Question about Kinyo SA-201 Computer Speakers
How to fix shortage in speaker - Kinyo SA-201 Computer Speakers
Amp blowing fuses
Then there is a defect in or on the amp, causing it to use a too high current. Stop putting in new fuses, till the amplifier is repaired or the shortage is removed. Could be a speaker cable has a shortage, or even some (older) amps could start oscillating when a speaker was removed, also blowing the fuse.
May 03, 2015 | Audio Players & Recorders
I have a pg 15:01 when I hook it up it goes to protect with a red light and pops my fuses can someone please tell me why so I can fix it
If fuses blow, there must be a shortage. Could be your speaker cables are damaged, or perhaps if there is an electrolytic capacitor in the end stage it is defect. Also the last transistors in the end stage can be damaged.
Start with checking your speakers and speaker cables. Then check the end stage of the amp.
Jun 26, 2014 | Car Audio & Video
How to get amp off of protect mode
To remove the thing that made it go into protection. Disconnect the cables and test them on shortage. Be aware your speakers ar only about 2 or 4 ohms, but anything less, could indicate there is a shortage in your cabling or speakers.
Jun 12, 2014 | Kenwood KAC-7202 Car Audio Amplifier
Tutorials to fixing cord shortage from hair straightener
Buy a new one they c aren't expensive.....too much to fix .....
Sep 24, 2013 | Health & Beauty
My dell pc was shut dwon becoz of power shortage.now i can hear the voice of my chat mates but they cant hear me
So if it it was by power shortage, then you have to seek a technician's help, it probably destroyed your hardware due to the power interruption.
Mar 22, 2011 | Dell Audio Players & Recorders
Will not turn on and smoke coming from external speaker jack and pa jack, i gues that is the only place to get out
if you smell something like burned plastic i am afraid you have had a shortage inside your cb. most of the time that means certian death for electronic. if you now of a cb repair shop they may be able to fix your problem.
May 04, 2009 | Cobra 29 LTD CB Radio
My mache speakers sound weak in my 99mustang
check the wire some times a little pieace of wire is touching the other one.swap the wires with the other one to see if it is the wire? if so replace wire.faulty bridgeif it works when you shake the wires and it turns on. open amp if you have to to see if the bridge is loose or melted do to excessive heat or shorting out
Feb 28, 2009 | Car Audio & Video
Psw1200 paradigm sub woofer
If your fuse keeps on blowing after you cg=hanging,that meens that there is a shortage.check it first using the multimeter.good luck.
Dec 28, 2008 | JBL PSW1200 Speaker
Shortage
depends where the shortage is, if you can describe it for us i can help ya.
Oct 28, 2008 | Microsoft Wireless Network Adapter Xbox...
Kinyo SA-201 Computer Speakers Logo
166 people viewed this question
Top Kinyo Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Jerry Umali
Larry Chandler
Are you a Kinyo Audio Player and Recorder Expert? Answer questions, earn points and help others
