Question about Lexmark P6250 All-In-One InkJet Photo Printer
Printer will not print showing error 2200. How do l fix it?
  • 2,069 Answers
This is a scanner error. You could try the following...
Power off and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off and remove the power supply from the back of the unit.
Open the top cover
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Posted on Nov 15, 2010
I have Lexmark p4350 I can not copy, and show error 2200
According to the Lexmark site the 2200 error is a jam, possibly the scanner. Try unpluging the power at the printer, remove the paper, and see if there is any paper stuck in the unit. Another possibility is the cartridges are messed up. If you don't find paper stuck, remove the cartridges, and reinstall the color one. If the error goes away, the black cartridge is possibly bad. Another problem you can't fix, which is the scanner glass cracked. In that instance or if the cartridge swap doesn't work, contact Lexmark to fix the unit.
Sep 18, 2014 | Lexmark P4350 All-In-One InkJet Printer
A code 2200 is showing and my copier will not copy. How do I address code 2200?
The 2200 error code indicates that the scanner has stalled. It could be due to the cartridges or the encoder strip (transparent strip seated behind the cartridge carrier) has gotten loose from its position. Please follow the steps below to identify and fix the problem:
  1. Open the printer cover and remove the cartridges. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then slide the carrier to the center for the loading position.
  2. Check the encoder strip and make sure it is secured in its place.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply (black box where the power cord is plugged in at the back of the printer) and put it back after 30 seconds.
  5. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  6. If no error appears, reinsert the other cartridge. Close the printer cover.
  7. Replace whichever cartridge is causing the error to appear with a new cartridge.
  8. If no error appears, try to print a document again to verify that the problem is fixed.
Feb 02, 2012 | Lexmark X7170 All-In-One InkJet Printer
Show error 2200
The 2200 error code indicates that the scanner has stalled. That's why you're not able to make a copy. Please refer to this article on the Lexmark website to fix the problem:
2200 Error on the Lexmark X7100 Series All-In-One
Should the error continue to display, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Dec 11, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
It does not copy or print it displays error 2200
The error indicates the has stalled or jammed. This article in the Lexmark website on 2200 Error on the Lexmark X7100 Series All-In-One might help fix the problem.
Mar 21, 2011 | Lexmark X7170 All-In-One InkJet Printer
I need a hard disk drive for a cannon 2200 imagerunner the copier keeps showing a error message
If you have a Service Contract with the local CANON office, call them, and get them to make a service-call to fix your printer.
Jul 17, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error 2200 with Lexmark x7170
Here's an article in the Lexmark website on 2200 Error on the Lexmark X7100 Series All-In-One. Just click on this link for instructions on what to do: http://bit.ly/deHk7F. Hope this helps but if all else fails, don't hesitate to contact Lexmark Technical Support for further assistance.
Jun 07, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error 2200
Here's a link to the Lexmark website to guide you on what to do when havine Error 2200 on the Lexmark X7170 printer. http://bit.ly/b6mEyP. Just follow the instructions carefully. Hope this fixes the problem but if all else fails, I strongly suggest you contact Lexmark Technical Support for further assistance.
May 15, 2010 | Lexmark X7170 All-In-One InkJet Printer
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Dell AOI printer 962 showing error 2200 when trying to scan or copy. I have tried disconnecting and re-installing but have been unable to fix it. Can anyone help ? Mac
go to printers find dell aio 962, right click propertys, check 1st it is set to the right port, usb, paralell which ever the printer uses and that bidirectional support is enabled.same prop. page click advanced and be sure start printing immediately is checked then ok and try printing then. if no prob here then you may have a bad driver, a bad cable or a bad printer.
Jul 26, 2009 | Dell Office Equipment & Supplies
Lexmark P6250 All-In-One InkJet Photo Printer Logo
69 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
