Question about Samsung SCX-4300 Monochrome Laser Multifunction Printer
What does 'jam 1' mean, where should i look for the problem in the printer itself please?
  • skimble04 Nov 15, 2010
    the complete error message is "jam 1 or install toner", but as far as i can tell the toner is inserted correctly, but there is still a paper jam somewhere. But where, and what does 'jam 1' mean?
Remove the toner cartridge and then reinstall it. The connecting leeds are not properly connecting to your toner. Now press: Maintenance > Of clear Of setting > Of all Of setting [OK] In the service menu (TECH MODE) MENU> Of data Of setup > Of clear of count > Of clear Of all CNT
Posted on Nov 15, 2010
  • Samsung Master
  • 3,267 Answers
Toner is not properly inserted or paper is jammed.
    Genius:
  • 1,354 Answers
You need to open the service menu:
Menu->Copies -> Left arrow -> right arrow ->Menu -> right arrow.
"Rdy Tech" will be displayed. Now press "Menu" then move to "Data setup", then "CLR CNT" , then "CLR all CNT".
Note:This will work only if you had reset you printer with the reset software
Hello, my name is sugeng arifai,,, i'm from indonesia...sorry,but i'm cannot speeking english.... printer canon mp 198 Error 6000? help me please mr.?....
Hi, this error code means that either one of the trouble has occurred:
Either there is a "Paper jam" in or "General malfunction" in the printer..
there might be some pieces of paper or dust in between the rollers. please carefully examine roller area and take a good look into rollers.
And than Try to reset the printer to erase memory code errors.
1. Press Resume button and hold it for 1 - 2 minutes
2. Open the cover
3. Remove the cartridge and then put it back again.
4. Close The Cover
5. Turn Off the printer wait and then Turn it On again
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I have a paper jam i cannot find on a kyrocea fs-1300d any suggestions how to find and correct this problem?
Hi
1. Paper jammed can be found in the paper tray. Just remove all the paper and inspect paper jammed from the feeder roller.
2. Paper jammed can be found in the toner cartridge compartment. Remove the toner cartridge and inspect for paper jammed.
3. Paper jammed can also be found in the rear door of the printer (back door of the print). Check if there is a back door and inspect for a paper jammed into the roller.
4. Paper jammed can be found in the toner cartridge itself. Check for teared paper inside the toner cartridge.
Please let me know if you need more help
Mar 05, 2011 | Kyocera Fs-1300d Printer
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
C5180 Keeps repeating: Clear Paper Jam. Despite looking very carefully there appears to be no paper or jam. Powered off and retried a number of times without success
You need to open up the printer in order to truly look carefully. Sometimes it just needs a good cleaning internally, dusted, swiped with alcohol. Sensors can be very delicate.
Mar 02, 2011 | HP Photosmart C5180 All-In-One InkJet...
Get paper jam message, paper is marked at the begining of the sheet but not jammed. When select copy button ,there is no paper jam problem, only when print command is used to print a document
Please follow this instructions to resolve your issue.
Solution # 1 Power cycle the printer
  1. Turn off the printer
  2. Unplug the power cable at the back of the printer
  3. Wait for at least 1min.
  4. Plug the power cable again
  5. Print test page using the printer itself (press and hold the OK and HELP buttons on the front panel of the printer, until it will prints a test page, then release the buttons.)
If you still having that error message, please proceed to the next step.
Solution #2 Clear any jams on the printer itself
  1. Turn off the printer.
  2. Please make sure that you will not take out any jammed papers in front of the printer, it can cause a mechanical damage on the printer.
  3. At the back of the printer, take out the access door.
  4. Clear any jammed papers, please make sure to clear the rollers.
Solution #3 Please make sure that the carriage will moves freely
  2. Open the cartridge access door
  3. Disconnect the power cable at the back of the printer.
  4. Check for any paper or other object that might restrict the carriage movement.
  5. Reach inside the product through the cartridge access door, and then manually move the carriage.
  6. Remove any paper or objects you find that restrict the movement of the carriage.
  7. Make sure the carriage can move freely across the width of the product. Firmly push the carriage to the left, and then to the right.
  8. Close the cartridge access door.
  9. Reconnect the power cable to the rear of the product.
  10. Press the power button to turn on the printer.
  11. Print test page using the printer itself (press and hold the OK and HELP buttons on the front panel of the printer, until it will prints a test page, then release the buttons.)
If your still having issues with it you need to contact HP to have your printer replace, if your printer is still in warranty you don't need to pay for anything, but if the printer is out of warranty charges may apply. 1800-474-6836
Good luck :)
Feb 17, 2011 | HP Photosmart C5180 All-In-One InkJet...
My kodak All-in-one printer ESP9 goes instantly in paper jam. Checked for a paper jam and found no paper jam or any paper anywhere inside machine. Pressed down on "OK" button and printer...
Had same issue with my ESP 9, called up the kodak support lines and spoke to them over the phone, getting a replacement sent out free of charge and I've owned this for 1 year and 4 months and only had one prior printer jam which righted itself in the past. Seems like ESP 9's are prone to the unfixable printer jam.
Best bet call kodak and get it sorted.
Jan 12, 2011 | Kodak Office Equipment & Supplies
Paper jammed and has switched itself off now can't switch it back on? how can i get it back on?
Well, 1st you should tell what typeof printr you have ,
1- open all doors and remove all the turned paper , there isare keys and sencers are available in the printer will not be active unless in normal case .
2- mean drawer of paper should be checked also .
3- open cartidge and check if there is any trouble in the paper slide way .
2- reset the printer
Oct 28, 2010 | HP Office Equipment & Supplies
Its saying paper jam when iv only just installed it and i have not evan put any paer in yet. help me please this is a kodak esp.3
It means it has "paper jam"error message. This is a common issue w/ the ESP printers of Kodak especially if its brand new.
Try the steps below.
1.Open the printer access door.
2.Remove the black and color ink cartridges.
3.Reseat the printhead.
a. Lift the printhead release latch
b. Reseat the printhead, pushing firmly on the white label on the printhead (if provided) or the center of the printhead, until it clicks into place.
NOTE: You may also visit www.kodak.com/go/printheadsupport for demonstration on reintalling the printhead
4. Close the access door.
5. wait for the printer to initialize.
If issue persists, the printer itself needs to be replaced. Call 1.800.421.6699
Thanks
Neerak21
Jul 05, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam
Usually paper jam error message on this machine is either caused by a physical paper jam or a printer error. To distinguish between the two I understand that you have already checked with the printer if there any paper or foreign object but there is none however, just to make sure you have checked everything out, check the left the side to double check. Now there is really nothing that you can see I really means that it is a printer error and that you would need to contact Epson directly to get a replacement. I do not recommend tearing off the printer because that's voids your one-year manufacturers warranty.
Jul 14, 2008 | Epson Stylus CX9400 Photo Printer
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
95 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
