Question about Electric Bicycle Motor, Bike,electric Bicycles ,kits
Back wheel appears locked wont turn, was working OK, I didn't ride it for a week, battery was flat , recharged, but back wheel appears siezed.
  • 23 Answers
Check that the brake is not jammed on either at the lever or at the rear wheel. Some levers have a pin you push to lock the brake.
If the brakes are OK then check there is nothing stuck in the chain or sprockets.
Posted on Apr 07, 2011
Craftsman yts3000 riding mower
Probably wheel will turn individually but try both at same time and they will probably not move. Am sending you diagram of tranny maybe it will help.
Oct 02, 2017 | Garden
My key won't turn and my steering wheel is locked.
push your foot on the brake pedal and try to put it into park, then turn steering wheel at same time as you try to turn key
Apr 02, 2013 | Cars & Trucks
I have a 1998 cavalier. My back wheel on drivers side was locking up so had a wheel cylinder replace and a brake line by just someone, then that didn''t help so I took it to all stars and they did...
its possible that the seals in the wheel cylinder were damaged from the previous problem when it didn`t fix the problem.was the replaced seal a new one or a used one that the someone installed or the seals were defective from the manufacture.also were the brakes shoes cleaned of the brake fluid that was on them from the original cylinder leaking on them as this can cause the brakes to lock up,as well as if the brakes are not adjusted properly can cause this as they will catch and turn with the drum until it can`t rotate any more causing the brakes to lock up.as far as the hardware missing then the person that replaced the wheel cylinder didn`t replace everything that they took off or didn`t know what was suppose to be there as far as parts.
Aug 09, 2011 | 1999 Chevrolet Cavalier
John deere 68 riding mower steering column won't turn wheel assembly via arced toothed plate. Wheel assembly OK and greased. Some minor play when rotating steering column with steering wheel, but appears...
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Sep 27, 2010 | John Deere Garden
Cordless Battery-Powered Soldering Iron wont turn on anymore
You can replace the battery with other new batteries, that way, you can tell whether it is the rechargeable batteries or the iron that are faulty.
Mar 09, 2010 | Weller BP860MP Dual Heat Battery Powered...
1992 Pontiac GrandAm has power brakes, front disc, back drums. Everything worked fine up to leaving the car sit on the street for 2 weeks, now back brakes seem to lock up at the slightest touch of the...
Sometimes a caliper or wheel cylinder will sieze, usually temporarily. This puts twice the amount of pressure on the other side of the system. Recommendation: turn your car on, take off the parking brake, and press really hard on the brake pedal. This will usually break the offending piston free, and you will be good to go for a long time. If this doesn't work, then you'll have to figure out which one it is, and change it out. Hope it works for you.
Dec 01, 2009 | 1992 Pontiac Grand Am
Battery light comes on when driving
SOUNDS LIKE THEY MAY HAVE DISCONNECTED THE ALTERNATOR OR PULLED THE CONNECTOR LOOSE WHILE DOING THE CLUTCH.
Nov 06, 2009 | 2001 Ford Focus
I think my wheel cylinders is locked up but i'm not for sure
pull the wheel remove the drum and check thats the only way to know for sure. Also check to see if your e-brake locked up. Chances are your riding on the shoes and it got damaged inside
Sep 11, 2009 | 2001 Dodge Neon
Electric Bicycle Motor, Bike,electric Bicycles ,kits Logo
162 people viewed this question
Top Electric Cycling Experts
Eric Hidle
Level 1 Expert
Colin Stickland
Colin Stickland
Are you an Electric Cycling Expert? Answer questions, earn points and help others
