Question about GE 24 in. GSD5500G - Multiple Color Built-in Dishwasher
WHEN I TURN ON THE DISHWASHER WATER COMES IN BUT IT JUST HUMNS REALY LOUD. OPENED THE BOTTOM AND LOOKED AND SEE FAN BLADES STOP AND TURN STOP AND TURN SLOWLY.
  • GE Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
Just os you know there are 12 models of this dishwasher and you only gave a partial model number. It is missing several digits after the last G. The symptom you describe would be applicable to all 12 models.
There are a few things that can cause this symptom.
1. Debris in the motor pump impeller (Things like toothpicks or small bones / bone fragments)
2. The motor pump seal has failed letting water into the motor bearings.
^--- These are the 2 most common reasons.
Take a look under the motor pump assembly for the tell tale signs of water dripping onto the floor under the dishwasher. (stains or a circular soap pattern) If you see a water or a soap stain on the floor the motor pump seal has failed and the only remedy is replacement of the motor pump assembly.
See the link below:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=209849&diagram_id=21603326#d21603326
Detailed view with 3 Views below link:
http://www.appliancepartspros.com/part_details.aspx?part_id=2616850
There is a possibility that the impeller is jammed with something but if the unit is 4 or more years old, most likely is the motor pump seal has failed causing subsequent motor bearing failure. It is best to remove the motor pump assembly for any attempt at clearing foreign debris from the pump impeller. Also look for a broken impeller blade during the clearing / cleaning process. If you thnk the motor can be salavaged make sure to lunricate the bearings with a paraffin based oil. We use the "Zoom Spout" Olier
http://www.appliancepartspros.com/Appliance-Parts/MAR-Zoom-spout-oiler-item-number-AP3695975.aspx
available at most LOCAL appliance parts sources.
Thanks for choosing FixYa,
Kelly
Posted on Nov 15, 2010
I noticed just as going to bed last night that our dishwasher appeared to be making a strange noise (dull buzzing sound), opened door to check and the display has the number 3 flashing, several fault codes...
check the very bottom of washer; look for something jamming the garbage cutting blades. it can be something very small stock half way in the drain causing the blades to stop turning and therefore keeps it from draining water. just an idea
Dec 16, 2014 | Hotpoint-Ariston LFT 228A 23 in Builtin...
Whirlpool dishwasher door falls open fast when opening. plastic part came off, but don't know where it is from
remove the bottom access covers on the bottom of dishwasher. turn on the dishwasher with water valve in off position so you can here the motor running,while its on, find the breaker and turn off power.you will here motor stop. disconnect power wires from power box on right hand side,then disconnect water line open the dishwasher door and at the top remove screws holding dishwasher in place. pull dishwasher out from bottom.you may have to adjust bottom adjustable screw legs. pull it out and check sides where springs are for the door to open and close. it may have came loose.
Feb 27, 2013 | Whirlpool Gold GU2275XTV Builtin...
Water not draining completely.
Clean the drain filters: click on filters
Jan 24, 2013 | Kenmore Dishwashers
GE Dishwasher - loud rumbling/growling noice!
If I am not mistaken this dishwasher has a Clean out at the bottom of the machine that can open .This is here to catch stuff like broken glass and things like that. It has a little fan like blades that act to chop up food that is to big to go down the outlet hose. also look under the machine if you can ,but in most cases you must remove 4 screws to get the bottom kick plate off, Also check all the spinning arms to make sure they are turning correctly. hope this helps
May 02, 2012 | GE Dishwashers
Does the Whirlpool Gold dishwasher have a fuse?
The fuse is in the control panel on the right hand side after you open the panels 6 screws.
The replacement fuse kit comes with a wire harness that must be used to prevent the new fuse from blowing.
Jan 24, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Sony vgn-s460: screen blinks, fan runs very loud
Possible clock timing of CPU is wrong. Is it two fan on this laptop? Maybe one is not functioning. Plus check your power supply if gives correct power!.. If none of this , it comes to the MB and possible a CAPS making problem. Need expert.
JMC
Aug 06, 2009 | Sony VAIO VGN-S460 Notebook
Water wont stop going in
You stated that your house is new. I see this frequently and what has likely happened is the installer used pipe dope to seal the elbow that screws into the bottom of the dishwasher water valve. They should have used Teflon thread tape instead as the pipe dope will get into the diaphram in the water valve, clog the tiny holes in it and ruin the water valve. The valve on the dishwasher will need to replaced. Hopefully the company that takes care of the warranty doesn't charge you for it. They should back-charge the installer.
Jan 01, 2009 | Dishwashers
AC make loud noise on power off.
Is this a wndow unit or central air system? if this is a window unit , your problem is it only needs cleanning (dirt dbber nest-- trash around the back blades-- or the unt is twisted and rubbing the fan shroud. Last but not least, the slinger ring around the back blades (a ring around the end of the blades thats picks up water in the bottom of the unit and sling it on the coils to help cool the hot gases....Thank-you Thank you Thank you very much!
Jun 02, 2008 | Heating & Cooling
GE 24 in. GSD5500G - Multiple Color Built-in Dishwasher Logo
118 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
