Question about Texas Instruments TI-83 Plus Calculator
In the TI-98 Titanium calculator, the default for log is 10, how do I either change it to base 2 or how to do I enter values to make it base to. eg: log(9/14) = -.637
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
To compute a log to any base, enter it as log(x, base). You can either select log from the catalog or simply type it in.
Posted on Nov 15, 2010
Change base log
The TI 86 has two logarithmic functions: natural logarithm (ln) and common (decimal) logarithms (log). If you need the logarithm in any other base than e or 10 you need to use one of the two equivalent expressions
log_b(x) =ln(x)/ln(b) =log(x)/log(b)
Here b is the value of the base of the logarithm and x is the argument (the value whose logarithm you are seeking). Of course the argument x must be a positive number.
Note: On the TI 86 the log function can calculate the logarithm of a complex number, according to the manual.
Sep 22, 2013 | Texas Instruments TI-86 Calculator
Where can I find the log values in TI 89
For natural logarithms, you can use the ln function (2ND shift of the X key). For example, the natural logarithm of 3 is 2ND [LN] 3 ) ENTER.
For logarithms to other bases, use the log function (diamond shift of the 7 key). For example, the base-2 logarithm of 16 is diamond 7 1 6 , 2 ) ENTER. If the base is 10 (common logarithms), you can omit the comma and the second argument.
Mar 09, 2011 | Texas Instruments TI-89 Calculator
How do you enter the log base on the TI 89 Titanium?
If you want to take the log base b of x, enter it as log(x, b).
To get log, you can either type it in or press diamond 7.
Nov 23, 2010 | Texas Instruments TI-89 Calculator
I am trying to figure out how to enter negative logs into the TI-30XA. I have a chemistry exam on Tuesday and we need to be able to do problems with the negative log and I can't seem to find any...
Use the +- key to the right of the decimal point to enter negative values and to change the sign of an existing value. For your sample:
2 EE +- 3 LOG +- =
Nov 15, 2010 | Texas Instruments TI-30XA Calculator
How do I calculate pH from H+ concentration on a ti 30a? [H+] 1.2 x 10 -5 M = ? pH = 4.9 I worked out pH to concentration but struggling for the opposite figured it out once and...
You calculate the pH with the relation
pH=-log(c) where c is the value of concentration in mol/L.
ex: c[H+]= 3.57x10^(-6)
pH: (-) [LOG] 3.57 [2nd][EE] [(-)] 6 [ ) ]
Here you have 2 change sign key press [(-)]
If you have the pH, and want to calculate the concentration that yields that value of the pH you proceed as follows
c= 10^(-pH)
Ex pH=8.23
c: [2nd][LOG] [(-) 8.23 [)]
General shortcut.
If concentration is of the form c[H+]= 1*10^(-a) where a is an integer between 0 and 14, the pH is equal to the positive value of exponent.
Ex:c[H+]=1x10^(-5) Mol/L then the pH is just the positive value of the exponent, ie 5 because pH=-log(1.x10^-5) =- log1 -log(10^-5)=0 -(-5)=5
Above I use the rule log(axb)=log(a)+log(b) , the rule log(a^b) = b*log(a)and the facts that log(1)=0 and log(10)=1, the last being true if log stands for log in base 10.
May 20, 2010 | Texas Instruments TI-30XA Calculator
How to use antilog?
As you well know the pH is the negative of the log in base 10 of the H+/H3O+ ion concentration. If we use [H+] to represent that concentration, then pH=-log[H+].
To obtain the [H+] you need to calculate the antilog. You write the definition in the form log[H+] =-pH and then calculate 10 to the power of each member. The equality remains valid as both members are treated similarly. Thus
10^( log[H+] ) = 10^(-pH)
Since raising 10 to a power is the inverse function of taking the log in base 10, 10^(log(x))=log(10^(x)) = x (they are inverse of one another), you are left with
[H+]=10^(-pH)
Your calculator has a function [10 to x] accessed by pressing the [2nd] function key. To use it you must enter the negative value of the pH, press the [2nd] function key then the [10 to x], then the = key to get the result (concentration)
Exemple: let the pH=5.5, what is the H+ concentration?
With [(-)] being the change sign key, then
[H+]:[ (-) ] 5.5 [2nd][10 to x] [=]
The result is 0.000003162 or 3.16 x 10^(-6)
Hope it helps.
Dec 07, 2009 | Texas Instruments TI-30XA Calculator
I need help with a change of base formula problem.
It's simple here some logs:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
you just need to know that the default base of log in calculators is 10, so log x mean
log x base 10 = log x / log 10,
so write log x / log y for log x base y example:
log 8 base 2 = log 8 / log 2 that is how you write it on calculator, hope it was helpful
Jul 01, 2009 | Texas Instruments TI-83 Plus Calculator
How I can get the log base 10 number in a TI 89
"♦" "7" will give you log base 10 for the texas instuments TI-89 Titanium
Feb 20, 2009 | Texas Instruments TI-89 Calculator
Antilog in chemistry problem
pH is minus (log to base 10) of the hydrogen ion activity of an aqueous solution, or (log to base 10) of (1/hydrogen ion activity)
To get the inverse log, i.e the hydrogen ion activity corresponding to a specified pH, simply enter the pH value and press
2nd
LOG
1/x
Answer 0.001
Apr 22, 2008 | Texas Instruments TI-30XA Calculator
Ti89 titanium
WHAT IS THE KEY OR KEYS TO GET THE INVERSE LOG FUNCTION?
Apr 02, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-83 Plus Calculator Logo
362 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
