Question about Gateway Convertible CX2620 Notebook
I have a gateway convertible notebook and the screen is no longer working.. it turned red on start up and then black.. i am currently using a monitor which works, and sometimes if i switch back to the screen it does show up red for a moment or two but then goes back to being black.. the touch screen part still works.. does the whole screen need to be replaced or do you think it is something small like a wiring issue.
  • lilbutloud Nov 15, 2010
    its a touch screen convertable notebook.. i can still use the screen as a touch screen and have it show up on the monitor.. and you are indeed correct.. the monitor would not be working if my video card was bad.. that much i know.. but since i can use the pen it came with for the touch screen and that still works im wondering if a internal cord has a kink or if there is a special light or something that needs to be replace.. but i dont know that much about these notebooks to know what the problem would be.. and i dont want to pay to have a computer tech assess it.. lol
  • Gateway Master
  • 32,281 Answers
The problem is a back light problem and could be caused by a faulty inverter or most likely a faulty CCFL lamp. Please click on this link to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Nov 15, 2010
Testimonial: "wow thanks so much that was pretty helpful.. im going to the link right now.. my dad thought it might be that light but we were unsure"
    Master:
  • 397 Answers
I suspect that it is probably a bad screen- you mentioned that one display does work, so it's not likely the video card. However, you can try reseating the cable- but the behavior you're describing does sound like a bad display
Gateway M275 display scambles
I suspect it may be a problem with the video cable coming from the convertible tablet, up through the hinged support for the LCD screen, AND/OR the screen Inverter.
I would like you to connect a VGA monitor, to the VGA port on the back of the convertible tablet. The VGA monitor will now be an External Monitor.
[ Looking at the rear of the convertible tablet, start at the Left side.
Vent, USB port, Monitor port. The Monitor port is the VGA port ]
The VGA monitor can be a CRT type, (Looks like a small TV), or a flat LCD screen monitor with a VGA cable.
Notebook OFF, monitor OFF, connect the VGA monitor to the M275's VGA connector. (Port)
Turn the monitor on. If a CRT type, allow it to warm up.
Turn the notebook on.
By the factory default settings, whatever is shown on the convertible tablet's internal monitor, should now be shown on the external monitor.
(VGA monitor)
If not, press, and hold down on the Fn key (On the bottom row of the Keyboard, all the way to the Left), and tap once on the F3 key.
(Top row of Function keys. The F3 key is the Display Toggle-Over Key )
No graphics shown on the external monitor? Hold down on the Fn key again, and tap the F3 key again.
There are at least three options available;
1) Convertible tablet's internal monitor - ONLY
2) Convertible tablet, AND external monitor
3) External monitor - ONLY
If graphics are fine on the external monitor, you have a problem with the video cable, and/or the screen Inverter. At this time we will bypass the LCD screen, and come back to it.
At the bottom/middle of the tablet's LCD screen, is the Hinge. The Hinge Cover is 'T shaped', and has one single Philips screw holding it on.
If you remove the screw, and the Hinge Cover, you will see two wire harnesses.
One Black, the other White.
See that these two cables are plugged in tightly to the connector.
After checking this step come back in a Comment, and state your findings.
Regards,
joecoolvette
[ Additionally;
Here is the Service Manual (Free) for the Gateway M275 Convertible Tablet,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Where it states - Gateway 400, go down to the second line, and across to M275. Left-click on M275.
This is a PDF file. It may take up to 30 seconds before the first page comes up.
Dec 11, 2011 | Gateway M275 Tablet PC
Gateway monitor issues, "FDP2275W TFT
This model is know for having bad caps problem as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/GATEWAY/Gateway%20FPD2275W/
That will be the first place to inspect, you MUST be real carefull when opening up this monitor since you can easily damage the ribbon cable attached to the front bezel.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 26, 2011 | Gateway FPD2275W LCD Monitor
I have a gateway m285-e tablet pc. I turned my computer off then 2 days later when I turned it on it appears to have a dead screen. I tried connecting an external monitor and switching to it via FN+F4...
Yup that is the Screen's back light inverter or CCFL(the actual light).
Here is sites which well the inverter for your model: (this is the cheapest I found in a short time but keep looking)
http://www.pelltechnology.com/Gateway/Laptop/Gateway-M200-Series-Notebook-M285-E-SB-Convertible/Gateway-M285-E-SB-Convertible-Notebook-Backlight-Power-Inverter-P4513.asp
Here is a video that might help ya:
Just pay attention to the dismantling not the screen replacing, once you open up the screen its pretty self explanatory how to replace it.
If you have anymore questions comment or send me a msg.
Hope this help, If it does then please, remember to leave Feedback/Testimonials.
Mar 22, 2011 | Gateway M285-E Notebook
Gateway ml6731 black screen
It is possible that it is the main board or motherboard that is having problems. it is possible that the video card is having troubles.
Jun 05, 2010 | Gateway ML6731 PC Notebook
Gateway PC Notebook/Tablet Model: CX2618 Monitor Replacement
First shine a flashlight on the screen. if you can see a very faint image on the screen the problem is the backlight. If not... it could be a few other problems, first test if it works on an external monitor. If it can then you need to cleear the CMOS. to do this you unplug the cord remove the battery and hold down the ON button for 30-60 seconds, then turn it on. If it does not work on the external monitor it is probally because you have a bad video card and need to replace it.
Jan 28, 2009 | Gateway CX2618 Notebook
Black Screen
Look in the back of the Gateway where you currently have the video cable connected. If there are two connectors, (Side by Side) there than disconnect & re-connect to the other. Your display should come up. Don't be fooled. Most Pc's that have no display on their monitor is not a monitor problem but a computer problem.
Feb 08, 2008 | Sony VAIO VGC-V617G PC Desktop
MY MONITOR TURNS ON AND AS IT SAYS STARTING ANALOG, IT IMEDIATELY GOES BLACK BUT FOR A SECOND I CAN SEE XP STARTING
Then ther is problem with your ram,please change your current RAM and upgrade it to newer one...
Dec 31, 2007 | Gateway FPD1760 17" LCD Monitor
Computers & Internet Logo
157 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
