Question about Whirlpool Dryers
MDL WED9600TAO WHIRLPOOL DUET STEAM - THE TEARDROW TRIM\r\nAROUND THE DOOR AND UP INTO THE CONTROLS IS LOOSE AND HAS THREE SMALL "CLIPS (?)" STICING OUT BUT I CAN'T SEE HOW TO REATTACH THE CLIPS TO THE TRIM PIECE.
  • wesley_fitzp Nov 17, 2010
    doesn't seem likely, the clips are metal.
  • 347 Answers
This was a very poor design from the factory ..The clips attach to the trim ring at the factory by plastic welding (MELTING) them in place to the stanchion's, in working on many of these sometimes you can super glue them back in place, but you will have to remove the trim ring completely to do it. other times i had to just replace the entire ring as it was to far gone to repair Just a bad design guess they didn't think it would ever have to be taken apart
Posted on Nov 17, 2010
    New Friend:
Factory warranty??? should be
Posted on Jul 11, 2016
Why will the washing machine door not unlock?
Sounds like you have a broken door lock, or a wire harness is loose or disconnected. Also make sure the door seal is not out of place.
May 01, 2014 | Whirlpool Duet Steam 4.1 Cu. Ft. Front...
Whirlpool duet door locked cannot open it
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer door is locked on the Duet Series. Tried all the basics but still nothing.
Dec 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Take off whirlpool duet front panel for filter
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer door will not stay latched and causes dryer
ew whirlpool duet steam dryer door will not stay latched and causes dryer to stop
Dec 20, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Mt front load duet whirlpool is locked full of water
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet dryer says control locked any idea what to
The following link explains how to correct a Control Lock problem on a Whirlpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not correct the problem, please let me know. I hope this helps.
Jul 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to remove the front door of a 2000 toyota sienna
  1. Remove the phillips screw that holds the door handle trim piece (under the door handle)
  2. Remove the phillips screw at the upper front under the small round trim cap. Pry gently around all sides of the cap, prying a little more each time.
  3. Remove the arm rest by forcing it up with a screw driver. Start with the end towards the front of the car. Start prying at the front edge and next to the door panel. The arm rest has two clips (one at front edge and one about three inches back. Once the two clips are loose the arm rest flips towards you which unhooks the back two prongs.
  4. Pry off the control panel. This trim piece has a metal clip that you need to press from the front edge. There is a small indent to allow a small screwdriver. Don't use a screw driver! Use a thin putty knife, but a scredriver will work. There is a lip that the knife will catch on and release the trim. The back of the trim has a fixed clip, so unless you release the front clip it ain't gonna budge! Then unplug the attached wires.
  5. Now remove the 2 screws that appeared once the arm rest is off. I think that's all the screws. Pry the bottom of the panel away from the door starting at the bottom back corner (you will feel where there is resistance) and the plastic retaining clips will pop loose one after the other.
  6. Your panel should now be completely loose on both sides and the bottom, held on only by the top lip (that is supposed to lift off) and the door handle trim
  7. The door handle trim is a little tricky but once you know its not that hard. First of all its held it place by two clips. One is directory over the lock switch and one directly under it. Carefully pry underneath the trim in both of these location and twist the screwdriver to pop off the clips. There is still a hook clip nearer the front of the trim so to pull off the trim you have to kind of pop out the two clips while pulling towards the rear of the car since the hook clips slides out towards the rear.
  8. Once that is off its just a matter of lifting the whole panel up until it unhooks from the top of the door.
Jun 01, 2009 | 2000 Toyota Sienna
I need to remove the drivers internal door panel
Remove plastic studs from door closer. Unscrew three retaining screws. remove grab.
Unhook window winder retaining clip. Best done with small long-nose pliers. window winder retaining clip located inside plastic winder handle section. Will need to prise away winder handle from door slightly to expose clip. locate and gently pull clip from winder shaft.
unscrew door opener / lock assembly retaining screw.
gently prise lower trim retaining press studs from door. remove lower trim.
gently , from rear of door, pull upper trim from door and similtaniously prise upper trim press studs from door.
gently giggle door opener / lock assembly through upper trim . remove trim
gently with flat blade, peel off plastic dust sheeting.
access to inside off door is now possible.
Reassembly reverse of above
Cheers !
ozzy11
Feb 04, 2009 | 2001 Suzuki Swift
Searching for a clip
Iwould asssume your lookin for number 32 on the door nd latch breakdown, you can call hyour local part distributer for ordering info
#32 8181929 Clip, Trim
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208180440.pdf
Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
417 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
