switch that I was previously using and was working flawlessly. All cables are connected (KVM PS2) except the KVM video cable to computer # 2. So I'm...
I would look first at rep;lacing the cable itself, KVM's usually last a very long time. Cables can break down after awhile. The easiest way to check is to try the other cable on the new machine., or a pin could be bent on the cable.
I would look at those two things first before the KVM. IT is possible that the KVM may not support the new machine, depending on how old it is.
Jan 18, 2011 | Belkin 2640-FTUA 2-port KVM Switch
Computer on switch not working
Replace the switch, or never turn your computer off.
Oct 28, 2009 | ASUS (VENTO3600BLU) ATX Mid-Tower Case
Replaced ignition switch on Saturn, won't recognize new switch.
Have you tried unhooking the negative battery cable for about 30 seconds and letting the computer reset itself.
Jul 08, 2009 | Saturn SL2 Cars & Trucks
My e-machine desk top does not power up.
There is a way to bypass the switch and start the computer, just to verify that the switch is the actual problem....the only thing is it requires you to open up the computer case. If you are not comfortable doing this, I would take it to a computer shop. I don't want to see you damage your computer!
Here are the directions:
  1. Open up the computer case
  2. Find the wire that is connected to the front switch
  3. Follow the wire to the motherboard and disconnect it from the 2 pins it is connected to
  4. Take a screw driver and touch both pins at the same time (Picture Below). This will create a connection, as if you pushed in the switch and should start the computer.
Now if the computer doesn't start , then you know the problem is not the switch and will have to further troubleshoot it. If it does start, try going to e-bay and searching for a replacement switch
Feb 24, 2009 | E-Machines eMachines Desktop PC
Can's switch without it switching back to first PC
Sadly, it is probably the KVM as this particular model has a string of failures and is only rated 2 out of 5 stars on Amazon due to poor performance. :( http://www.amazon.com/Belkin-F1DK102U-2-Port-Switch-Cables/dp/B0001JXAQ6/ref=sr_1_1/105-6999807-3936431?ie=UTF8&s=electronics&qid=1187826004&sr=8-1 What I would do first is plug in Computer 2 directly to the monitor, keyboard and mouse with no KVM. If those work fine, it is probably not a computer issue; if you don't get video here, then it is a seperate issue with that PC. If Computer 2 is working, plug both computers into the KVM but switch the cables (plug Computer 1 into the KVM using Computer 2's cables). If Computer 2 shows up and can't switch to Computer 1, then it is the KVM messing up.
Aug 21, 2007 | Belkin F1DK102U 2-port KVM Switch
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
