My Techko LF286BCS paper folding machine just stopped working. Can you give me some advice to get it going again
2 Suggested Answers
SOURCE: Thechko LF286 letter paper folder not working
Motor burned out.. commn fault in this model I got mine eventually from China after googling its part number.
Posted on Nov 06, 2010
Crease in paper when printing
Your information is a bit limited but we'll try anyway.
If the crease is a corner fold or a pressure line down the page, it will often be caused by something in the paper feed path close to the main drive bar in an inkjet or near the fuser in a laser printer. Have a look at the leading edge of the paper as it exits the printer for a nick or mark that may give a clue where to start looking. If there is a fold or crumple line down the length of the page, look at the paper pick up mechanism in an inkjet (usually the paper tray is a good start) or if it is a laser printer you should remove the fuser and check the fuser sleeve and pressure rollers. If you could let me know what the machine is and where the crease is I may be able to give better advice.
Jul 09, 2015 | Office Equipment & Supplies
Can a paper folding machine fold paper of different sizes or do they only work with standard size paper?
Most higher end folding machines are able to fold most standard size sheets of paper. You would have to check the manual or with the maker before trying anything too fancy. Mine works great with A4 and standard 8.5 x 11" papers.
Sep 24, 2013 | Office Equipment & Supplies
Techko shredder model #SH4205PD. The shredder stopped working. After unpluggung it and sliding the switch back and forth a couple of times it worked. Now it has quit working again. what coulf be the...
The micro switch referred to is to triggers from the presence of a piece of paper in the slot when on 'Automatic'. If this is stuck in the closed position it will easily be verified by placing a piece of paper in the accepting slot on the top of the machine. If it turns on it is stuck in the closed position. These shredders obviously get quite dirty and may simply need cleaning. Be Very Careful when working on any shredder! Also. the slide switch while basic in design has a number of wires on 8 poles and could also be the problem. As well if you these machines are protected by a thermal cut-off circuit if you overworked it give it sufficient time to cool down and reset. These are the most probably things to look at however, more in depth Dx may be necessary.
Good luck.
Mar 07, 2011 | Techko Office Equipment & Supplies
Jun 05, 2009 | Sharp Office Equipment & Supplies
Paper folder grabs too many sheets and doesn't fold accurately
Not sure what make / model you have but folders are pretty much the same. The issue with the paper feed is your retarder, also known as the paper seperator. On the feed table where you load paper there should be a pad or rubber wheel. Look for an adjustment screw. You need to close the gap enough so that it only takes one sheet at a time. The extra fold sounds like you need to adjust the fold plate stop positions just a hair. If you give me the make and model I should be able to email you a manual.
Apr 10, 2009 | Office Equipment & Supplies
Hp c6180 keeps erroring that there's no paper, when it does recognize paper
folded corner is 2 things
a) it's gettig folded somewhere along the paper path ( you would have to stop it at every step to see at what point it gets folded)
b)usually the fuser claws are the problem ( right before the exit the part that gets hot has some claws that ride ON the heat roller 3-5 depending on the machine, one is going bad )
Aug 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
Instruction Manual
Go to http;//audio.manualsonline.com maybe there you find an answer.
Jul 02, 2008 | Dahle Office Equipment & Supplies
205 people viewed this question
k24674
jasbo
jasbo
