Question about Daewoo Washing Machines
I have a Daewoo DWC-LD1013 washer machine and the machine turns on and starts a cycle but will not finish or start a drying cycle. The screen says OE and will not finish. Any suggestions?
  • 121 Answers
SOURCE: why wont my machine start drying?
you can get the manual here that should sort you out
Posted on Mar 03, 2008
SOURCE: The door on my indesit
slide in a piece of string around the door. if lock is on the right, pull round the door til the pieces of string are at left of the door and pull left quite firmly.
Posted on Mar 10, 2009
  • 73 Answers
SOURCE: My LG Clothes Washer has
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Posted on Apr 29, 2009
  • 100 Answers
SOURCE: Machine won't spin clothes dry. I've tried the
remove the lower front panel and look to see where the electric pump hooks up to a hose and than the hose to the tub probly have a small article blocking the drain
Posted on Aug 09, 2009
e-Guru
  • 3917 Answers
SOURCE: OE error code
error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.
Thanks
Posted on Dec 26, 2009
I have massage say D/Lock and I can't open the washing machine I have DWC-LD1013
The doorlock mechanism is most likely bad and will need to be replaced
Sep 25, 2016 | Washing Machines
I have a washer dryer combo DWC LD1013 it stoped drying. My clothes are more wet when put in to dry. The clothes would be extremely hot but all wet. It works 1 cycle and then stops. Please help ????
In order to dry cloths, you need two things, heat source and air flow. Sounds like you have heat but no air flow. If you can, pull unit out and check vent for washer. Look around unit and make sure there is nothing blocking any vents. If you don't see any thing, try drying with vent not installed. I run into a lot of homes with clogged vents inside walls. By drying with no vent installed, it might tell you if you have dryer problem or a home issue. Good Luck
May 25, 2016 | Washing Machines
I have a washer dryer combo (daewoo DWC-LD1412) am I able to use the dryer without having to do a load of washing?
check the hand book ( download from the net if you have lost it) you should be able to program it to dry with out a wash as you should be able to hang the washing with out using the dryer
Jun 25, 2015 | Washing Machines
DAewoo DWC-LD1013 will not spin
The Daewoo DWC-LD1013 is a washing machine, you may wish to post your question in that category, not in air conditioners.
Jan 09, 2015 | Daewoo Heating & Cooling
Daewoo DWC-UD1212 Washing Machine
Washer machine when I select manual wash , LE letter show on program monitor , and washer machine is not work.
Aug 29, 2013 | Daewoo DWDWD3011WW Front Load Washer
Machine washes but will not spin and finish the cycle, has OE or DE on screen ??
OE and DE means Open Error and Door Error.
a sensor or wire is loose or broken.
the next question is who is going to do it ? you, a repairman or service center ?
Oct 06, 2010 | LG WM1812C Front Load Washer
OE code on front load Daewoo washing machine
According to your owners manual you only have two choices...
Your lint screen is blocked or you have a problem with your drain motor (a separate device ).
Old age & experience will add a third... Assume lint did get past all those sophisticated "filters" and is presently residing inside the impeller housing... In the olden days when those housings came apart (aluminum/aluminium) I took out an entire sock and enough lint to make another... My guess today is you buy another plastic pump.
Sorry I could not get part number or price here in the USA...
Not even cleverly saying "spares" (but I did try).
Hope this was helpful.
Daewoo Washer Drain Pump Spares Yahoo Video Search Results
Yahoo Image Search Results Page
Amazon com Daewoo Dwd m301wp Mini Drum Washing Machine English Menu...
http://www.daewooelecusa.com/customer-service/service-centers
Jan 06, 2010 | Daewoo DW500M Top Load Washer
Washing Machines Logo
400 people viewed this question
Top Daewoo Washing Machines Experts
dweatherby
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
