Question about Boating
I have a mercury 50 blueband and i cant get it in gear can you help thanks
  • 747 Answers
If you are trying to shift it while not running the "shift dog" may not be lined up with the gear, turn the prop a little should go in to gear. If the engine is running and will not shift then the idle could be set to high. On the control box there is often a small thumb screw that lifts the idle a little this may have been turned which will lock the **** mechanism for engaging gears, back off the idle screw. If you have replaced the shift or throttle cables these need to be readjusted before proper operation can continue.
Posted on Dec 14, 2010
Cant find year of my outbaord its a 50 hp mercury number A102-766
Does this help?
Locate the serial number plate by looking on your motor's transom bracket; the plate will have "Mercury Marine" written on the top. The serial number is the top number on the plate. The number directly beneath this is the year it was manufactured.
From everything I can find, yours is a 1986 model
Jun 25, 2017 | Mercury Boating
Villegar mercury 1997 have reverse gear problem
No reverse gear but forwards work ok is the most common sign of a failed transmission.
Mar 04, 2014 | 1997 Mercury Villager
50hp blueband seized
make sure its not the gearbox ! drop the box and try the engine again ! ive had this b4 !! when you used it last there was plenty of power and cooling ? easy to strip if it is seized ! please let me know more !
Feb 18, 2014 | Seloc Mercury Outboard Engine Repair...
IVE A I TECH BLUEBAND BLUETHOOTH STREO HEAD SET HOW CAN I CONNECT
Pairing your Headset:
When the headset is off press and hold the MFB until the LED alternately flashes blue and red.
Active your mobile handset’s Bluetooth function by referring to your mobile handset user quide for details.
Set the mobile handset to search for Bluetooth devices.
Select i.Tech Blueband from the list.
Enter the passkey “8888” (new devices needs “0000”) and press “ok”. Then press “connection” on your mobile.
We are always happy to assist you.
i.Tech Hellas
Sep 23, 2009 | Nokia Cell Phones
No compresion in 1 cylinder, 150 mercury outboard blueband
  • doese it make a noise??could be piston ,bore-headgasket
Sep 21, 2009 | Boating
Mercury 20Hp impeller/water pump location
It is located inside the lower unit housing. They are fairly easy to replace. Most Mercury authorized service stations will charge around $120 for this task.
Triton72
Mar 26, 2009 | Sport & Outdoor - Others
1995 Mercury Villager automatic gearbox problem.
does it start in neutral and park? if yes, linkage should be ok. The trans has it's own computer. you can buy used for about $50 from EBay or car-part.com
check this site for more help
http://autos.groups.yahoo.com/group/villagerquest/
Jan 06, 2009 | 1995 Mercury Villager
The passcode for i.tech blueband bluetooth head
PAsscode of iTech Blueband Headset is "8888"
Good luck
Aug 17, 2008 | Cell Phones
Boating Logo
60 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
