Question about Vacuums
Teac Radio - Model No CRX2601 I have lost my manual can you tell me how to change the hours and minutes on my radio.
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 | Vacuums
I have just purchased a second hand AWA CRD176X CD Clock radio that did not come with a manual and I am having trouble setting the time, alarm time etc. Can you please help out at all. Thanks in...
Hi Chris, is this the one?
Like most of this type, it should have a button named TIME, and another one named ALARM.
Then there should be one button named HOUR, and another one named MINUTE.
With the radio turned off, press and hold the TIME button, then tap the HOUR button until you reach the current hour, AM or PM.
Release the TIME button.
Press and hold the TIME button again, and tap the MINUTE button until you see the correct minutes.
Now repeat the same operation with the ALARM button, to set the time the buzzer or music should come on.
If you have any further questions please email me.
Subject: AWA CRD176X CD Clock radio
faxmando@yahoo.com
I can't make out the names of the buttons or functions from my image, so if you need any extra information, please send me a clear image of the top and front of the radio.
Thanks!
Jerry
May 30, 2011 | Vacuums
A friend gaave me a Multi-rice cookerl She had lost the manual, and I don't know how to use it. No recipes, cook times. or any directions. Can you please help me?
I need make and model number. Generally you use a cup of rice and all 1 1/2 cup of water. You have to soak the rice for at least 30 minutes. It should take about 20 to 30 minutes to cook the rice. This is for sticky white rice, brown rice you should soak it at least 1 hour.
Apr 04, 2011 | Vacuums
WE CANNOT CHANGE THE CHANNEL ON RADIO IT HAS DEFAULTED TO RADIO ONE AND THERE DOES NOT APPEAR TO BE ANY WAY OF CHANGING IT TO RADIO TWO HELP PLEASE!
I was never too fond of Jimmy young however Try switching of unplugging for a few mins then try a new auto scan this will search for available frequencies ,which I hope picks up Radio 2 in your case..Good luck
Feb 22, 2011 | Vacuums
I have an older model rca cd clock radio dual alarms. I cannot find my instructions for setting the clocks time. The batteries were dead when the electricity went off. Now the time keeps flashing the time.
For most clocks of the RCA clocks without a clock or time set button, press Set until you see the clock icon. Press the fwd or rev button to change the time. Release the button when you reach the correct time. (AM or PM will be indicated next to the time.)
There are manuals for several RCA cd clock radios available from their site: http://support.rcaaudiovideo.com/select.aspx?u=manual . Check if your specific model is listed in the menus.
I hope this helps.
Feb 03, 2011 | Vacuums
How do i program my radio shack pro 71 scanner
Hello John. Here is the link to your owner manual and other documents radio shack provides for this model. http://support.radioshack.com/support_electronics/52330.htm
Joe
Nov 15, 2010 | Vacuums
I have an old kenmore canister 116-model 52612200 how do i change the belt i can't take apart the housing and have lost the service manual. any help would be awesome bg
I was unable to find a pdf manual that could be downloaded. I guess Sears wants money for the manuals.
Call 1-800-366-7278 and tell them the model number and they will sell you a manual.
Oct 02, 2010 | Kenmore Vacuums
How do you set the time and alarm on a Zenith Z1261S??
body{padding: 10px;}#Post p {margin: 0px; padding: 0px;}#Post ul{padding: 0px;margin: 0px;list-style-position: inside;}The time settings is under the top panel of the clock-radio. Turn the device to the back. There are two screws at the top and a message saying unscrew them to take off top. Remove the screws and take the top off. You might have to pry it off a bit. There are white buttons underneath the plate. Press the "time" button and then use the back-forth buttons on the front to adjust the time. You have to adjust the time minute-by-minute. There is no hour button. You have to keep holding down the forward-reverse keys until you get to the right time. Replace the top panel and screw in the screws to put back together. You might have to open the CD door to pull the panel through the front catches. And that should do it. (By the way, this is a hotel clock radio, not a vacuum cleaner!)
Aug 22, 2010 | Vacuums
I'm using my dad's old Panasonic RC-6064 alarm clock. How do I set the time and the alarm?
The Hour/Minute buttons are on the bottom of the radio. Just press the hour or minute buttons to adjust the regular time. Alarm is the same but you hold the alarm button on top.
May 18, 2010 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
