Question about Lenovo Ideapad U350 Laptop Notebook
I use windows 7 operating system on lenova ideapad U350 keyboard and mouse is disabled : it is not detected after boot:
    Guru:
  • 125 Answers
It is easy to use and you do not have to change the settings for it to do its job, it can adapt its charge in the Dell Inspiron 6000 battery, it is re-fueling and, once the battery is full, this is converted into a pulse charge.
Posted on Nov 15, 2010
Help how to format lenovo ideapad s300 in windows 7
If you want to format your entire hard drive (and reinstall windows) You'll need to insert the appropriate windows disk. If you want to reinstall 7, insert your windows 7 disk and boot off of the disk (When booting, it should start by showing a screen that says "Press any key to boot from CD..." and you can just press a key on your keyboard. From there, follow the on screen instuctions. When you get to the drive partitioning step, select your hard drive and partition you want to format. You can delete the partition you have and make a new one if you want to totally clean the computer (WARNING: This will literally delete everything on your computer. Everything). From there you continue and finish the setup (it may run for a while). And you have a fesh new hard drive and operating system install.
Sep 12, 2013 | Lenovo IdeaPad S300 Laptop Computer -...
Tip
Installation problems for keyboards/mice in XP
Removing the software and reinstalling it using a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Download the latest version of the software for your OS from the manufacturer's website.
2. Open the Windows Control Panel.
3. Open the Add / Remove Programs window.
4. Locate the listing for the keyboard/mouse software and remove it. When prompted to remove the keyboard/mouse drivers files, click Yes.
The following is the procedure for a 'clean boot' in Windows XP:
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hopefully, you should not have any problem now.
on Apr 25, 2008 | Logitech LX7 Cordless Optical Mouse
My lenova laptop BMR is compressed, what's the solution for it?
The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps
b>
Jan 20, 2013 | Lenovo 3000 G530 Notebook
I have a Lenovo U350 ideapad. When i rebooted it, it keep coming up Windows Error Recovery. I tried all the options (Safe Mode, Safe Mode with Networking, Safe Mode with command Prompt, Last known good...
Welcome to Fixya
Looks like the Windows OS is already messed up. You should be able to boot the computer to safe mode to troubleshoot the issue. In your case, it is not booting up to safe mode then the only way to use your computer again is to restore it from the factory default state. If you want to do that, just turn off the computer then press the ONE KEY button located beside the power button then follow the on screen instructions.
Thank you for using Fixya!
Sep 05, 2011 | Lenovo Ideapad U350 Laptop Notebook
IDEAPAD HAS SPANISH LANGUAGE ON IT WILL NEED TO CHANGE CMOS AND REINSTALL WIN 7 IN ENGLISH
On the IdeaPad, while the system is booting, before you get to the windows booting screen (during the BIOS boot), press F2 to bring up the BIOS options. From there, change the language ("idioma" in spanish) from spanish (Espanol) to english (Ingles). If that doesn't fix it, then change the language in Windows 7 (Start menu > Control Pannel > Clock, language, and Region > Region and Language)
You should not have to reinstall the operating system. If you have trouble navigating in Spanish, contact me at my listed email address.
Mar 19, 2011 | Computers & Internet
My webcam, veriface and easycapture are not working anymore. and i don't have the settings or backup or recovery.am using window 7 premium. pls help me out. thanks
Welcome to Fixya
Dont you worry. You can reinstall all these programs by downloading it at Lenovo site. Please click here. Make sure to select the correct operating system.
Let me know if you have further questions.
Feb 26, 2011 | Lenovo Ideapad U350 Laptop Notebook
All in one computer and mouse and keyboard are not responding.
Check your keyboard is working or not by accessing your BIOS by pressing del or Esc or F12 (usually) or whatever your boot up screen says. If your keyboard works there then the problem lies in the operating system.If still your keyboard doesn't respond then replace the keyboard.
only if keyboard work, you can fix mouse opearting system problems.
For windows Vista & 7, expand "Mice & other point devices".right click on Microsoft Ps/2 mouse" select uninstall and restart the system.If your mouse is still working the system will automatically installed the mouse driver.And your mouse will work again.
Otherwise get a new mouse.
Note: Check you have wrongly insert the mouse 7 keyboard port at the back too.
Remember : Green for Mouse
                   Purple blue for keyboard
Dec 22, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Mouse won't install
You may need to check your BIOS setting. The mouse be disabled there. You can access the BIOS thru the boot menu when your computer frist starts up. If the mouse is active as a usable feature, then you may have to a hard boot of your operating system with the OS(Windows Vista, XP, 2000, etc.) Cd you recieved with the computer. If that does not work, then you will have to a complete reinstall of your operating system.
Dec 06, 2009 | Gear Head Wireless Optical Tilt Wheel...
Hello.. ive had this computer with vista as its operating system, because im not used using vista ive reformat it to windows xp pro but after formatting screen goes blank.. what could be the problem?? the...
There likely may be no XP Drivers for this model. If thats the case your choices are Vista or Windows 7 (Windows 7 Only if the system is capable)
Friendly, affordable, REMOTE computer help!
Nov 23, 2009 | Computers & Internet
I have a wireless keyboard and mouse (Microsoft) I also have Vista operating system. When the computer sleeps when not being used, once awakened, the keyboard doesn't work and computer needs to be...
chances are its a driver problem, windows vista is not very stable, even with the 2 service packs now available. if u can, go to microsofts website and try to find drivers for your model of mouse and keyobard and get the latest drivers. otherwise, disable the sleep function or format the computer with windows 7 when its released, or windows xp.
Jul 08, 2009 | Microsoft Multimedia Keyboard/Wireless...
Lenovo Ideapad U350 Laptop Notebook Logo
147 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
