Question about HP Vs17 17" LCD Flat Panel Monitor
Problem is my monitor takes about a hour to light up normally.
  • 734 Answers
Your backlight is failing. You need to get a new monitor. Sorry to be the bearer of bad news.
Regards,
Selk
Posted on Nov 15, 2010
For the past few weeks my Hanns G 19 inch LCD monitor keeps having troubles displaying a screen. It constantly makes a loud sound that it repeats and it takes several hours before the green light appears...
From the description you give, this sounds like a failure in the circuit board, normally the capacitors go and the thing refuses to power up, however, the fact it defaulted to a low resolution indicates that the actual board is in some way failing, possibly a damaged circuit, or component.
I would think it could be repaired and it may be a simple job for someone who can identify the failing component, however, I think that the cost of getting it repaired would outweigh the cost of replacement
Jun 22, 2011 | Hanns.G Corporation Computers & Internet
It takes an hour or two to come on blue light
Power supply caps should be checked out, look for caps with bulging top first, post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 26, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
I have a monitor HANNS-G It worked 3 years. And exactly after 3 years warrant policy ended my monitor got a problem. It looks like there is a problem in power connection on front buttons. After I connect a...
This is a problem with the power supply unit inside the monitor, there is no easy way out here. If you keep on using your monitor like this eventually it won't switch on no matter how long you wait. Keep on using it like this for the time being without switching off anything but ultimately you will have to take it in for repairs or otherwise purchase a new screen..
Aug 02, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
Lg flatron w2234s monitor is flashing ??
I am going to suggest if it's only 3 months old you should take it back to where you bought it. Mine quit working right a few weeks after I bought it and they gave me a new one. Be sure you take your receipt with you. Even new things can mess up.
Mar 02, 2017 | Computers & Internet
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
LCD HP 1730
Normally it is no more then $45-$50 total.
It will take about 2-3 hours but normally I reccomend a 24 hour period to allow for full after repair testing to ensure everything is running as it should.
Apr 17, 2008 | Computers & Internet
LG Studioworks 700E
It sounds like one of the capacitators inside the monitor is malfunctioning, these little things store a certain amount of necessary power and then discharge it when it is needed.  If it is malfunctioning, it could explain why it takes so long to charge, and why when you hit it, it suddenly comes on.
Jan 09, 2008 | Computers & Internet
LCD Monitor blacks in and out for 1-2 seconds
does your monitor have an external transformer as the psu ?
If so, try disconnecting at mains for about 5 seconds and re-connect. failing that we'll need to dig deeper.
Jan 06, 2008 | Samsung SyncMaster 205BW LCD Monitor
Scanport H21 problem.
Fried chips? Tech with electronic repair requested.
Sep 08, 2017 | Scanport H21 21" LCD Display Monitor
Monitor revives only after cycling the power many times
Unscrew 4 screws on the back side. Place the monitor with the front up and open it along the upper seam. Turn it again and lift the back cover. Shift the inner case "up" and take the button holding plate out - it is being held only by a tape. Inspect it and clean it. You might have to replace the condensers and/or switches on it.
This might solve the problem, but there may be other causes as well.
Aug 03, 2006 | Dell UltraSharp 1905FP 19" LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
