Question about Dayton E51 Oil Filled Utility Heater
Heater works fine but you have to give the fan a little push in order for the unit to start.....can you help?
    President:
  • 1,654 Answers
This doesn't have an easy fix to it. Sounds like the fan motor is very weak, probably the brushes in the motor are worn out and I doubt you can replace just the brushes. Probably have to change out the fan motor. Good news is these  are common heaters and parts should be available. Try Grainger on line or even Dayton on line and see if there is replacement parts for the fan.
Top of Form
Dayton heaters at one time were manufactured by DESA or a predecessor and labeled DAYTON for Grainger. I have been unable to find any specific reference material to "Dayton 3EV51".
There were 2 types of motors used. I suspect your heater has a starter relay. The solid state relay was used to allow the energizing of the start winding which would allow the motor to achieve approx 80% of rated speed, then the relay would de-energize the start winding to prevent overheating. The relay is not attached to the motor, except for the wiring.
This is what the starter relay looks like. If yours has one check to see if it is energizing the starter windings at start-up. If not it is probably defective. The part is still available at www.reddyparts.com, I think, but today's replacement part looks slightly different.
If your motor does not have the relay, then the motor has an internal start-up system which is not serviceable, but the motor is probably still available. Most of the time the motor's part number is printed on the label.
Posted on Nov 15, 2010
  • Dcramer531
    Dcramer531 Nov 15, 2010
    Sorry the picture for the relay did not come out. It is a small black rectangle box with 2 screw in hte top and 2 mounting screw on the bottom. It has 4 lines of numbers and letters with p being the firts and 42 being the laas digits on the numbers. If you need this part I can get you the numbers, but it doesn't sound like the relay to me.
In order to start heater I have to open it, turn it on, and push the fan. This is the 2nd heater I have had with this problem.
would help if you stated hours use on item.
try lubricating the fan motor. take it apart, grease or heavy oil
like 90wt gear lube
Jan 01, 2013 | All-Pro Kerosene Garage Shop Heaters - All...
The blower fan on my AC/Heater isn't working properly.
check the capacitor on the moter or just replace 12.00 bucks. if it doesnt work you need new moter.
Oct 23, 2012 | General Electric GENERAL ELECTRIC...
I have a rinnai heater and it stopped working all
rinnai, toyostove and monitor heaters are basically all the same. first you have to make sure your fuel valve is open at the tank. next you have to reset the tank lockout on the sump. then set your set point higher than your room temperature. now press on. the unit will go through a 300 second purge cycle. the pot heater should turn on when the purge cycle starts. after the purge cycle the fuel pump turns on and pumps fuel into the pot. when it vaporizes the igniter lights it. when a flame is detected the flame rod says ok to keep running so the fuel pump shifts into high speed. when plenum temperature reaches a preset level the fan turns on.
Oct 17, 2009 | Rinnai Toyostove Direct Vent Heater:...
2002 S type 3.0. The heater not working
Heater control valve faulty,
Air lock/blockage to heater matrix,
control unit voltage sender.
Check the above in this order. I assume you are operating heater control functions correctly and the heater display is showing no unusual infor.?
hope this helps. good luck.
Oct 01, 2009 | 2001 Jaguar S-Type
Air condtioning unit outside fan will not move
Sounds like the motor start capacitor is gone south on you. you can get them at a motor rebuilder.
Jul 12, 2009 | Coleman Propane Forced Air Heater...
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
Combustion fan and circulating fan running and no heat
Check near the squirrel cage fan and see if there is a sail switch.  Sometimes these are used to confirm air movement prior to firing off the gas furnace.  It is simply a square piece of metal on a stick that attaches to a microswitch.  This switch is then depressed when the fan pushes the air (and the metal piece) allowing the burner to fire off.
Hope this helps.
Feb 03, 2009 | Goodman GMS90703BXA Heater
Heater won't start
Thanks for your question,
Sounds to me like you have a faulty fan in the unit, could be stuck, or might be a bad fan motor, try unplugging it first, find something to insert where the fan is and try spinning the blade, if its stuck or has alot of resistance, then you have a bad motor, if its free spinning, then try plugging it back in and see if it works, sometimes just by manually moving the motor shaft it frees it to work, if it still doesnt work, then you might look at replacing the fan motor, or replacing the unit, hope this helps ya,
mr.grzz
Jan 25, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Dayton E51 Oil Filled Utility Heater Logo
108 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
