Question about NEC Versa LX Notebook
Constantly running I bought this thing used. I turned it on and got it logged on. Something seemed to happen and now I can't shut it off from the power switch, I cannot control alt delete, it is just stuck on the Microsoft Windos XP black start up screen. Help
    Scholar:
  • 167 Answers
HELLO. FIRST UNPLUG IT. THEN TAKE THE BATTREY OUT. THEN WAIT 15 MINS. PUT THE BATTREY BACK IN. AND PLUG IT IN. AND TRY TURNING IT ON.!! AND SEE WHAT HAPPN'S. LET ME KNOW.!!! GOOD LUCK!!!!
Posted on Jun 19, 2008
Having trouble with my logging winch constantly pulling in.
service the clutch section of the winch as it appears that something is broken in that section of the winch
This situation is dangerous because if something happens, the winch cannot be disconnected or reversed immediately
May 25, 2015 | Cars & Trucks
Hotpoint rla31 motor constantly running/freezing at the back
Your fridge is cooled by the freezer, the thermostat is within the Fridge to tell it to shut off, you might have a bad fan or a build up of frost where the air is sent to the fridge, check where air goes to the fridge when it's running, if you don't feel air flow then something is up, best thing you can do is take everything out and allow the fridge to defrost, at leat 24hrs. then see what happens, if you don't feel air flow after the defrost then you fan is shot and you'll need to replace it.
Aug 04, 2012 | Hotpoint RLA31 Compact Refrigerator
Asus u52 shut down unexpectedly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 17, 2012 | ASUS U52F-BBL9 Laptop
Just bought a guf 500gig freesat recorder. Seller tells me it should be switched off at nights. Is that True? Also he tells me it is normal for the internal fan to be running constantly whenever it is...
No,the box dosen't have to be require turning it off at night.Yes the fan is constantly running,when have on power to it.No,the box have intermittent problems,it not normal for the box to lock up and shutting u out of the tv programs.If the thing still under warrenty,get a replacement box.
Nov 27, 2010 | Grundig Televison & Video
Laptop intermittent startup problems
if you need your laptop always in ready use change the time your computer is on in control panel then log off your device will be on always until you shut it down it constantly drains battery
There is a way to fix this try reinstalling windows
or just take it to software mechanic
Mar 21, 2017 | HP Compaq Presario v4000 Notebook
Laptop shuts OFF on it's own
Laptop fans DO NOT run constantly. They only turn on when booted up and once the laptop has reached a certain temperature. You should probably time how long for a shutdown, record your results. Let laptop cool for 10-15 between attempts. If it takes approximately same amount of time to shutdown between attempts it is very possible its overheating.
Other things like Viruses, software conflicts, and Harddrive problems can also be the culprit. take a look at the administrator event logs for any clue there. Event logs are in control panel under Administrator Tools.
I don't recommend trying to fix any overheating issue you may have, as that would entaiil disassembling your laptop. Unless you have a bit of experience in this, I would take it to a good repair shop.
Hope this helps you some. If so please rate my solution.
May 10, 2009 | Dell (6F858) Cooling Fan
Dehumidifier won't shut off
Well your dehumidifer runs constantly. My guess seeing how you bought a 30 pint per 24 hrs. Your house better be 400sqft. It is under sized and humidity need to be 30/50 percent to stop mold growth. It cant keep up its two small 50 pint are for 1000sqft 65 pint is 1300sqft. Upgrade now!!!!!
Dec 29, 2008 | LG DH30 GoldStar Dehumidifier
Humidifier by Hunter
if you are constantly heating the house, your heter element in the furnace is drawing in and drying out the air you are humidifying. Heat the house, and then turn on the humidifier while the heater is not running. Is your humidifier able to do your entire house (whole house) or just a small room unit?
Dec 26, 2008 | Humidifiers
Start > turn off computer does not work on XP
Some process running in the background is not letting the system shut down. Use task manager to kill unnecessary processes before pressing turn off. If it shut downs then try to locate the process using taskmanager which is causing this problem.
Let me know if it helps.
Apr 13, 2008 | Acer Aspire 3610 Notebook
Microwave buttons not responding - microwave running constantly with door shut
It seems the micro switch for the door close have moved from and is not aline the door clip or the micro switch is faulty
Dec 17, 2007 | Sanyo EM-S9515W Microwave Oven
NEC Versa LX Notebook Logo
163 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
